Forum » Pomoč in nasveti » težave z reset cmos (pravi jumper) pomoč prosim
the_game ::
no imam težavo in nevem kateri jumper je pravi za reset biosa
imam plato shuttle mv43v spodaj na sliki
http://shrani.si/?mv43vv73oy74.jpg][img...
- spremenil: the_game ()
amigo_no1 ::
Odstrani baterijco za minuto (spodaj levo).
Drugače pa RTFM !
Drugače pa RTFM !
- spremenilo: amigo_no1 ()
MaX ::
Pravi jumper je skoraj vedno tisti, kateri, kateri je najbližje baterije. Poglej zraven jumperja, običajno kaj piše zraven.
StratOS ::
RTFM, mislim da je to najboljša informacija
Preglej jumper Clear CMOS JP-1 stran 11 pdf-ja.
Za Clear CMOS si preglej stran 28.
Na hitro :
Na hitro :
Clear CMOS Setting (JP1) JP1 is used to clear CMOS data. Clearing CMOS will result in the permanently erasing previous system configuration settings and the restoring original (factory- set) system settings. Pin 1-2 (Default) Pin 2-3 (Clear CMOS) Step 1. Turn off the system power (PC-> Off). Step 2. Remove ATX Power cable from ATX Power connector. Step 3. Remove jumper cap from JBAT1 pins 1-2. Step 4. Place the jumper cap on JBAT1 pin 2-3 for a few seconds. Step 5. Return the jumper cap to pin 1-2. Step 6. Plug ATX Power cable into ATX Power connector. Step 7. Turn on the system power (PC-> On).
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
| » | Test matičnih ploŠč - kje so clr cmos zobciOddelek: Strojna oprema | 4649 (4352) | Siddh |
| » | računalnik se ne bootaOddelek: Strojna oprema | 1616 (1515) | IvoJan |
| » | Dva računalnika na izbiroOddelek: Kaj kupiti | 1763 (1606) | opeter |
| » | Reset biosa na HpOddelek: Strojna oprema | 2469 (2296) | RiNC |
| » | "flashanje" BIOS-ovOddelek: Pomoč in nasveti | 2347 (1922) | cultko |
