Forum » Operacijski sistemi » WinXP Internet speedup ;)
CaqKa ::
http://www.xp-erience.org/
1.Make sure your logged on as actually "Administrator". do not log on with any account that just has administrator privileges.
2. Start> run>type gpedit.msc
3. Expand the "local computer policy" branch
4. Expand the "administrative templates" branch
5. Expand the "network branch"
6. Highlight the "QoS Packet Scheduler" in left window
7. In the right window double click the "limit reservable bandwidth" setting
8. On the setting tab check the "enabled" item 9. Where it says "Bandwidth limit %" change it to read 0
Stvar dela!!! Meni je na 256kbps kablu zvisala download iz 26k/s na 27,5k/s
nsignific ::
u cem je pa fora. a si je MS rezerviru procent bandwaidtha za kksn privat spy stream al kaj? don't get it.
| » | Zapis stvari, ki so se pocele na racunalniku?Oddelek: Programska oprema | 1444 (1151) | darkolord |
| » | Iščem alternativo vudujuOddelek: Kaj kupiti | 2439 (2203) | Arthur |
| » | PHP POST methodOddelek: Omrežja in internet | 1788 (1502) | StratOS |
| » | Pomoč pri MySQL in PHP...Oddelek: Programiranje | 2376 (2244) | darh |
| » | 115 kOddelek: Omrežja in internet | 1609 (1390) | Boky |
