Excel macro - kako ga preurediti?
egomez ::
Makrojev v excelu nisem nikoli uporabljal. Včeraj pa sem hotel narediti enega, ki bi mi uvozil csv datoteko in potem opreuredi podatke iz nje. Problem se pojavi, ker ne vem, kako bi naredil, da me vpraša iz katere *.csv datoteke naj importira podatke. Za točno določeno datoteko zgleda koda makroja tako:
Sub Makro1()
With ActiveSheet.QueryTables.Add(Connection:= _
"TEXT;N:\meritve\PRINT_01.CSV", _
Destination:=Range("A1"))
.Name = "PRINT_01"
.FieldNames = True
.RowNumbers = False
.FillAdjacentFormulas = False
.PreserveFormatting = True
.RefreshOnFileOpen = False
.RefreshStyle = xlInsertDeleteCells
.SavePassword = False
.SaveData = True
.AdjustColumnWidth = True
.RefreshPeriod = 0
.TextFilePromptOnRefresh = False
.TextFilePlatform = 852
.TextFileStartRow = 3
.TextFileParseType = xlDelimited
.TextFileTextQualifier = xlTextQualifierDoubleQuote
.TextFileConsecutiveDelimiter = False
.TextFileTabDelimiter = False
.TextFileSemicolonDelimiter = False
.TextFileCommaDelimiter = True
.TextFileSpaceDelimiter = False
.TextFileColumnDataTypes = Array(1, 1, 1)
.TextFileDecimalSeparator = "."
.TextFileThousandsSeparator = "'"
.TextFileTrailingMinusNumbers = True
.Refresh BackgroundQuery:=False
End With
ActiveWindow.SmallScroll Down:=48
.tukaj sem zbrisal klobasasto kodo ker smatram, da ni ključna za rešitev problema.
ActiveWindow.ScrollRow = 1
Columns("A:A").EntireColumn.AutoFit
Range("E4").Select
End Sub
Ker se z Visual Basicom nisem nikoli ukvarjal vas prosim, če mi lahko kdo svetuje, kako spremeniti kodo, da me bo makro vprašal, katero datoteko hočem importirati.
  • spremenil: egomez ()
nevone ::
Neki tazga:
Sub Makro1()
direktorij$ = "N:\meritve"
ChDir direktorij$
filetoopen$ = Application.GetOpenFilename("CSV Files (*.csv), *.csv", , "Open file")
If filetoopen$ = "False" Then Exit Sub
"TEXT;" + filetoopen$, _
.Name = filename(filetoopen$)
.FieldNames = True
.RowNumbers = False
End Sub
Function filename(datoteka As String) As String
      cx = Len(datoteka)
      If (InStr(datoteka, "\") <> 0) Or (InStr(datoteka, "\") <> 0) Then
        While (Mid$(datoteka, cx, 1) <> "\") And (Mid$(datoteka, cx, 1) <> "/")
              cx = cx - 1
        Wend
        x1$ = Mid$(datoteka, cx + 1)
        cx = Len(x1$)
        If (InStr(x1$, ".") <> 0) Then
           While (Mid$(x1$, cx, 1) <> ".")
                 cx = cx - 1
           Wend
           filename = Mid$(x1$, 1, cx - 1)
        Else
           filename = x1$
        End If
      Else
        filename = datoteka
      End If
End Function
o+ nevone
egomez ::
Super, dela.
To je to, kar sem želel.
Hvala
rabib vba kodo za shranjevanje v bin (iz excella)
Oddelek: Programiranje
71167 (949) Silikon
null reference exception na čudnem mestu C#
51744 (1681) krho
Makroji v excelu
Oddelek: Programska oprema
62996 (2890) smetko
[Excel]Vrednost celice = ime dokumenta
315244 (4666) veteran
Excel vprašanje
81442 (1341) matic
