Problem pri odzipanju.
dux ::
Ko poskušam odzipati datoteko tipa .gz, dobim napako :
gzip: ime do datoteke.gz: decompression OK, trailing garbage ignored
Kaj naj storim ?
OS: Xubuntu 7.04.
Upanje je v nasih odlocitvah
StratOS ::
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
data cannot be decompressed
91141 (846) GTX970
72 ur po brodolomu na dnu oceana našli preživelega
82418 (2108) oo7
Mnenja o DELL 6400 Inspiron (strani: 1 2 )
9310369 (6964) steev
Program za formatiranje kode
Oddelek: Programiranje
111760 (1534) Gundolf
Kokoš ali jajce?
315710 (4238) krho
