MATSONIC plate
MATSONIC plate
AnZo ::
MATSONIC MB MS 8127C+VIAKT-133
PROCESSOR
Supports AMDTM AthlonTM /DuronTM (K7)
Socket A processor (256K/64K 2nd cache on
die)
Supports 500MHz ~ 1.2GHz and faster
CHIPSET
VIA Apollo KT133 (VT8363/686A) two chip
AGPset
Supports 200MHz Front Side Bus
MEMORY
Three 168-pin SDRAM DIMM sockets
support up to 768MB
Supports PC-100 /PC-133 /VC-133 SDRAM
Graphics Adapter Slot
Supports AGP 4x mode
Two Ultra DMA 33/66 IDE Ports
Two independent channels for four IDE
devices
Supports up to PIO mode 4 and Ultra DMA
33/66
SYSTEM BIOS
2MB Flash Rom on board, provides complete
Advances Configuration Power Interface
(ACPI) and Legacy PMU;Ultra DMA 66
Fully compliant to PC'97 and PC'98
Spec
BUILT IN AC97 PCI AUDIO
Supports built-in AC97 Digital Audio.
Dual full-duplex Direct Sound channels.
H/W Sound Blaster Pro DOS Legacy compatibility.
FM Synthesis for legacy compatibility.
Supports game or MIDI port.
I/O INTERFACE
PS/2 Mini-DIN mouse & keyboard ports
Two USB ports
One 25-pin female printer port
Two serial port
Audio I/O: LINE-Outx1 , LINE-Inx1, MIC JACK x1
One game port
On Board Ultra I/O Chip
Two RS-232 serial ports (16550 UART compatible)
One parallel printer port (SPP/EPP/ECP mode)
One FDD port (Supports LS120, 3 mode,
1.2/1.44/2.88 MB FDD
Provides IrDA port with optional cable for
transceiver
OTHER
Supports multiple selectable sets of system and
PCI clock speeds inside the BIOS directly, allowing
for easy, no-jumper configuration!!
Supports on-board Hardware Monitoring and
includes Hardware Health Utility to streamline your
PC system management
Supports WOL (Wake On LAN) function to simplify
network management
Software power off control, Power-on by keyboard,
Power-on by Alarm, Modem Ring On
BUS ARCHITECTURE
1 AGP Slot
5 PCIs Slots
1 AMR Slot
FORM FACTOR AND LAYERS
Four layers, 30.5 cm x 22.0 cm
ATX form factor
Kako je kaj s temi platami (ali bi blo bolš QDI-jevo vzet) obe za isti dnar. Dajti mi pomagat čim prej!!!
Tnx
Dva računalnika na izbiro
121772 (1615) opeter
ATA disk prenos + QDI Excellent 1 plata
61700 (1650) Daedalus
Je kriva plosca za memtest errorje/nestabilnost?
Oddelek: Navijanje
82282 (2134) AtaStrumf
QDI plata
61690 (1615) Koci
Soyo????
52324 (2260) piko
