Forum » Pomoč in nasveti » Težava z TV kartico in modemom
beni ::
Pozdravljeni,
imam težavo na compu P4 2.8, 512 MB, Radeon 9250, 160GB HDD, Asus P4V8X-X.
V compu sta še WinfastTV2000XP TV tuner in dial up modem Motorola SM56k.
Ko hočem vzpostaviti povezavo na net mi :
1. računalnik zamrzne takoj ali
2. računalnik zamrzne ob povezavi.
3. povezava na net ne dela, računalnik ne zamrzne, se pa po preverjanju gesla ne skonekta. ( če vpišem št. GSM namesto ISP telefon zvoni)
Če odstranim tv kartico modem deluje BP.
Sem že vse kombinacije prestavljanja po slotih preizkusil in vedno je rezultat 1 , 2 ali 3.
Kje naj iščem težavo ?
LP Beni
LP Beni
Pojma nimam ...
Jeebs ::
Če hočeš najbolj enostaven nasvet... Zamenjaj modem. Sem imel ta modem, skoraj sem znorel zraven njega.
Press any key to continue... RESET. Didn't you say ANY key?!?!?!
beni ::
Vse sem že poskusil, celo na novo instaliral komplet vse, pa enako.
Torej bo prva stvar - modem v koš, pa drugega noter.
Hvala zaenkrat, bom jutri poskusil.
LP Beni
LP Beni
Pojma nimam ...
Spajky ::
iz moje nekajletne zlate Help zakladnice :-) :
cini se da nije stvar u driverima, jer update nije pomoggao. nasao sam enki
tekst na netu o cackanju po device manageru.....
i sad radi bez problema! :)
Evo tekst pa vidite:
For those with Motorola SM56 PCI, i have a solution that doesn't make the
modem disconnect every time your hdd is overworking or whenever you run
large programs. I had a serious problem in which every time I even put a cd
on my cdrom, un archived a file, or played a game, i got disconnected. I
couldn't work on my pc that way at all, therefore I've spent hundreds of
hours searching in webpages for something that might help, like init strings
or whatever.. none worked. Only what i did worked, and I hope this works out
for other pci-based modems, too:
Go to control panel > system > device manager
> view devices by type > system devices
under that you should find "pci bus", double click on it, go to settings and
choose
"use bios"
then go to irq steering and make sure to set it all like this:
(checked) use irq steering
(unchecked) get irq table using acpi bios
(checked) get irq table using ms specification table
(unchecked) get irq table from protected mode pcibios 2.1 call
(checked) get irq table from real mode pcibios 2.1 call
do the same in device manager > view devices by connection > system devices
> pci bus
then click ok and restart your pc
choose
"use bios"
> pci bus
| » | Ubuntu vprašanjaOddelek: Operacijski sistemi | 3383 (2132) | roksson |
| » | Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )Oddelek: Novice / Nova vsebina | 20344 (17184) | arrigo |
| » | Linux internet povezava problemOddelek: Operacijski sistemi | 2525 (2140) | dr.J |
| » | Modem motorolaOddelek: Pomoč in nasveti | 3351 (2731) | joco |
| » | Pci modem pod dos-omOddelek: Strojna oprema | 1820 (1697) | MadMax |
