Conroe procesorji so med nami
11 / 42
Lord.Febo ::
Pipi, chipseta od vie še ni za conroje, DDR podpirajo vse plate na 865 chipsetu imajo pa samo AGP, da se zastopimo.
tole je od asrocka
775i65G Revision 2.0
775i65PE
ConRoe865PE
Good Guy ::
letence ne vplivajo na sam preformance conrota... ampak sama hitrost na ramih...
http://goo.gl/7ItKpU
Naj računalnik dela za vas^^
Good Guy ::
Xeon 5160 3.00 GHz, FSB1333, 4 Mo L2, socket LGA771 - 851 US dollars
Xeon 5150 2.66 GHz, FSB1333, 4 Mo L2, socket LGA771 - 690 US dollars
Xeon 5140 2.33 GHz, FSB1333, 4 Mo L2, socket LGA771 - 455 US dollars
Xeon 5130 2.00 GHz, FSB1333, 4 Mo L2, socket LGA771 - 316 US dollars
Xeon 5120 1.86 GHz, FSB1066, 4 Mo L2, socket LGA771 - 256 US dollars
Xeon 5110 1.60 GHz, FSB1066, 4 Mo L2, socket LGA771 - 209 US dollars
Core 2 Duet X6800 2.93 GHz, FSB1066, 4 Mo L2, socket LGA775 - 999 US dollars
Core 2 Duet E6700 2.66 GHz, FSB1066, 4 Mo L2, socket LGA775 - 530 US dollars
Core 2 Duet E6600 2.40 GHz, FSB1066, 4 Mo L2, socket LGA775 - 316 US dollars
Core 2 Duet E6400 2.13 GHz, FSB1066, 2 Mo L2, socket LGA775 - 241 US dollars
Core 2 Duet E6300 1.86 GHz, FSB1066, 2 Mo L2, socket LGA775 - 209 US dollars
Core 2 Duet E4200 1.60 GHz, FSB800, 2 Mo L2, socket LGA775 - Price nonavailable
Core 2 Duet T7600 2.33 GHz, FSB667, 4 Mo L2, socket mPGA479 - 637 US dollars
Core 2 Duet T7400 2.16 GHz, FSB667, 4 Mo L2, socket mPGA479 - 423 US dollars
Core 2 Duet T7200 2.00 GHz, FSB667, 4 Mo L2, socket mPGA479 - 294 US dollars
Core 2 Duet T5600 1.83 GHz, FSB667, 2 Mo L2, socket mPGA479 - 241 US dollars
Core 2 Duet T5500 1.66 GHz, FSB667, 2 Mo L2, socket mPGA479 - 209 US dollars
evo
igor0203 ::
A teli T so Yonahi oz. Meromi al kako?
Good Guy ::
ja uni k so socket 479
sinko999 ::
Cene po evpropi zdaj pa samo čakajte pocenitve, ker kolikor sem gledal te cenike sem zasledil 50-150€ nižje cene.
6300
6400
6600
6700
6800 extreme
Ni? ni ve?no !
MEDENA ::
Tole zna biti zanimivo, saj bo krepko pod 200$.....200x8 predvidevam? Naviješ na 300x8 :D Minimalno :)
Good Guy ::
mene interisira predvsem tale
nobene menjave plate ramov :D sam rpoc v tujino in to je to :D
MEDENA ::
za MSN bojo super :P
Good Guy ::
lo:\ :\ l _:ČD
Urajmal ::
Se pravi, kolikor sem spremljal vso debato, pridejo tudi plate za conroe, ki bodo imele podporo DDR-u 1 in vodilo AGP ??
PrimozR ::
igor0203 ::
Medenko, ti niti tega kompa ne izkoristiš 30%, pa že hočeš novga? :D
MEDENA ::
MSN mi štekat začel :D
Wow, da bo možen CONROE z DDR1 :D
Pa še tole ASROCK plato hvalijo...hehehe...
  • spremenil: MEDENA ()
Jaz Conroe-a na ASRocka nedam. :\
Good Guy ::
tisto z asrockovo plato je bl drek....
če boš hotu navit boš mogu pseč po bad axu al pa asusu,fdi-ju
muzičar ::
Mah tista Asrock plata ma slabše čipovje ko moja Asus-ka s 478 socket-om in P4. Tista ne bo izkoristila prav dobro Conroe. Če že tak procesor potem se mi zdi da je obavezno še PCI-e grafika in DDR2 (kmalu DDR3).
DominusSLO ::
Zakaj pa ne? Bojim se, da bo conroe edino na asrocku cenovno konkurenčen amdjevim dvojedrnikom... No mogoče pozabljam, da je za nekatere pc toliko dober, kolikor so ga plačali. :\
cpu&nb watercooled, gpu on air at the moment
Naj lepo ASRock ma svoje plate . A zdaj ko bom kupo superduper Conroea naj da dam na kr neko ASRock plato. Odg. No way. ASRock se neda merit z ASUSom ABITom,.....
