Forum » Elektrotehnika in elektronika » [Koda] Lcd od nokie 3310 in pic 18F877
Azrael ::
V to temo sem prenesel kodo, ki jo je prilepil v temo Lcd od nokie 3310 in pic 18F877
uporabnik Nitro Tech, saj koda izvorno temo neprijetno podaljša in naredi nepregledno,
moderator.
moderator.
' NOKIA 3310 LCD MODULE
DEFINE LOADER_USED 1
DEFINE OSC 20
DC VAR PortB.6
DTA VAR PortB.5
RST VAR PortB.7
CLK VAR PortB.4
Chr VAR Byte
BitMap VAR Word
CharCount VAR Byte
PosX VAR Byte
PosY VAR Byte
Column VAR Byte [6]
LCDstr VAR Byte [26]
LcdData VAR Byte
PAUSE 100
GOSUB LCD_INIT
PAUSE 100
GOSUB LCD_Clear
Start:
PosX=0:PosY=0:GOSUB LCD_GotoXY
FOR Chr=0 TO 13
LOOKUP Chr,["NOKIA LCD TEST"],BitMap
LCDstr(Chr)=BitMap
NEXT Chr
GOSUB LCD_StringOut
PosX=0:PosY=1:GOSUB LCD_GotoXY
FOR Chr=0 TO 13
LOOKUP Chr,[" GRAPHICS "],BitMap
LCDstr(Chr)=BitMap
NEXT Chr
GOSUB LCD_StringOut
PosX=0:PosY=2:GOSUB LCD_GotoXY
FOR Chr=0 TO 13
LOOKUP Chr,[" 84X48 PIXELS "],BitMap
LCDstr(Chr)=BitMap
NEXT Chr
GOSUB LCD_StringOut
PosX=0:PosY=3:GOSUB LCD_GotoXY
FOR Chr=0 TO 13
LOOKUP Chr,[" CONTROLLED "],BitMap
LCDstr(Chr)=BitMap
NEXT Chr
GOSUB LCD_Stringout
PosX=0:PosY=4:GOSUB LCD_GotoXY
FOR Chr=0 TO 13
LOOKUP Chr,[" BY "],BitMap
LCDstr(Chr)=BitMap
NEXT Chr
GOSUB LCD_Stringout
PosX=0:PosY=5:GOSUB LCD_GotoXY
FOR Chr=0 TO 13
LOOKUP Chr,[" PICBASIC PRO "],BitMap
LCDstr(Chr)=BitMap
NEXT Chr
GOSUB LCD_Stringout
Loop:
PAUSE 2000
LOW DC
LcdData= %00001101:GOSUB LCD_ByteOut ' Invert
PAUSE 2000
LcdData= %00001000:GOSUB LCD_ByteOut ' Blank
PAUSE 2000
LcdData= %00001100:GOSUB LCD_ByteOut ' Normal
GOTO loop
LCD_Init:
LOW RST :pause 20 : HIGH RST : LOW DC ' RESET LCD
LcdData= $21: GOSUB LCD_ByteOut ' LCD EXTENDED COMMANDS
LcdData= $c8: GOSUB LCD_ByteOut ' SET LCD Vop (CONTRAST)
LcdData= $06: GOSUB LCD_ByteOut ' SET TEMP COEFFICENT
LcdData= $13: GOSUB LCD_ByteOut ' LCD BIAS MODE
LcdData= $20: GOSUB LCD_ByteOut ' LCD STANDARD COMMANDS
LcdData= $0c: GOSUB LCD_ByteOut ' LCD IN NORMAL MODE
RETURN
LCD_ByteOut:
SHIFTOUT DTA,CLK,1,[LcdData]
RETURN
LCD_CharOut:
IF lcddata=32 THEN BitMap=216 ' SPACE
IF lcddata=42 THEN BitMap=240 ' *
IF lcddata=43 THEN BitMap=222 ' +
IF lcddata=45 THEN BitMap=228 ' -
IF lcddata=46 THEN BitMap=234 ' .
IF lcddata=58 THEN BitMap=246 ' :
IF LCDData > 47 THEN ' Numbers 0-9
IF lcddata < 59 THEN
BitMap=6*(lcddata-48)+156
ELSE ' Capital Letters A-Z
BitMap=(LcdData-65) * 6
ENDIF
ENDIF
FOR Chr=0 TO 5
READ BitMap+Chr,Column(Chr)
NEXT Chr
HIGH DC
SHIFTOUT DTA,CLK,1,[Column(0),Column(1),Column(2),Column(3),Column(4),Column(5)]
RETURN
LCD_StringOut:
FOR CharCount=0 TO 13
LcdData=LCDstr(CharCount)
PAUSE 80
GOSUB LCD_CharOut
NEXT CharCount
RETURN
LCD_Clear:
HIGH DC
FOR Chr=1 TO 252
LcdData=0:GOSUB LCD_ByteOut
NEXT Chr
RETURN
LCD_GotoXY:
LOW DC
LcdData=%01000000 | PosY :GOSUB LCD_ByteOut
LcdData=%10000000 | PosX :GOSUB LCD_ByteOut
RETURN
' Font tabela
CData $00,$00,$00,$00,$00,$00 'stevilka nič
CData $FF,$FF,$FF,$FF,$FF,$FF 'stevilka ena
CData $07,$07,$07,$00,$00,$00 'stevilka dva
'in tako naprej...
' Če hočeš prikazati kakšen alfanumerični znak rabiš še font tabelo z njihovimi hex kodami, ki pa je cela predolga da bi jo tukaj objavljal.
END
Nekoč je bil Slo-tech.
- zaklenil: Azrael ()
| » | [Java] Zasnova shoot em up igreOddelek: Programiranje | 1585 (1264) | PecenkA |
| » | Leteče luči; AT90S2313, AT89C2051Oddelek: Elektrotehnika in elektronika | 2921 (2742) | Red_Mamba |
| » | [Win32 API]Popup menu v taskbaruOddelek: Programiranje | 1201 (1158) | 64202 |
| » | Drop down meni!Oddelek: Izdelava spletišč | 2293 (2046) | ACE |
| » | Collision detectionOddelek: Programiranje | 2743 (2495) | Senitel |
