Grafična 8x agp na matični ki podpira 4x agp
teomi ::
Pozdravljeni!
Zanima me, če laufa grafična z 8x apg na matični 4x agp al je boljše če mam grafično s 4x agp?
Hvala!
Tr0n ::
http://www.neoseeker.com/Hardware/faqs/kb/10,63.html
"The bottomline is that your 8X video card can theoretically be safely TESTED in any 1.5V motherboard for compatibility. But if you know for a fact that your board only runs 1.5V AGP 2.0 spec and your 8X AGP 3.0 card runs only 0.8v spec, then the two should NOT be compatible one another. At the very least it will be unstable, if it runs at all. However, we've had a lot of users tell us that their AGP 8x cards work on 4x only motherboards. This is likely due to the fact that some AGP8X video cards are in fact universal 1.5V capable AGP3.0 cards that can run on either 1.5V or 0.8V (remember, AGP speeds are backwards compatible, only voltage incompatibilies cause problems)."
Urc ::
Jaz mam grafo ki podpira 8x agp na plati ki podpira max 2x :))
  • spremenil: Urc ()
nonenone ::
treba pazit na voltažo 1,5 V ali 3 V - to piše v navodilih za plato in grafično, drugače pa dela, jaz imam PCI express 8x na plati, grafično pa imam PCI 16x in lepo dela.
8x agp grafična na 2x agp
91578 (1403) karafeka
GF7600GT na GA-7VT600-L (Rev 1.x)
51381 (1318) John Abruzzi
8x AGP na 4x AGP
232018 (1707) darkcloud88
Odstopanja med 2x, 4x ter 8x AGP
191976 (1708) boštjan
AGP-pomoč
151434 (1246) Zheegec
