Forum » Strojna oprema » TS-L532A problemi
TS-L532A problemi
zmeda ::
Najprej moj NB :
LapTop Prestigio Pentium M 740 (1.7)
512 DDR Rama
80GB
Ati X700
TSSTcorp CD/DVDW TS-L532A
Ko želim zapeči DVD+R moj log zgleda takole :
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26.10.2004 17:35:34
Nero Version: 6.6.0.16
Internal Version: 6, 6, 0, 16b
(Nero Express)
Recorder: TSSTcorp CD/DVDW TS-L532A Version: TI51 - HA 1 TA 0 - 6.6.0.16
Adapter driver: atapi HA 1
Drive buffer : 2048kB
Bus Type : default (0) - ATAPI, detected: ATAPI
CD-ROM: Generic DVD-ROM Version: 1.0 - HA 2 TA 0 - 6.6.0.16
Adapter driver: d347prt HA 2
=== Scsi-Device-Map ===
DiskPeripheral : TOSHIBA MK8026GAX atapi Port 0 ID 0 DMA: On
CdRomPeripheral : TSSTcorp CD/DVDW TS-L532A atapi Port 1 ID 0 DMA: On
CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
TSSTcorp CD/DVDW TS-L532A D: CDRom0
Generic DVD-ROM E: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523632kB)
Free physical memory: 142MB (146016kB)
Memory in use : 72 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
10.11.2005
ISO compilation
19:48:42 #1 Text 0 File Isodoc.cpp, Line 6356
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 2 (Max. of 31 chars)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
19:48:43 #2 Text 0 File Reader.cpp, Line 127
Reader running
19:48:43 #3 Text 0 File Writer.cpp, Line 122
Writer TSSTcorp CD/DVDW TS-L532A running
19:48:43 #4 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
19:48:43 #5 Text 0 File Burncd.cpp, Line 3233
Turn on Disc-At-Once, using DVD media
19:48:43 #6 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2194495 (487:39.70, 4286MB)
19:48:43 #7 Text 0 File DlgWaitCD.cpp, Line 282
Write in overburning mode: NO (enabled: CD)
19:48:43 #8 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: TSSTcorp CD/DVDW TS-L532A, Media type: DVD+R
Disc Manufacturer ID: POMSC001, Media Type ID: 002, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 1
19:48:43 #9 Text 0 File DlgWaitCD.cpp, Line 448
Protocol of DlgWaitCD activities:
19:48:43 #10 Text 0 File ThreadedTransferInterface.cpp, Line 838
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2194496 (2194496) = #2194496/487:39.71
relocatable, disc pos for caching/writing not required/ required, no patch infos
- TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2194496 blocks [TSSTcorp CD/DVDW TS-L532A]
19:48:43 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [TSSTcorp CD/DVDW TS-L532A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4494327808, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2194496 | lead-out | 1 | 0x41 | 0x00
19:48:43 #12 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
19:49:15 #13 Text 0 File Burncd.cpp, Line 4120
Cache writing successful.
19:49:15 #14 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
19:49:15 #15 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 4x (5.540 KB/s)
19:49:15 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
19:49:15 #17 Text 0 File Cdrdrv.cpp, Line 8862
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: not specified (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 1 h
Media type ID: 002
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 01 50 4F 4D 53 43 - 30 30 31 30 30 32 00 38 ...POMSC001002.8
23 54 37 13 02 4A 71 02 - 90 66 16 16 0B 0B 0A 0A #T7..Jq..f......
01 1C 1E 0B 0C 12 12 01 - 00 00 00 00 00 00 00 00 ................
19:49:15 #18 Text 0 File DVDPlusRW.cpp, Line 665
Start write address at LBA 0
DVD high compatibility mode: Yes
20:04:53 #19 Text 0 File WriterStatus.cpp, Line 116
TSSTcorp CD/DVDW TS-L532A start writing Lead-Out at LBA 2194496 (217C40h), lenght 0 blocks
20:04:53 #20 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
20:05:40 #21 SCSI -1135 File Cdrdrv.cpp, Line 1180
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x039C4E00
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x51 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
20:05:40 #22 CDR -1135 File ThreadedTransferInterface.cpp, Line 1909
Write error
20:05:40 #23 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1909
Could not perform end of Disc-at-once
20:05:40 #24 SCSI -1046 File Cdrdrv.cpp, Line 1180
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x5B 0x01 0x01 0x00 0x00 0x01 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x30 0x05
20:05:40 #25 SCSI -1046 File Cdrdrv.cpp, Line 1180
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x5B 0x01 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
20:05:40 #26 Phase 127 File dlgbrnst.cpp, Line 1832
Generating DVD high compatibility borders
20:05:40 #27 Phase 129 File dlgbrnst.cpp, Line 1832
Generating DVD borders completed successfully
20:05:40 #28 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 4x (5.540 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 14.9.2005 20:17:44 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 3.8.2004 21:59:44 (Adapter driver for rec)
File 'Drivers\d347prt.sys': Ver=3.47.0.0 built by: WinDDK, size=5248 bytes, created 22.8.2004 15:31:48 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Čemgogče kdo ve kako in kaj naprej oz. nazaj se zahvaljujem :)
LP Zmeda
512 DDR Rama
80GB
Ati X700
Windows XP 5.1
IA32
WinAspi: -
(Nero Express)
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Use Inquiry : 1
10.11.2005
ISO compilation
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
Reader running
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
Media type ID: 002
Sense Code: 0x0C
Sense Qual: 0x00
Write error
Sense Code: 0x30
Sense Qual: 0x05
Sense Code: 0x30
Sense Qual: 0x05
Existing drivers:
Registry Keys:
LP Zmeda
| » | NEC ND-3540A problem...Oddelek: Pomoč in nasveti | 2784 (2075) | dean444 |
| » | LG GSA-4120B dela probleme pri pečenju DL DVD+RjevOddelek: Strojna oprema | 2195 (2004) | mtosev |
| » | tezave z virusomOddelek: Pomoč in nasveti | 1868 (1717) | royal |
| » | Težave s pekačemOddelek: Pomoč in nasveti | 2375 (2315) | boštjan |
| » | PLEXTOR BurfProof unicuje cdje - prosim pomagajte!Oddelek: Pomoč in nasveti | 2163 (1917) | krho |
