Forum » Programska oprema » AntiVir PE Classic in problemi z updatom
Rotaidal ::
Ta program uporabjam že kar nekaj časa in se mi je lepo posodabljal vsaki dan... sadaj pa kakšen teden pa ne. Tako da sem ga moral vedno ročno posodabljat. Sedaj pa še to več ne gre.
Ko pritisnem Start update. se mi povezuje, pol pa napiše " No connection to the internet could be produced". V reportu pa mi napiše to:
[3.3.2007 15:05:03] [INFO] [PLG] C:\Documents and Settings\All Users\Application Data\AntiVir PersonalEdition Classic\TEMP\AVUPDATE_45e9808f\
[3.3.2007 15:05:03] Command line for update application: "C:\Programi\AntiVir PersonalEdition Classic\update.exe" --config-file="C:\Documents and Settings\All Users\Application Data\AntiVir PersonalEdition Classic\update.conf" --install-path="C:\Programi\AntiVir PersonalEdition Classic"
[3.3.2007 15:05:03] User changed the logfile name to C:\Documents and Settings\All Users\Application Data\AntiVir PersonalEdition Classic\LOGFILES\Upd-2007-03-03-15-05-03.log
[3.3.2007 15:05:03] Installation Directory: C:\Programi\AntiVir PersonalEdition Classic\ Backup Dir: C:\Documents and Settings\All Users\Application Data\AntiVir PersonalEdition Classic\BACKUP\ Temp dir: C:\Documents and Settings\All Users\Application Data\AntiVir PersonalEdition Classic\TEMP\AVUPDATE_45e9808f\
[3.3.2007 15:05:03] [INFO] [GUI] Start the Update GUI... Displaymode: 0
[3.3.2007 15:05:06] [INFO] [PLG] Keyfile: OK [FULL Mode]
[3.3.2007 15:05:06] [INFO] [PLG] Avira AntiVir PersonalEdition Classic
[3.3.2007 15:05:09] Connection failed while downloading the file http://dl1.avgate.net/upd/idx/master.id...
[3.3.2007 15:05:09] Switching to next update server
[3.3.2007 15:05:10] Connection failed while downloading the file http://dl6.avgate.net/upd/idx/master.id...
[3.3.2007 15:05:10] Switching to next update server
[3.3.2007 15:05:12] Connection failed while downloading the file http://dl2.avgate.net/upd/idx/master.id...
[3.3.2007 15:05:12] Switching to next update server
[3.3.2007 15:05:14] Connection failed while downloading the file http://dl3.avgate.net/upd/idx/master.id...
[3.3.2007 15:05:14] Switching to next update server
[3.3.2007 15:05:20] Critical error: Connection failed while downloading the file http://dl5.avgate.net/upd/idx/master.id...
Internet mi deluje super... požarni zid(zone alarm) ne blokira Antivira... kje je problem?
svencbir ::
Jaz sem poskusil "pingati" http://dl5.avgate.net/, in mi ne vrne odgovora. Verjetno so strežnike zamenjali. Poskusi še ti:
Start/Run(zaženi) in vpiši cmd. Nato vpišeš v okno ping http://dl5.avgate.net/ ali pa namesto tega katerikoli drug naslov (poskusi najprej nekaj strežnikov ki delajo zagotovo, npr Google.com, najdi.si). Med ping in naslovom je presledek. Če ti za noben naslov od antivirusa ne vrže odgovora so strežniki offline.
Rotaidal ::
Sem sprobal. Za google je šlo... za avgate.net pa ne
Sem pa šel na njihovo internetno stran, da bi si dol potegnil nov antivir... in ko sem šel na download mi vrže stran na kateri piše:
This Site Is Under Construction and Coming Soon.
This Domain Is Registered with Network Solutions
Tako da je to problem.
| » | nod32 in avaraOddelek: Pomoč in nasveti | 889 (823) | bluefish |
| » | kateri antivirus, firewall ter spy-wareOddelek: Informacijska varnost | 2501 (2340) | rkajtn |
| » | Nakup licenc antivirusaOddelek: Kaj kupiti | 2512 (1918) | ta-mau |
| » | Antivirus za 128MB rama?Oddelek: Pomoč in nasveti | 1311 (1166) | mirkuma |
| » | Antivirus (strani: 1 2 )Oddelek: Programska oprema | 7172 (6197) | BigFoot |
