Forum » Programska oprema » SP1 za OfficeXP Slo
SP1 za OfficeXP Slo
matjaz000 ::
Iz Microsoftove strani sem downloadov Service Pack1 za OfficeXP (varnost). Jaz imam instalirano slovensko verzijo. Ko sem ga pognal je javil da ne najde instaliranega Offica.
Ali je to zato ker imam slovenski OfficeXP in kako bi lahko resil ta problem?
berni ::
meni isto javi za ang verzijo
"the expected version of the product was not found on your system"
menda obstaja patch ampak ga ne najdem
Mercier ::
SYMPTOMS
When you apply Microsoft Office XP Service Pack 1 (SP-1), you may receive an error message similar to one of the following:
Error 1328. Error applying patch to file C:Program FilesMicrosoft OfficeOffice10Msaccess.exe. It has probably been updated by other means, and can no longer be modified by this patch. For more information contact your patch vendor.
NOTE : The Office program that appears in the error message may be different from Msaccess.exe.
-or-
The expected version of the product was not found on your system.
CAUSE
This error message can occur if the following conditions are both true:
You originally installed an unreleased version of Microsoft Office XP.
-and-
You downloaded and installed the Microsoft Office XP Service Pack 1 (SP-1) update.
To determine whether your version of Office XP is an unreleased version, follow these steps to view the ProductVersion property of the Setup.ini file:
Using Windows Explorer, browse to your CD-ROM drive.
Insert your Office XP CD-ROM, and then locate the following folder on the CD:
drive FilesSetup
Right-click the Setup.ini file, and then click Open to view the contents in Notepad.
Look for the section named "[Product]" and the line that begins with "ProductVersion".
The version number that appears after "ProductVersion" must exactly match the version number in the following list, in order for the SP-1 update to install. Check the version number that corresponds to your language version of Office.
Language Release (RTM) Version
Arabic 10.0.2701.01
Chinese - Simplified 10.0.2701.04
Chinese - Traditional 10.0.2701.04
Chinese - Hong Kong 10.0.2701.04
Croatian 10.0.2627.19
Czech 10.0.2627.11
Danish 10.0.2627.12
Dutch 10.0.2627.11
English 10.0.2627.01
English - Academic Edition 10.0.2627.01
Finnish 10.0.2627.12
French 10.0.2627.5
German 10.0.2701.01
Greek 10.0.2627.19
Hebrew 10.0.2701.10
Hungarian 10.0.2627.14
Italian 10.0.2627.3
Japanese 10.0.2701.04
Korean 10.0.2701.05
Norwegian 10.0.2627.8
Polish 10.0.2627.14
Portuguese - Brazil 10.0.2627.7
Portuguese - Portugal 10.0.2627.18
Romanian 10.0.2627.19
Russian 10.0.2627.15
Slovak 10.0.2627.16
Slovene 10.0.2627.19
Spanish 10.0.2627.4
Swedish 10.0.2627.7
Thai 10.0.2701.14
Turkish 10.0.2627.15
For additional information about versions of Office XP, click the article number below to view the article in the Microsoft Knowledge Base:
Q305095 OFFXP: History of Office XP Updates
RESOLUTION
To resolve this problem and install SP-1, you must purchase
a retail edition of Microsoft Office XP (showing an Office Hologram). Only a retail version of Office XP can be updated. Beta or unreleased versions cannot be updated to SP-1.
MORE INFORMATION
Office client updates use a binary method to update a file. This means that specific parts of a file are updated, instead of the entire file being replaced. As a result, an Office program file that is not a retail version cannot be updated by using the SP-1 client update, because the unreleased file is not the one that a client update is designed to find. This causes the update to fail.
(Q315152) od tu
-or-
CAUSE
-and-
drive FilesSetup
Arabic 10.0.2701.01
Czech 10.0.2627.11
Danish 10.0.2627.12
Dutch 10.0.2627.11
French 10.0.2627.5
German 10.0.2701.01
Greek 10.0.2627.19
Hebrew 10.0.2701.10
Italian 10.0.2627.3
Korean 10.0.2701.05
Polish 10.0.2627.14
Slovak 10.0.2627.16
Spanish 10.0.2627.4
Swedish 10.0.2627.7
Thai 10.0.2701.14
RESOLUTION
MORE INFORMATION
(Q315152) od tu
- spremenil: Mercier ()
| » | dual boot xp/ubuntuOddelek: Operacijski sistemi | 2287 (2168) | misek |
| » | Težave z računalnikomOddelek: Pomoč in nasveti | 2513 (2438) | mojsterleo |
| » | Office XP SP1 Update tezaveOddelek: Programska oprema | 2041 (1873) | Blisk |
| » | Norveška: don't cry for me, MicrosoftOddelek: Novice / Brskalniki | 3508 (3508) | andrej |
| » | SP1 za Office XP ang ??Oddelek: Programska oprema | 1472 (1315) | ABX |
