C#,HLSL, 3D texture
C#,HLSL, 3D texture
spelic ::
Pozdravljeni
A ima kdo kakšen primer kako v C# ustvariti 3D texturo in jo prenesti v shader kot spremenljivko sampler3d, tako da lahko izvajamo 3d mapiranje po texturi z ukazom tex3d.
Ali pa mogoče kakeršen koli primer v c# in 3d texturami, kako jih generiramo in prikažemo.
Hvala za pomoč
Senitel ::
Kaj pravzaprav hočeš naredit?
spelic ::
v c# bi naložil 256x256x256 3d texturo in jo obdeloval s shaderji.
problem je pa prenos te texture v shaderje. 2d texturo ni problem 3d pa nevem kako.
LP Denis
Senitel ::
Kreiraš "VolumeTexture" in ga nekako nafilaš (to si že), potem nastaviš z SetTexture teksturo na ustezen stage in jo uporabljaš v shaderjih tako kot vsako drugo teksturo (samo da imaš tu tri koordinate)...
Al rezultati niso taki kot jih pričakuješ?
spelic ::
to je primer shaderja za 2d texturo, nevem kako naj spremenim za 3d: zanima me samo sprememba za sampler3d namesto sampler.
struct VertexToPixel
    float4 Position     : POSITION;
    float2 TexCoords    : TEXCOORD0;
struct PixelToFrame
    float4 Color : COLOR0;
float4x4 xViewProjection;
Texture xColoredTexture;
sampler ColoredTextureSampler = sampler_state { texture = "/ColoredTexture/ ; magfilter = LINEAR; minfilter = LINEAR; mipfilter=LINEAR; AddressU = mirror; AddressV = mirror;};
 VertexToPixel SimplestVertexShader( float4 inPos : POSITION, float2 inTexCoords : TEXCOORD0)
    VertexToPixel Output = (VertexToPixel)0;
    Output.Position = mul(inPos, xViewProjection);
    Output.TexCoords = inTexCoords;
    return Output;
PixelToFrame OurFirstPixelShader(VertexToPixel PSIn)
    PixelToFrame Output = (PixelToFrame)0;
     Output.Color = tex2D(ColoredTextureSampler, PSIn.TexCoords);
    return Output;
technique Simplest
    pass Pass0
        VertexShader = compile vs_1_1 SimplestVertexShader();
        PixelShader = compile ps_1_1 OurFirstPixelShader();
Hvala.
[edit - uporabi tag "st.koda" - vsc]
  • spremenil: Vesoljc ()
Senitel ::
Samo zamenjaš sampler z sampler3D in namesto tex2D uporabiš tex3D (in seveda popraviš koorinate iz float2 v float3)...
Samo zakaj se mi zdi, da ti samo ne dobiš ven tistega gar pričakuješ? In ker ne vem kaj pričakuješ... :D
spelic ::
Že deluje, napaka je bila ko sem kreiral texturo sem kreiral texturo3d namesto samo texture.
Texture3d xColoredTexture; Texture3d sploh ne bostaja !!!!
Hvala za pomoč.
[DirectX] Problem s teksturami
Oddelek: Programiranje
61023 (921) Senitel
tekstura [c++ opengl]
91245 (1030) matej94
[C# HLSL] osnovna uporaba pixel shaderja
51345 (1267) Senitel
GeForce4 čipi bodo zamudili
132927 (2927) franci
O Truform-u
52399 (2399) Radiant
