POMOČ - ntdlr.exe - Troj/Feutel-CH Trojan
mirando ::
Alo mojstri,
Imam težave z zgoraj navedenim virusom/črvom?!
Ima kdo kakšne izkušnje z odstranjevanjem, ali obstaja kak dober removal tool?!
Očitno se nahaj v nekem startupu v registry-u!!!!
AVG antiviru ga redno zaznava....?!
Prosim za pomoč - hvala
M.
detroit ::
mislim da tega fajla ne mores kr zbrisat oz razkuzit (kar pomeni v velik primerih lih brisanje) zato si dob copy tega fajla pa ga v safe modu deletej ce se da ce ne pa z eno systemsko disketo zazen comp (win98 ftw:) in bris pa posnam tanovga ofc seveda se lahk pojavijo problemi z updatanimi winsi (lahk da je tud ta fajl updatan bog ve)
Skero
mirando ::
pa od kod se kreira ta file....?!
oz. keri proces ga zaganja???
amigo_no1 ::
Napiši ntdlr.exe v google in se čudi :D
http://www.sophos.com/security/analyses...
mirando ::
ja saj...klasični worm....sem že gledal!
nikjer pa ni natančnega postopko odstranjevanja...?! :(
mirando ::
rešeno!
ntdlr.exe sem umaknil iz zagonskih procesov!
v registry-u še najbrž tiči kak gremlin; ampak dokler se ne zgodi vse deluje OK....
amigo_no1 ::
Klikni na link ki sem ga dal
Lepo piše zavitku Advanced
This section contains the description and advanced technical information
Troj/Feutel-CH is a Trojan for the Windows platform.
Troj/Feutel-CH includes functionality to access the internet and communicate with a remote server via HTTP.
When first run Troj/Feutel-CH copies itself to Windows\ntdlr.exe and creates the following files:
Windows\ntdlr.dll
Windows\ntdlr_Hook.DLL
The file ntdlr.dll is detected as Troj/Feutel-P.
The file ntdlr.exe is registered as a new system driver service named "Windows Internet Server", with a display name of "Windows Internet Server" and a startup type of automatic, so that it is started automatically during system startup. Registry entries are created under:
HKLM\SYSTEM\CurrentControlSet\Services\Windows Internet Server\
Troj/Feutel-CH changes settings for Microsoft Internet Explorer by modifying values under:
HKCU\Software\Microsoft\Internet Explorer\Main\
problem z odpiranjem strani v IE
Oddelek: Omrežja in internet
252457 (2272) bbf
Regedit in brisanje ključa
114912 (4703) Silvano
Dual boot Vista in XP problem.
Oddelek: Operacijski sistemi
51522 (1392) matjaz23
zajedalski spyware
213279 (2946) hunter01
Par problemov z XPji
343099 (2345) Mercier
