Forum » Kaj kupiti » kateri 24" monitor kupiti
AlienRex ::
Silom prilike se moramo odločiti za nov monitor. Star LG E2441V-BN http://www.lg.com/us/monitors/lg-E2441V... je v garancijskem roku odpovedal poslušnost. Tega modela ni več, zato nam ponujajo menjavo zanj:
Moti me, da nobeden nima vse treh priključkov (DVI, VGA in HDMI) kot stari, pa tudi diagonale so malenkost manjše (23,6-23,8") in nobeden nima mat ohišja. Prosim za pomoč, katerega naj izberemo.
Hvala!
Hvala!
Dropbox: http://db.tt/Jg5BmDw
No brain - No tumors
spirit ::
opkliči jih in jim povej kaj te moti, da je manjši in ima svetleče ohišje, poleg tega jih prašaj če ti lahko dajo 24MP55HQ, za katerega bi se v najslabšem primeru odločil in ga vzamejo nazaj ti pa doplačaš malo in vzameš http://www.enaa.com/oddelki/racunalnist...
jonystar ::
Mal gledam monitorje na hardverversand, pa vidm, da majo eni Samsungi PLS panel in ker se ne spoznam glih na te stvari me zanima, če so PLS monitorji dobi in kakšna je razlika glede na IPS.
To je Samsungova varianta IPS.
Torej v grobem, to je "isto" kot IPS.
Tomson ::
PLS is a sub-set of IPS panel. Under the IPS umbrella, if you will, you have -> H-IPS -> AH-IPS -> P-IPS -> E-IPS -> eIPS -> S-IPS -> PLS, among a few others, that are not produced anymore. Except for the eIPS panel, all the above are essentially the same. Every manufacture does their own iteration of IPS panel, and all have a 5-10% up on something and down on something else. It's generally not noticeable to the eye. It's just to avoid patent disputes. PLS is Samsung version of the IPS panel. Because they want it to stand apart, marketing wise, they called it something different, but in reality it's the same. eIPS is different than the other IPS panels as it's full name suggests: economy IPS, is targeted at offering IPS panels on those on the budget. These are 6-bit panel, much like TN panels. So colors, while still better than TN and MVA panels, it's not as good as other more expensive IPS panel technologies. But the price, makes it very interesting. They are eIPS panel, competing against med-low range TN panels, which is a bit crazy. It kinda says: "why even get a TN panel", especially if you are not a hardcore FPS player and on budget.
Verjetno trenutno nima smisla kupovati dragega monitorja, ko je Ultra HDT v uvajanju. Razen, če nujno potrebuješ seveda.
RejZoR ::
Zakaj že? Ne vem zakaj folk misli, da je 4K rešitev za vse. Večina začetnih panelov bo kakšen cheap crap, res dobre boš dobil šele čez kakšno leto ali dve. In če si gamer, bo to avtomatično pomenilo, da boš zmetal še celo premoženje za grafične kartice, ker ti ena sama take ločljivosti ne bo poganjala v zadovoljivem frameratu.
Men ne bi bil problem dat še par sto evrov več za uber ne vem kakšen monitor, pa sem se ustavil pri 24 inčih in samo 1080p. Ker vem, da bom na tem lahko igre poganjal v max kakovosti na eni grafični. Je pa 144Hz in 1ms, kar pomeni, da je gibanje slike svileno gladko, 1080p mi povsem zadošča, če snemam gameplay bo v formatu, ki se odlično počuti na LCD TV-jih itd. Skratka cel kup stvari, ki meni osebno odgovarjajo.
Če se ukvarjaš z nečem drugim pač prilagodiš izbiro svojim potrebam in lahko mirno nekaj kupiš že sedaj. Sej imaš cel kup dobrih IPS monitorjev do hardcore gaming TN-ov in še vse vmes. Vse je samo stvar izbire. To da folk želi cheap ass monitorje za 150 EUR ničear ne spremeni za high end. Pol bi ukinili že vse iPhone in ostalo drago sranje, pa temu ni tako, ker je še vedno folk pripravljen plačat premium za top sjhit robo.
