Forum » Kaj kupiti » Kje do Opterona 939 (Dual core) ?
gfighter ::
Menda so naročili malce večjo pošiljko, tako da jih pokupite preden jih zmanjka. Kolega ga je šel iskat dve uri nazaj...
Catapultam habeo. Nisi pecuniam omnem mihi dabis, ad caput saxum immane mittam
ok torej mam opterona. un je ocitno mal zamesu ceno. cena je taka kot je bla prej
ampak ni vazno. jest sm cpu dubu in to je to.
trenutno se mal testiram...tole je zdele (zaenkrat se) stabilno na 1.35V. testiram pa z orthos beta. ubistvu prime za dual core.
mi pa voda skor vre ze
zdele sm sam tok zakuru, da se pasta mal razleze. jutr pa visam frekvence.
upam vsaj na 2.9GHz.
CPU-Z 1.38 report file
Processor(s)
Number of processors 1
Number of cores 2 per processor
Number of threads 2 (max 2) per processor
Name AMD Opteron 170 (UP)
Code Name Toledo
Specification Dual Core AMD Opteron(tm) Processor 170
Package Socket 939
Family/Model/Stepping F.3.2
Extended Family/Model F.23
Brand ID 44
Core Stepping JH9-E6
Technology 90 nm
Core Speed 2520.6 MHz
Multiplier x Bus speed 10.0 x 252.1 MHz
HT Link speed 1008.2 MHz
Stock frequency 2000 MHz
Instruction sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size
Chipset & Memory
Northbridge NVIDIA nForce4 rev. A3
Southbridge NVIDIA nForce4 MCP rev. A3
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR
Memory Size 2048 MBytes
Memory Frequency 210.1 MHz (CPU/12)
CAS# Latency (tCL) 2.0 clocks
RAS# to CAS# (tRDC) 3 clocks
RAS# Precharge (tRP) 2 clocks
Cycle Time (tRAS) 5 clocks
Bank Cycle Time (tRC) 7 clocks
DRAM Idle Timer 8 clocks
Command Rate 1T
Processor(s)
Code Name Toledo
Package Socket 939
Brand ID 44
Technology 90 nm
Chipset & Memory
Memory Type DDR
Command Rate 1T
WhiteWolf ::
Moj opteron 170 gre na 2850Mhz pri 1.5V z Big Typhoonom Dual Prime stable.
"Maximus Decimus Meridius: What we do in life, echoes in eternity"
jest sm svoga uceri potem ser probu za 2800MHz @ 1.5V dual prime stabilno (cca pol ure sm pustu).
z vodnim hlajenje je mel cpu cca 70°
cevi so ble tudi cist mehke od vrocine...
ocitno bo treba pokrov na procesorju odsekat
WhiteWolf ::
Zgleda, da bo moral IHS dol ja. Men se je lepo poznalo. Okol 10 stopinj.
gfighter ::
Visoke temperature imate. Jaz imam svojega pol leta na 2800, temerature so pa max 55 stopinj full load z zračnim hlajenjem. Sta pa HS in spoliran Big Typhoon skupaj dala 10 stopinj.
DominusSLO ::
gfighter
Pri kakšni sobni temp. ima tvoj proc 55°?
cpu&nb watercooled, gpu on air at the moment
zelo dvomim v 55°C pri 2800 z zracnim hlajenjem. tok sm jest mel z 3000+ @ 2800 in 1.7V. sam opteron se pri 1.4V bolj greje kot SC A64 pri 1.7V...
DominusSLO ::
Moj x2 3800 pride na 1,55V in 2750mhz na max 53°C, če je v sobi 25°(voda ~29°). Gor originalno ihs.
kje pa to gledas?
men npr speedfan kaze cpu core 61-63°C zdele. v sobi je 23°C, cpu pa 2800 @ 1.525V dual prime.
mam pa 3 bloke na vodnem in od yugota radiator z enim 120mm ventilatorjem na ene 1500rpm, vse skupi zapakirano v kisti.
gfighter ::
Dr. M: Tako pač je pri meni. 55 stopinj je v bistvu že veliko zanj, ponavadi so temperature pod 50 stopinj tudi med delom ali igranjem. Večurne 100% obremenitve so itak redke. Kot sem že rekel sta pri meni poliranje in HS dodala okoli 10 stopinj, svoje naredi še 10 ventilatorjev na ohišju (vsi na 7V zaradi tišine), prostorno ohišje (Dragon Big Tower) ter voltaža 1,392 po CPU-zju. Tule je npr. screenshot od lanske jeseni ko sem proc še testiral na 2,7. Če te zanima cela zgodba, pa preberi tole temo. Začetek je IMHO zanimiv, konec pa tudi...
DominusSLO: Termometra sicer nimam zraven, ampak s kurjavo ne šparamo...
DominusSLO ::
Dr_M
Jaz mam tudi 3 bloke, pa 2 radiatorja in na vsakem en 12vent na 5V
Temp. pa čekiram v MBM(kaže isto, kot bios). Vse to pa na asrock dual 939 plati
AngelOfDeath ::
@DominusSLO
Jaz nisem mogel usposobiti MBM da bi delal na asrock 939 dual...
Sem si zato speedfan potegnil
Drugače je pa Temperatura proca okoli 35 stopinj (Hladim z big typhoon VX), sistemska pa 32. vendar pa ni nič navit.
edit: Slovnica
GUFY ::
Kupil sem zadnjega Opterona 170 pri Mlacomu imajo pa še 4 kom Opteronov 165. Poročam ko ga malo stestiram.