  • spremenil: mtosev ()
jest10 ::
In plačaš za 5% višje navitje 50% višjo ceno...:\
Kar imej ASUS, ABIT,... ASRock bo best buy, če le ne bodo kaj konkretno zasrali.
+ to ASRock ma slabše chipsete. Mislim da na ASRocku ne bo nikoli 975.
celada ::
Kolikor jaz vem se uli cipset cist dobr kosa s nforce cipsetom pr amd-jem torej nevem zakaj se nebi dobr odrezu se pr intlu.
AndrewSmith ::
Ker uli ni za intele.
Za intele so bli vedno najboljsi
samo njihovi(intelovi) chipseti.
Tudi NF4 za intel baje ni lih ne
vem kaj...drag pa je:\
1)Venice3200/DfiUltraD/2x512UltraX-BH5/X800Xl/LG DVDRW/Seagate320Gb
2)3xTechnics1210MK5/FinalScratch/DJM600/SennheiserHD25/
2xProel15A@250rms/1xB&C 15"@750rms
celada ::
NF4 za intel ni dobr to je znano, toda atijevi chipseti so se pa precej dobro obnesli pri intelu in asrock ima pa eno plato bazirano na atijevem chipsetu in na to plato jaz ciljam.
muzičar ::
Tista Asrock plata, ki je bila omenjena malo višje ima 865 čipovje kar je občutno prestaro za tak proc -> velika večina ostalih ima VIA -> kar je še slabše od starega Intel čipovja. Če pa bo Asrock naredil plato z novejšim Intel čipovjem in ohranil cenovno ugodnost potem pa bo definitivno best buy.
GrimReaper ::
Meni ne gre v glavo kako lahko uporabijo zastarelo čipovje za nov procesor.
jest10 ::
Komot-poceni je.
Tako kot so recimo do konca furali KT400A pri socketA procesorjih.
RC14 ::
GrimReaper:
Si predstavljaš novo plato za ~15k in da se da z njo ultra noro navijat in na njej vsa nova čipovja, vse nastavitve itd..8-O Na tem svetu tega ne boš doživel, ker cene dobrih plat grozno "umetno" nabijajo v višave.
Torej plata za 15k z zastarelim čipovjem, bo dobra za 95% ljudi ,vendar še vedno zelo dobre performanse+vseeno možno rahlo navijanje, 5% ljudi pa bo kupilo ultra hitro in ultra drago plato in vse naj naj novosti na platah +najboljše performance.
Za večina uporabnikov je vseeno kakšno je čipovje, sam da dela stabilno in da je kompatibilno z recimo tem conroe procom, za navijalce pa......:\ Ne navijajo procesorjev vsi ane?
Zdej si dobil odgovor ?
Drugače pa superPi pod 10s , res svaka jim čast. Sicer mene taki programi ne zanimajo, pa vendarle zelo dober dosežek. Očitno bodo tile conroe proci res zelo dobri, sam kaj, ko bodo plate predrage, če boš hotel iz njega največ iztisnat. Upam , da bodo kakšne pametne cene teh procov in plat pri nas.
  • spremenil: RC14 ()
igor0203 ::
Pri nas boš težko najdel kako trgovino, ki bo po "pametni" ceni mela dobre plate. Mogoče kak funtech, ki je kar primerljiv s cenami v EU.
Pomoje bojo najboljše plate ponovno od Asusa, ki cene takih plat nabija v višave. Upajmo, da bojo tud DFI, Epox, ABIT,... dal kaj pametnega pa dobrega ven, da se bojo tud cene plat nekoliko spustile oz. bojo bolj dostopne. Ker 60k samo za plato je kar hud zalogaj... :|
muzičar ::
Kaj pa Gigabyte? Do zdaj se je zelo dobro obnesel. Je že kaj napovedanega?
Good Guy ::
No sam uraden izid je bil prestavljen za 4 dni(za conrota), zaradn nevem kašnim problemov...
o gigabytu je ena plata že zuni (se mi zdi sam linka ne najdem)
RC14 ::
igor0203:
Se strinjam ja, 60k za plato je res too much. Čimveč dobrih plat naj bo, pa bo konkurenca, vendar dvomim v to, po mojem bo ena ali dve plati, ki bosta vrhunski za navijanje, ter temu primerna cena. Se dobro zavedajo, da bo conroe zelo dober proc in navijalec in bodo uporabniki-navijalci tega proca pripravljeni dati veliko $$$ za dobro plato in tako lahko nabijejo cene v višave.
Plata+proc +DDR2...8-O , preveč, še posebno se ne splača , tisti ki imajo oz imamo sedaj soliden 939 sistem.
Drugače pa res svaka čast Intelu, da so skupaj spacali po doooolgem času dober proc.
