windows 2000 in resursi
Thunder ::
Imam en velik problem pri win 2000, zmanjka mu resursov za eno napravo pol pa ne morem poganjati tistih programov,ki so z njo povezani (audiocatalyst, nero), v eventu napiše:
Unable to read IO control information from NBT device.
Jaz osebno mislim da so napake zaradi modema, sistem ga ne sam instalira, pol ko ga pa hočem dodati sam najde(na disku) in namesti gonilnike
miranpozar ::
CAUSE
The Windows 2000 TCP/IP performance counters (Perfctrs.dll) are attempting to extract I/O control information from a network device, but no network device (network adapter, modem, and so on) is present in the system.
This problem can also occur when the performance counters attempt to extract I/O control information, but the network stack has not completed loading. This is a timing issue and does not necessarily indicate a problem.
RESOLUTION
To eliminate the event message you can safely disable the TCP/IP performance counter by following these steps:
Run the Exctrlst.exe utility from the Microsoft Windows 2000 Resource Kit.
For information about the Windows 2000 Resource Kit, go to the following Microsoft Web site:
Windows 2000 Resource Kits
Locate and then click the following extensible performance counter entry in the list:
TCPIP Perfctrs.dll
Click to clear the Performance counters enabled check box for that counter only.
Quit the utility, and then reboot the system.
After you restart the computer, the event entry should not appear. This has no effect on system performance or usability, even if networking is enabled in the future.
NOTE: You can also install Microsoft Loopback Adapter on the computer to try and resolve this issue.
STATUS
Microsoft has confirmed this to be a problem in the Microsoft Windows 2000 Professional.
Miran Požar, Portorož, www.miranpozar.com
Thunder ::
za miranpozar-a: tvoj nasvet ne pomaga, še vedno se računalnik resetira
andrej ::
right click my computer, properties, idi na advanced tab, pa startup and recovery in odznaci Automatically reboot.zdaj vec ne bo resetiral ampak bos dobil blue screen. tale napaka v event viewerju pa ni nic resnega - manjsi bugi v w2k... ko dobis moder zaslon postaj sporocilo, ki ga dobis na vrhu...
Thunder ::
napise::::::
***STOP: OX0000001E (0XC0000005,0XF0938BAA,OX00000003,OX00000039)
KMODE_RECEPTION_NOT_HANDLED
***ADDRESS F0938BAA BASE AT F0938000 DATE STAMP 30cd929b-ASPI32.SYS
Beging dumb at physical memory.
Physical memory dump complete.Contact you administrator ....
Thunder ::
napise::::::
Thunder ::
napise::::::
samodejni vklop in izklop računalnika
82880 (2704) RuskiSnajper
Windows 2000 se ob zagonu restartajo - zelo čudno obnašanje
161820 (1603) Jackass
Zakaj mi to napise???? (BSOD)
81320 (1237) Popeye
w2k boot - blue screen
Oddelek: Operacijski sistemi
81976 (1880) matevzm
blue screen
Oddelek: Programska oprema
61372 (1298) Thunder