Čmrlj ::
OPTERON 170 208€.Mislim da preveč,glede na to da za ta denar dobi e6400.Je pa res da gre za 939 socket,ki je že skoraj izven prodaje.
GUFY ::
Za vse, ki imamo še stari socket 939 je to ceneje kot pa prehod na Intel, saj to za sabo potegne še menjavo plate in rama, kar pa tudi ni prav poceni.
chucki ::
Se splaca za 120 eurov kupit novega AMD Dual-Core Opteron™ 165, 1.8 GHz Retail Boxed iz UK?
- spremenil: chucki ()
chucki ::
Zdi se ti malo,ampak pr nas v Sloveniji je vse drago.
120 evrov je drobiž, pri nas stane 195, v Mlacomu še malo manj.
Križ je lahko edino z garancijo.
Čmrlj ::
Odvisno GUFY, če imaš zdaj kako DFI NF4 Ultra-D plato ,boš dobil zanjo cca 80 eur,pa če imaš bh-5 rame,ki imajo tudi kar solidno ceno jih pomoje tud komot prodaš za cca 100 eur.Pa dodaš 50 eur (skupaj je 230 eur) in imaš solidno c2d plato na 965 chipsetu BIOSTAR TForce 965PT (115 eur) in 1Gb kit OCZ XTC ddr2 800( 110 eur).Za tistih 200 eur ki košta opty 170 pa vzameš E6300 in ti ostane še za en dokaj soliden cooler
chucki ::
Kdor ne reskira,ne profitira!
Bom kupil konec meseca,ko se kartica obrne.
GUFY ::
čmrlj: Moraš vedeti, da si jaz ne bom šel kupovat Biostar matične plošče, ker čakam na DFI plato na 965 chipsetu, pa tudi ram si bom omislil malo overclockerski, proc bo verjetno 4400 ali pa 6600, tako, da bi mene prišel prehod na Intla kar malo več kot si ti računal.
čmrlj: nismo usi tok bogati, da bi poceni kupoval
tuki smo nekateri taki, da ce ze kupimo neki, kupimo najboljse, oz vsaj bluzi tega.
gfighter ::
Menjava dobrega 939 sistema za C2D je bedarija. Konkretno, kolega dobi z navitim opteronom in 8800GTS skoraj 16.000 točk v 3dMarku05, prej jih je z A64 3000+ (2700Mhz) pod 13.000. Zakaj bi menjal vse skupaj in se zajebaval s prodajo komponent, če pa bo razlike mogoče par 10%. Ni vredno ne časa ne denarja če nisi ravno OC freak.
lopov ::
Trenutno mam 754 plato z A64 3400+ (stock 2400 MHz varianta).
Da ne bi menjal se grafiko in ram me zanima, se da dobiti se kaksno plato z AGP za te Opterone? Grafika je GF6800 in mi dobro sluzi, rami so pa tudi neki noname DDR1.
Thx,
b.
Thx,
b.
ne splaca se. za to, da nebi menju grafike, se ti res ne splaca...
lopov ::
Racunam na to da bi plato dobil brezplacno, v tem primeru se mi pa izide. Ta NF3 je cist v kur** in mam same probleme z rami.
Pa ce dobim proc iz US, bi bilo se lepse (oke, to je spekulacija, ampak cisto realna).
Lp,
b.
Lp,
b.
Mogoče kdo ve, če lahko še sploh kje v sloveniji dobim opterona 165 ali 170?
Novega seveda.
Novega seveda.
ATI cards are like buses... They're huge, red and have bad drivers.
369 evrov
Za to si raje kaj drugega nabavim.
Jackal ::
Za takšno ceno dobiš pa že skoraj celo novo platformo na C2D (procesor, plata, ram).
Walking the way is something completely different than imagining the way.
zvite grable ::
Nasi prodajalci kr fajn oberajo folk. Sm najdu kolk stane operon 180 pri AMD-ju. SAM SI POGLEJ.
bluefish ::
je res, da so prodajne cene veliko višje od proizvodne. Poleg tega pa so cene na navedeni strani veljavne za dobavo tisočih kosov na enoto. Torej, če si lahko privoščiš nakup 1000 procesorjev bodo tudi zate veljale te cene
- spremenil: bluefish ()
Pyr0Beast ::
Athlon 64 X2 3800+ (64-bit, Energy Efficient, 2.0GHz, 1MB total dedicated L2 cache, 2000MHz HyperTransport bus, socket AM2) $83
Aaaaaa ... aa aa. .. strelam jih pse. Jst pa dajal 50 jurju za proc XD
16 kosov na komad.. to bi si pa lahko privoščili :P
| » | Vprasanje glede rama in procesorja AmdOddelek: Kaj kupiti | 2222 (1812) | gfighter |
| » | Proc ali ram?Oddelek: Kaj kupiti | 1567 (1313) | >>><<< |
| » | Kateri procesor? (strani: 1 2 )Oddelek: Strojna oprema | 5613 (4591) | steev |
| » | Padec cen OpteronovOddelek: Novice / Procesorji | 4510 (3762) | Smorny |
| » | Opteron ali Athlon X2? (strani: 1 2 )Oddelek: Kaj kupiti | 6203 (4957) | ekseR |
