Forum » Pomoč in nasveti » kako odpret file?
kako odpret file?
marjan_h ::
ubistvu mam 2 fajla na kompu en je .hqx drug pa .dmg. poskušal sm z daemon tools in nism mogu odpret.. help?
trek@s ::
Pojdi na tale link, stisni "CTRL + F", napiši notri "dmg" in "enter".
- spremenil: trek@s ()
StratOS ::
http://www.slo-tech.com/script/forum/izpisitemo.php?threadID=275496#neprebrano
http://www.slo-tech.com/script/forum/izpisitemo.php?threadID=275472#neprebrano
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
| » | Radeon 9600xt v okvariOddelek: Kaj kupiti | 4468 (4373) | dejan15 |
| » | 200GB disk zazna mi ga samo 130Oddelek: Strojna oprema | 5752 (5624) | HeXeD |