NejcSSD ::
Živjo, iščem monitor v rangu do 170 evrov.
Mora biti iz trgovine funtech, bom naročil v kompletu:
Raba : igre
http://funtech.si/si/vsi-oddelki/zaslon...
Je kaj bolšega, cenejšega?
Vem je TN matrika ampak ni pomembno
Raba : igre
PC : MAG B550 Tomahawk, Ryzen 5600X, 32Gb 3200Mhz CL16, 2x 1TB NVME, MSI 1070Ti
jonystar ::
Kater kabl naj kupm, da bom lahko povezou računalnik(DVI-D) z monitorjam k ma HDMI prklučk:
Dual-link
http://www.hardwareversand.de/en/HDMI/7...
ali Single-link
http://www.hardwareversand.de/articlede...
Dual-link
ali Single-link
jonystar ::
Grafična je Geforce 9800GT in lahko not utaknem tut DVI-D dual-link kabl, sam pač me zanima če je kakšna razlika v kvaliteti slike med dual-link in single-link al je vseen.
jonystar ::
aha, dobro, pol nima veze kerga vzamem, ker je itak max. resolucija monitorja 1920x1080.
The Muppet ::
Pozdravljeni,
kupujem (poleg komponent) tudi nov LCD monitor - 23" ali 23". Uporabljan bo skoraj izključno za gaming. Pogoji: solidne barve (ne rabi pa bit nevemkaj über), dober za igranje v temnem okolju (čim manj glowa, backlight bleedinga itd.), čim manj ghostinga, blura in teh sranj, nisem pa pretirano občutljiv na to zadnje dvoje. Bolj je pomembno backlight bleed in IPS glow. Aja, pa ne sme bit previsok (max. 43 cm).
Gledal sem te:
Nekako bi najraje ubavil U2414H, ker je čislan povsod, kjer sem gledal, edino me zanima, kako je z "IPS glow-om" v praksi? Kako zelo moteč je pri igranju v temni sobi? Kako zelo vpliva vidni kot (če je treba gledati naravnost v monitor +/-1°, ali je "dead-zone" večji?)?
Se pa vseeno vedno bolj nagibam h kakšni cenejši alternativi. Nenazadnje je razlika kar 80€ med U2414H in E2314H. Vem, da je malo dnarja=malo muzike, ampak ker nisem pretirano zahteven me zanima, če ima kdo izkušnje z E2314H in če je preskok na U2414H vreden tega denarja?
Vmesne opcije sta dva Asus-a, en IPS in en TN. Je moj sum, da je Asus-ov IPS opazno slabši od Dell U2414H zaradi cene utemeljen? Pozna kdo primerjavo?
Nevem, sem v velikem precepu, ker je budget kar omejen, ne bi pa se rad zasral in kupil nekega sranja, ki me bo motilo še nadaljnjih 5-6 let.
Gledal sem te:
barocco ::
@The Muppet
imho,Sam bi vzel DELL U2414H,to pa zato ker imam sam Dell2312HM IPS ,uporablajam ga za gaming.Se ponavljam,"žal" se pri nakupu nisem stegnu in vzel raje DELL Ultra Sharp 2412HM.
Ne me razumet narobe tud ta je super monitor,če nisi neki ultra zahteven uporabnik.Maš pa celo paleto nastavitev,če te kaj moti oz. našel boš svoj profil ki ti bo všeč(DELL).
Za druge zgoraj omenjene ti ne znam povaedati nič,razen da pred nabavo sem imel TN in je ogromna razlika,sploh v gamingu lepše barve vidni kot,ni da ni ,ne boš zgrešu z dellom.
RangerVIII|6700k|Corsair16GB|
Msi1070|pm961|BX5001TB|RM650x|H100iv2|
The Muppet ::
@The Muppet
Hvala za mnenje. Se kar nagibam k U2424H bolj in bolj, tudi, če je malo dražji. Bo le nekaj časa služil svojemu namenu.