Good Guy ::
rc14...
v vrhu bojo sam tri plate bad axe,dfi,in asuska (una oranžna) tko da ne vem kašni nizkih cen ne prčakovat..(iso kt pr amdju..če hočeš ocjat nujno dfiu ki pa ni tako oceni)
Če nočete dat 50k za plato ostanite na AMDju. :P
@rovtar katera oranžna ASUSka je to?
Katero plato pa meni priporočate do 55-60k? :))
Good Guy ::
GA-965P-DS3 (gigabytova plata)
  • zavaroval slike: kuglvinkl ()
OChack ::
kr solidne cene tegale conoreta v primerjavi z AMD X2 , mislm da če hoče AMD kj zaslužt nj zdej zniža cene, pol nebo dost prodav.
Kaj pol pravte da ena spodobna plata za navijanje Intla ni pocen? a je to zato ker Intel zaračunava licenco za svoj chipset al kko ze ( če se spomnmo VIA k nj bi mogla plačvat) ?
al zakaj tok drago?
Int€l inside, IDIOT Outside
AngelOfDeath ::
@igor0203
AGT se lahko kar primerja z avstrijo imajo par k dražje cene ampak garancija je tudi dalša pri nas...
edit: Slovnica
Urajmal ::
A ni bla nekje novica da je amd pocenil x2 3800+ na 34k ??
zee ::
če bi bilo to res, bi že tiktakal v moji kišti.
zee
jest10 ::
Tad3j: Sej se je pocenil. Samo morajo te cene priti do nas, to pa traja...
jest10 ::
No trenutno ima Asrock največ plat, ki podpirajo conroe:D
katere so prave
fras ::
Cene dual core procesorjev od amd-ja se bodo znižale z izidom conroe procesorja, single corce pa že zej nižajo.
Urajmal ::
Pardon bil je 3600+. Evo še link do novice.
PrimozR ::
Plate za Intel proce na 975, 955, v svojih časih tudi 945 čipsetu so drage zaradi cene samega čipa. rovtar na DFIjko ne bi takoj polagal upov, vsaj ne na SLI plato. NF 4 se slabo navija, mogoče se je z NF 5 to spremenilo. Da bi pa delalna 975 plati pa ne vem. Razen Infinity...
Zakaj dajete link na računalniške novice??? Dejte vsaj skopirat, nismo vsi tam registrirani, mater. :\
igor0203 ::
Prosim, ne smetit v tej temi o pocenitvi AMDjevih procesorjev. Dejte o tem govort v temi o AM2 procesorjih. ;)
edit: typo
  • spremenil: igor0203 ()
Lord.Febo ::
PIPI, dfi dela njihovo "vodilno" plato na osnovi Atijevega chipseta, edina plata, zaenkrat, za conroeje, ki jo dela Oscar, kar se pa tiče nf5, se pa govori da bo imel oz ima isti mem controler kot nf4, torej sranje.
Urajmal ::
AMD je za računalnikarje s plitkejšimi denarnicami pripravil novi cenovno ugodni mlinček, s katerim bo poskušal konkurirati priljubljenim procesorjem Core 2 Duo podjetja Intel. Gre za procesor z dvema sredicama Athlon 64 X2 3600+, ki podatke preračunava pri taktu 2 GHz. Količina drugonivojskega pomnilnika L2 znaša 512 kB (256 kB na procesorsko jedro). Za izmenjavo podatkov s sistemskim naborom skrbi 1.000-MHz zunanje vodilo FSB (Hypertransport). AMD je v cenovno ugodni mlinček s podnožjem Socket AM2 vgradil še dvokanalni pomnilniški krmilnik za sistemske pomnilnike vrste DDR2-800. Za nakup Athlon-a 64 X2 3600+ naj bi bilo potrebno odšteti le preračunanih 34 tisočakov.
LOL samo 34k.
Drugače kaj mislite o P5W DH Deluxe? :D :D :D :D
50k v AVT.
Primoz78 ::
Pocakat je treba do 23. oz. 27 julija...pa bomo vidli kaj bojo za ene plate do takrat zuni...
Lp Primoz
GAMING HTPC I5 2500k/ASUS P8P67/4GB CORSAIR XMS3/
VERTEX 3/ASUS 670 GTX OC/Antec TP-650 NEW/
11 / 42
[komentarji] Intel Core 2 & AMD AM2 SuperPI lestvica! (strani: 1 2 3 )
Oddelek: Navijanje
12812262 (6623) Galaxy
Plata za core 2 duo???..asus
Oddelek: Navijanje
412886 (1798) ShARk63
računalnik gre v predelavo (strani: 1 2 )
788435 (6310) aodius
core2 duo vs. Pentium D 945 vs. Athlon 64 X2 4200+ AM2
452835 (1784) bond007
Core 2 duo sistem
373388 (2186) Cinderela
