Forum » Operacijski sistemi » Kubutnu Problem
Kubutnu Problem
DOOM_er ::
Jah ne morem v root načinu odpret konquerorja, sem poskusil sudo konqueror pa mi nabije tole
fora je u tem da ne morem source.list fajla spremenit ker niam pravic
X Error: BadDevice, invalid or uninitialized input device 168
Major opcode: 145
Minor opcode: 3
Resource id: 0x0
Failed to open device
Major opcode: 145
Minor opcode: 3
Resource id: 0x0
Link points to "/tmp/ksocket-root"
Xlib: connection to ":0.0" refused by server
Xlib: No protocol specified
kdeinit: Can't connect to the X Server.
kdeinit: Might not terminate at end of session.
Link points to "/tmp/kde-root"
kded: cannot connect to X server :0.0
DCOP aborting call from 'anonymous-5203' to 'kded'
kded: ERROR: Communication problem with kded, it probably crashed.
kdeinit: Shutting down running client.
It looks like dcopserver is already running. If you are sure
that it is not already running, remove /root/.DCOPserver_denis-desktop__0
and start dcopserver again.
kded: ERROR: KUniqueApplication: Registering failed!
kio (KSycoca): ERROR: No database available!
KCrash: Application 'konqueror' crashing...
Warning: connect() failed: : No such file or directory
KCrash cannot reach kdeinit, launching directly.
drkonqi: cannot connect to X server :0.0
DOOM_er ::
spet mam ta problem kva nej nardim... ker dobivam živčnga
| » | Pomoč pri prehodu na linux (strani: 1 2 3 4 … 17 18 19 20 )Oddelek: Operacijski sistemi | 51438 (28740) | Anteus |
| » | Zaganjanje grafičnega programa na namizju trenutno prijavljenega lokalnega uporabnikaOddelek: Operacijski sistemi | 1286 (1147) | b |
| » | Skripte (strani: 1 2 )Oddelek: Programiranje | 10368 (8231) | Microsoft |
| » | problem prijavljanja v accountOddelek: Operacijski sistemi | 1814 (1672) | ql000 |
| » | Kako uninštalirat programe v linuxu?Oddelek: Operacijski sistemi | 1176 (1137) | CCfly |
