Forum » Pomoč in nasveti » opozorilo na novi virus
DrSergioDJ ::
tole sem danes dobil po emailu:
----- Original Message -----
To: Luka Glogoški-Volja
Sent: Saturday, December 15, 2001 8:47 PM
Subject: Pošilja kriko NE virus!!
PAZI spet nov virus, preglej po navodilih!! Uniči tudi trdi disk! Obvezno preveri!!!! Jaz ga imam
> URGENT VIRUS ALERT >>>
> SORRY, THIS IS NOT A PAID EMAIL - YOUR COMPUTER MOST PROBABLY HAS THIS
VIRUS!!!
> This is serious! I was warned before it took effect, and successfully
removed it! I got this virus, and chances are you have it too. It lies
dormant for 14 days, then kills your hard drive. Here's how to stop it. If
you've got it, send this to everyone in your address book. The directions
for removing it are easy.
> 1. Go to '! start' - then to 'find or search' (depending on your computer)
> 2. In the 'search for files or folders' type in sulfnbk.exe -- this is the
virus.
> 3. In the 'look in' make sure you're searching Drive C.
> 4. Hit 'search' button (or find)
> 5. If this file shows up (it's an ugly blackish that will have the name
'sulfnbk.exe') DO NOT OPEN IT
> 6. Right click on the file - go down to delete and left click.
> 7. It will ask you if you want to send it to the recycle bin, say yes.
> 8. Go to your desktop (where all your icons are) and double cli! ck on the
recycle bin.
> 9. Right click on sulfnbk.exe and delete again - or empty the bin.
> If you find it send this email to all in your book, because that's how
it's transferred.
> Gregg V. Thursten
> Webmaster@CompDough.com
> http://www.compdough.com
Kristijan-Kriko
kriko@gsm.mobitel.si
je kaj na tem? je se kdo dobu to?
VIRUS!!!
virus.
recycle bin.
it's transferred.
> Gregg V. Thursten
Kristijan-Kriko
- zaklenilo: DrSergioDJ ()
To JE ta virus - namreč ta fajl je v bistvu komponenta samih oken. V bistvu to igra na to, da bo uporabnik sledil navodilom - in sam onesposobil svoj računalnik. Tako da je obramba pred tem virusom enostavna - NE naredit tega, kar piše!
OZZY ::
Ma dej mir. Ta mejl je že nekaj časa nazaj okrog hodu.
če pobrišeš ta fajl boš v težavah.
Pa mislim, da je blo tudi na slo-techu o tem mejlu govora in tudi na nekaterih drugih straneh. Kok cajta nazaj ne vem.
Go with the flow.
| » | Uničujoči virus diskov na pohodu preberite si!Oddelek: Omrežja in internet | 2894 (1970) | demag |
| » | Virus!Oddelek: Pomoč in nasveti | 2287 (2133) | Elemen_T |
| » | Jest mam virus a?!Oddelek: Pomoč in nasveti | 2820 (2577) | Kriko |
| » | Zelo hud virus! Jutri bo hudo...Oddelek: Omrežja in internet | 2177 (1785) | element |
| » | Bug v winsih - tempiran na 1.6.2001?!Oddelek: Loža | 1489 (1253) | krucymucy |
