call of duty 2..rcon problem
freekshot ::
zivjo!!!
mam en problem...
kadar hočem vpisat rcon password za server mi vrže vn tole
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x800A271E): Invalid argument
at MSWinsockLib.IMSWinsockControl.SendData(Object data)
at AxMSWinsockLib.AxWinsock.SendData(Object data)
at COD2_Rcon_Commander__final_.Form1.Button1_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
COD2 Rcon Commander (final)
Assembly Version: 1.0.2142.6731
Win32 Version: 1.0.2142.6731
CodeBase: file:///C:/Program%20Files/Rabid%20Servers/COD2%20RCON%20Commander/COD2%20Rcon%20Commander%20(final).exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
AxInterop.MSWinsockLib
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/Rabid%20Servers/COD2%20RCON%20Commander/AxInterop.MSWinsockLib.DLL
AxInterop.VBUProgressBarControl
Assembly Version: 5.0.0.0
Win32 Version: 5.0.0.0
CodeBase: file:///C:/Program%20Files/Rabid%20Servers/COD2%20RCON%20Commander/AxInterop.VBUProgressBarControl.DLL
CodeBase: file:///C:/Program%20Files/Rabid%20Servers/COD2%20RCON%20Commander/Interop.VBUProgressBarControl.DLL
Accessibility
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
CodeBase: file:///C:/Program%20Files/Rabid%20Servers/COD2%20RCON%20Commander/Interop.MSWinsockLib.DLL
Microsoft.VisualBasic
Assembly Version: 7.0.5000.0
Win32 Version: 7.10.3052.4
CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualbasic.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
tut mal mi ni jasn zakaj mi to nardi!!!:s
ce mate kksno idejo...plis pomagejte:O :(
amigo_no1 ::
.net framework 1.1 te zajebava in/ali cod2 .
Seštevanje, odštevanje za drugošolce
Oddelek: Šola
102133 (1789) norcuron
[c#] Vprasanje glede BackGroundWorker classa in spreminanja gui elementa
Oddelek: Programiranje
61089 (1015) Ericssony
[c#] Vprašanje glede release verzije aplikacije
51964 (1788) Ericssony
Tezava pri instanciranju class-a
61761 (1632) KernelPanic
null reference exception na čudnem mestu C#
51734 (1671) krho