Še to me zanima: igraš kdaj v temi? Je "IPS glow" kaj moteč?
Primer, kaj je IPS glow za vse, ki morebiti ne vedo:
Po videih sodeč bi me to lahko motilo...
Ja, tisto o 178 stopinj vidnega polja je pravljica, ki velja, če gledaš točno pravokotno od zgoraj/spodaj/levo/desno in od dovolj daleč.
barocco ::
@The Muppet
tudi sam sem se bal IPS glow,ipd.Bral gledu videe..in se tresu a bo ok..
Na koncu,pa Že pri prvi uporabi opazu ,da sem si preveč belu glavo z vsemi temi "slabostmi",ki naj bi jih monitor prinašal.
igram v temi in ne ni moteč ,ker ga ne opazim.
aja,Niti pod razno ni takega glowa niti 5%,ki si ga prlepu iz YT..
Meni,so že po defoultu nastavitve monitorja ustrezale.Malo sm spremenu brightnes in contrast,pa toploto barv,to je pa vse.
Maš malo morje natavitev,tko da verjemi ,da boš našel svojo pravo za svoje oči.
Lej Igre zgledajo fenomenalne(z leve,desne,gor in dol..) :)
prej sem imel BlueH 19" ki se skrije proti leto staremu Dell2312HM ips.
Sam imam, z njim dobre izkušnje,boljše kot sem pričakoval po branju po forumih.
Bi ga menu,samo v primeru,če mi kdo da 190€ zanj,da si dokupim delovga 24" hehe.
The Muppet ::
@The Muppet
Po defaultu so nastavitve kul, ker je ta monitor (kolikor vem) že tovarniško kalibriran.
Drugače pa: sliši se super, res ti hvala za mnenje iz prve roke!
AjgaBidona ::
oj, mene pa zanima kateri od teh treh monitorjev je najboljši:
http://www.hardwareversand.de/en/60+cm+...
barocco ::
AjgaBidona je izjavil:
Na hitro,
Če bi ŽE moral izbirati med tremi bi vzel ASUSA.
NejcSSD ::
Za to ceno so kul, če pa bi se stegnil še ene 20-30evrov pa že lahko kšnga della vstopnega dobiš,
ki je out of the box že vrhunski
barocco ::
kaj pa bi izbral za tako ceno?
Kaj takega,če ti finance dopuščajo,pa maš 5+ let mir.
Jih dobiš tud ceneje izven SLO.
http://www.funtech.si/si/vsi-oddelki/za...
RejZoR ::
razlika je samo da je dual link za večje resolucije
In za višje hertze. 144Hz lahko pozabiš na navadnem DVI al pa HDMI kablu. Prvi prikaže zmazano sliko, pri HDMI pa sploh noče pokazat slike, ker zmore samo do 60Hz. Moraš obvezno imet ali Dual Link DVI al pa DisplayPort.
Motion ::
Jst mam philips 234e5q HAW http://www.enaa.com/search.asp?q=philip... in sem ful zadovoljen z njim. Super super slika in barve, edino stand je mal šašav.
ramiz?! ::
A je sploh opazna razlika med kontrastom 20.000.000 in 5.000.000?
Never regret anything, there's always a reason things happen.
Boljše vprašanje: je opazna razlika med 20.000.000 in 1.000?
Ne ravno.
Razen če gre za "local dimming", kar pa monitorji nimajo, kolikor vem.
Ne ravno.
- spremenil: MrStein ()
Ce koga slucajno zanima...
Dell je izdal nov 16:10 monitor, ki nekako nadomesca starega U2412M.
Sicer cene in dobava za EU trg se niso znane.
http://www.guru3d.com/news-story/dell-u...
ramiz?! ::
Jao... jst pa nabavil 2x U2412M pred dobrim tednom![]()
Jah če nisi pripravljen dat 2x 500€ za te dva nova, pomoje nisi dost falil...
