PHPLinks problm
PHPLinks problm
flasha ::
No imam en problem in sicer ko hočem na server namesti to PHPLinks gre vse lepo in prav pol pa naredim še bazo ampak zdaj pa mi ko odprem stran javi napako (nevem kaj naj v bazo vzstavim, cn probo že vse k je z .sql končnico not vzstavit) ima kdo izkušnje s tem??? bi mi lahk pomago
LP Nejc
Tody ::
takoj ko zvemo kak je error ti bomo pomagal... z sql končnico ?...
flasha ::
Warning: mysql_fetch_row(): supplied argument is not a valid MySQL result resource in /home/www/povezave.freehostia.com/include/session.php on line 31
Warning: session_start(): Cannot send session cookie - headers already sent by (output started at /home/www/povezave.freehostia.com/include/session.php:31) in /home/www/povezave.freehostia.com/index.php on line 11
Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /home/www/povezave.freehostia.com/include/session.php:31) in /home/www/povezave.freehostia.com/index.php on line 11
Warning: main(include/lang/.php): failed to open stream: No such file or directory in /home/www/povezave.freehostia.com/index.php on line 15
Warning: main(): Failed opening 'include/lang/.php' for inclusion (include_path='.:/usr/local/lib/php') in /home/www/povezave.freehostia.com/index.php on line 15
Warning: main(themes//tables.php): failed to open stream: No such file or directory in /home/www/povezave.freehostia.com/index.php on line 19
Warning: main(): Failed opening 'themes//tables.php' for inclusion (include_path='.:/usr/local/lib/php') in /home/www/povezave.freehostia.com/index.php on line 19
aja še link http://povezave.freehostia.com/
Alpheus ::
očitno ti ene datoteke manjkajo, med drugim je pri queryju uporabil nekaj kar ni SQL connection, wild guess: ampak preveri če si dobro ime baze vpisal (zadnji error).
VI VERI VENIVERSUM VIVUS VICI.
zen-cart: slovenski prevod / moneta
Oddelek: Izdelava spletišč
144407 (3857) mrezna
Obvestilo o vsebini druge strani
71476 (1254) sverde21
Web control panel
111897 (1610) DC-
mldonkey webgui
Oddelek: Omrežja in internet
51181 (1112) asgard2.0
EZ portal problem!
91779 (1699) roli
