Forum » Pomoč in nasveti » koda napake 008
koda napake 008
xena ::
Pri pošiljanju priponk preko gmaila mi napiše opozorilo:
Windows Internet Explorer:
"Opla! Sistemu ni uspelo izvesti te operacije (koda napake 008). Poskusite znova čez nekaj sekund."
Vendar ne pošlje ne čez nekaj sekund, ne čez nekaj ur niti čez nekaj dni...
xena ::
SEM ŠLA PO TEH KORAKIH, PA ŠE VEDNO NE DELA!
If you receive a 007 or 008 error, it's likely caused by one of three issues: configuration issues with security software installed on your computer, a browser cache that needs to be cleared, or a temporary glitch with the Gmail server.
Please follow all of the steps below in the order they're presented. If these steps don't fix the issue, you'll be able to report the problem to the Gmail team.
Step 1.
Many Internet security, firewall and anti-virus applications can prevent Gmail from working correctly. Please select all of the listed applications you have installed on your computer and follow the instructions provided. If you're still having trouble after following these instructions, please proceed to the next step.
Norton
ZoneAlarm Pro
McAfee
Freedom Privacy and Security
eTrust EZ Firewall
Kerio
Proxomitron
Telus
BellSouth Internet Security
None of the above
Norton
To use Gmail with Norton products, you may have to create a specific rule allowing pop-ups on the Gmail website.
Here's how to create a rule with 2003 Norton products:
Open your Norton software.
Click Options and select Web Content.
Select Add Site, and enter gmail.google.com.
Click the User Settings tab, and uncheck Use Ad Blocking settings.
Select Permit.
If you're using 2004 Norton products:
Highlight Ad Blocking and select Configure.
Click Advanced.
Click Web Contents, and select Add Site.
Enter gmail.google.com.
Select Permit.
And for 2005 or 2006 Norton products:
Open Internet Explorer.
Log in to your Gmail account at http://mail.google.com.
Click the NIS (2005 products) or Norton Internet Security (2006 products) icon on your browser's toolbar.
Uncheck the box next to Block pop-ups from this website.
Restart Internet Explorer.
If you'd like to disable the Norton 2006 pop-up blocker, just follow these steps:
Open the Norton 2006 program installed on your computer.
From the Options drop-down menu, select Norton Antispam.
Click General under Ad Blocking.
Uncheck the box next to Turn on Pop-up Window Blocking.
Click OK.
ZoneAlarm Pro
You may have to adjust some of the security settings in ZoneAlarm Pro so that Gmail functions properly.
Here's what to do:
Open ZoneAlarm Pro, and click Privacy.
Click Site List, and then click Add.
Enter mail.google.com.
Click the X under Persistent Cookie Control for mail.google.com.
Set the cookie control to Allowed.
Clear your browser's cache, and log in to Gmail.
McAfee
To use Gmail with McAfee products, please follow these steps.
Open your McAfee security, privacy, or firewall software.
Find your preferences for cookies, and set www.google.com and mail.google.com as allowed.
To use Gmail with Freedom, please follow these steps:
Click the Start button in your operating system's taskbar.
Select Settings, and click Control Panel.
Open Internet Options, and click the Advanced tab.
Remove the check next to Enable third party browser extensions under the Browsing header.
eTrust EZ Firewall
It may be necessary to adjust some EZ Firewall security settings. Here's how to do so:
Open EZ Firewall.
Click Privacy, then Site List.
Add gmail.com and google.com to your list.
Right-click the red x under Cookie Control: 3rd Party, and select Allow for both sites.
Kerio
You may have to adjust some of the security settings in Kerio Internet Security Software so that Gmail functions properly.
Here's what to do:
Add mail.google.com to Kerio's site exceptions list.
Exit and restart Kerio.
Clear your browser's cache.
Restart your browser and log in to Gmail.
Proxomitron
To use Gmail with Proxomitron, you may need to change some web settings. Please disable the following options in Proxomitron:
Kill pop-up windows
Restore pop-ups after a page loads
Suppress all JavaScript errors
Stop browser window resizing
Telus
To use Gmail with Telus, please follow these steps:
Uncheck the box next to Enable third party browser extensions under the Browsing header.