Sej ne bo taka cena, ker to je ze vec, kot je U2413, s tem, da je slednji za en rang ali dva visje.
kuglvinkl ::
Imo ne sme bit dražji od tega http://geizhals.at/de/dell-ultrasharp-u..., ker je ta wide gamut.
AjgaBidona ::
kateri je najboljši monitor do 200 iz funtecha?
rabil bi ga za računalnik z xeon e3 in gtx 770 za gaming
AjgaBidona ::
če že ne dobim odgovora mi prosim vsaj povejte če je kaj od tega vredu oz. kateri izmed teh monitorjev je najboljši za denar?
a bi se dalo še kaj boljšega od teh štirih monitorjev dobit pri funtechu?
hvala
hvala
NejcSSD ::
@AjgaBidona jaz bi vzel Della.
A kdo ve kje bi dobil čimhitreje pri nas Dellov U2414H?
jonystar ::
jest mam točno ta model Della in morm rečt, da je to najbolši monitor kar sem jih kdaj mel. Slika je super, kar je pa še bolj pomembno je to, da me oči nč ne bolijo tut če cel dan delam kaj na računaliku, tega recimo pri prejšnjem monitoruju nisem mogu. Pa priporočam, ti, da pogledaš v tujino, ker je tam ceneje. Mene je s poštnino vred stalo 164€.
NejcSSD ::
Govoriš za P verjetno ne ?
AjgaBidona ::
zdej se odločam med
in
a se mi bolj splača vzet cenejšega 23" in gtx 970 ali je bolje dat teh 70€ več za 24" monitor pa vzet slabšo grafiko - gtx 770/280x ?
in
Ne pozabit, da boš monitor verjetno imel 5 ali celo 10 let, grafična pa se menjuje pogosteje.
Je pa tale Dell P24 baje dober.
99ghetto99 ::
Kupujem monitor 24", uporabljal se bo za programiranje in za gaming. Glede cene pa tam do 150€ +- 10€. Kupujem pa izključno v Sloveniji.
lp, Klemen
lp, Klemen
Map ::
Ker je ta tema o monitorjih najbolj aktivna bom kar tukaj vprašal, čeprav iščem 27" monitor.
Katerega od teh priporočate:
http://www.asus.com/Monitors_Projectors...
http://www.lg.com/ae/monitors/lg-27MP75...
http://accessories.us.dell.com/sna/prod...
Ti trije so mi takoj padli v oči. Je kaj boljšega oz. kaj je najboljše za ta denar(250-300€)?
Amdforce ::
Jaz imam tega lg-ja in je super,kalibriran out of box, barve zelo naravne, vglavnem priporočam.
Map ::
Glede dizajna je tudi meni najbloj všečen, lepa oblika, tanki robovi itn., je pa Dell bolj praktičen. Ima DVI priključek pa nekaj USBjev ima. Asus ima pa Bang&Olufsen zvočnike, so pa vseeno LGjevi močnejši. Pa še dejstvo je, da je LG eden večjih proizvajalcev panelov, zato so sigurno kvalitetni, ampak ima pa Dell daljšo garancijo in naj bi imel zelo dobro podporo kupcem. Skratka, vsak ima svoje prednosti in včasih že ne veš, za katero prednost bi se odločil. Bi pa zdaj dal na prvo mesto LG ali Dell, potem pa Asus.
- spremenilo: Map ()
Motion ::
99ghetto99 je izjavil:
lp, Klemen
Jst mam ta srednjega za 161e (od ostalih dveh (150e) se razlikuje samo v priklopih ter vgrajenih zvočnikih) in mi služi super. Barve so super, sicer mal preveč na rumeno po defoltu sam se jih da lepo skalibrirat. Odziven je prav tako dovolj za vikendsko nabivanje BF 4,... Edino stojalo je mal šašavo, sam podpira tud vesa tako da ni problem.
99ghetto99 ::
Motion za kateri monitor gre točno?
Me pa zanima razlika med tn in ips matriko.
Lp, klemen
Lp, klemen
