Forum » Programiranje » C#,HLSL, 3D texture
C#,HLSL, 3D texture
spelic ::
Pozdravljeni
A ima kdo kakšen primer kako v C# ustvariti 3D texturo in jo prenesti v shader kot spremenljivko sampler3d, tako da lahko izvajamo 3d mapiranje po texturi z ukazom tex3d.
Ali pa mogoče kakeršen koli primer v c# in 3d texturami, kako jih generiramo in prikažemo.
Hvala za pomoč
Hvala za pomoč
spelic ::
v c# bi naložil 256x256x256 3d texturo in jo obdeloval s shaderji.
problem je pa prenos te texture v shaderje. 2d texturo ni problem 3d pa nevem kako.
LP Denis
LP Denis
Senitel ::
Kreiraš "VolumeTexture" in ga nekako nafilaš (to si že), potem nastaviš z SetTexture teksturo na ustezen stage in jo uporabljaš v shaderjih tako kot vsako drugo teksturo (samo da imaš tu tri koordinate)...
Al rezultati niso taki kot jih pričakuješ?
spelic ::
to je primer shaderja za 2d texturo, nevem kako naj spremenim za 3d: zanima me samo sprememba za sampler3d namesto sampler.
Hvala.
[edit - uporabi tag "st.koda" - vsc]
struct VertexToPixel
float4 Position : POSITION;
float2 TexCoords : TEXCOORD0;
struct PixelToFrame
float4 Color : COLOR0;
float4x4 xViewProjection;
Texture xColoredTexture;
sampler ColoredTextureSampler = sampler_state { texture = "/ColoredTexture/ ; magfilter = LINEAR; minfilter = LINEAR; mipfilter=LINEAR; AddressU = mirror; AddressV = mirror;};
VertexToPixel SimplestVertexShader( float4 inPos : POSITION, float2 inTexCoords : TEXCOORD0)
VertexToPixel Output = (VertexToPixel)0;
Output.Position = mul(inPos, xViewProjection);
Output.TexCoords = inTexCoords;
return Output;
PixelToFrame OurFirstPixelShader(VertexToPixel PSIn)
PixelToFrame Output = (PixelToFrame)0;
Output.Color = tex2D(ColoredTextureSampler, PSIn.TexCoords);
return Output;
technique Simplest
pass Pass0
VertexShader = compile vs_1_1 SimplestVertexShader();
PixelShader = compile ps_1_1 OurFirstPixelShader();
Hvala.
- spremenil: Vesoljc ()
Senitel ::
Samo zamenjaš sampler z sampler3D in namesto tex2D uporabiš tex3D (in seveda popraviš koorinate iz float2 v float3)...
Samo zakaj se mi zdi, da ti samo ne dobiš ven tistega gar pričakuješ? In ker ne vem kaj pričakuješ...
spelic ::
Že deluje, napaka je bila ko sem kreiral texturo sem kreiral texturo3d namesto samo texture.
Texture3d xColoredTexture; Texture3d sploh ne bostaja !!!!
Hvala za pomoč.
Hvala za pomoč.
| » | [DirectX] Problem s teksturamiOddelek: Programiranje | 1023 (921) | Senitel |
| » | tekstura [c++ opengl]Oddelek: Programiranje | 1245 (1030) | matej94 |
| » | [C# HLSL] osnovna uporaba pixel shaderjaOddelek: Programiranje | 1344 (1266) | Senitel |
| » | GeForce4 čipi bodo zamudiliOddelek: Novice / Grafične kartice | 2927 (2927) | franci |
| » | O Truform-uOddelek: Novice / Grafične kartice | 2399 (2399) | Radiant |