You can disable your BellSouth Popup Blocker by following these steps:
Click Start from your system tray and select Run...
Type cmd and click Okay.
Type cd c:Program Files//BellSouth/BellSouth Internet Security and press Enter.
Type regsvr32.exe/u pkr.dll and press Enter.
Step 2.
Your browser stores relevant information about sites you've visited to make browsing faster, but sometimes this data is incomplete or corrupt. Deleting your stored cache and cookies will often allow your browser to successfully work with Gmail. Please select your browser from the list below for instructions.
Firefox
Internet Explorer
Mozilla
Netscape
Safari
Firefox
Here's how to clear your cache in Firefox:
Log out of your Gmail account and close all other open browser windows.
Click the Tools menu at the top of your browser and select Clear Private Data...
Select the Cookies and Cache checkboxes.
Click Clear Private Data Now.
In some cases, it may be necessary to clear your cache more than once to completely fix the problem.
Microsoft Internet Explorer
To clear your cache in Internet Explorer:
Log out of your Gmail account. Close all other open browser windows.
Click the Tools menu at the top of your browser, and select Internet Options.
Click the General tab at the top of the dialogue box.
Click Delete Files under Temporary Internet files.
Select Delete all offline content by checking the box.
Click OK.
Mozilla
To clear your cache in Mozilla:
Click the Edit menu at the top of your browser, and select Preferences.
Click the + next to Advanced.
Select Cache under Advanced.
Click Clear Cache.
Click OK.
Netscape
To clear your cache in Netscape:
Click Clear Cache.
Click OK.
Safari
To clear your cache in Safari:
Open the Safari menu on your browser's toolbar.
Select Empty Cache.
Click Empty in the dialogue box.
Step 3.
Gmail offers an encrypted site for extra security. Because browsers and security applications are more likely to trust encrypted data, visiting Gmail through its encrypted login will often resolve issues caused by that software.
Please try logging into your account via https://mail.google.com before choosing an option below.
I tried the secure site but my issue continues.
I tried the secure site and my problem is resolved.
We're sorry for the inconvenience you've experienced.
We're glad to hear your problem has been resolved. Click here to return to Gmail.
Step 1.
Norton
ZoneAlarm Pro
McAfee
eTrust EZ Firewall
Kerio
Proxomitron
Telus
None of the above
Norton
Select Permit.
Click Advanced.
Select Permit.
Click OK.
ZoneAlarm Pro
Here's what to do:
McAfee
eTrust EZ Firewall
Open EZ Firewall.
Kerio
Here's what to do:
Proxomitron
Kill pop-up windows
Telus
Step 2.
Firefox
Internet Explorer
Mozilla
Netscape
Safari
Firefox
Click OK.
Mozilla
Click Clear Cache.
Click OK.
Netscape
Click Clear Cache.
Click OK.
Safari
Select Empty Cache.
Step 3.
marsovcek ::
Torej, ali uporabljaš kak firewall? Kaj pa kak drug brskalnik - npr. firefox? Si poskusila z njim?
xena ::
marsovcek, sm te šele zdej vidla...
Uporabljam AVG 7,5 in Windows Defender, kar ne bi smelo bit problem.
Ni fora menjat brskalnik, ampak bi se rada pregrizla skozi probem. Mi je všeč gmail in Internet Explorer pa ne bi rada menjavala.
| » | Avtomatsko posredovanje mailovOddelek: Omrežja in internet | 1443 (1318) | Hayabusa |
| » | eBay - nujnoOddelek: Loža | 2833 (2341) | mtosev |
| » | Msn TEŽAVA...!!! čudna zadevaa...Oddelek: Pomoč in nasveti | 2263 (1888) | d3n!5 |
| » | Ne predvaja novega audio CDOddelek: Pomoč in nasveti | 2617 (2573) | Tea Time |
| » | Kako v Win2k premakniti mapo Documents and Settings?Oddelek: Operacijski sistemi | 2542 (2508) | Mercier |
