Forum » Zvok in slika » HBO "zaščiten" proti snemanju
Light Bearer ::
Can I make a copy of a DVD that I made from HBO?
HBO and some other cable and Network programmers are beginning to copy-protect some of their programs on a random basis. The type of copy protection that is being used allows an initial recording (such as to a hard drive of a DVD recorder/Hard Drive combo or direct to DVD or VHS), but will not allow the initial recording to be copied again (such as making a copy from a DVD recorder hard drive to DVD or from DVD to DVD or DVD to VHS). Unfortunately there is no way around this with consumer equipment. This would be the same no matter what brand or model of DVD recorder you have. It is simply the luck of the draw as to which programs are copy-protected. You will see an increase of this practice, especially as HDTV becomes more popular and HD-DVD and Buy-ray High Definition DVD recorders reach the consumer.
For more information on HBO's copy-protection policy, check out their FAQs on Copyprotection
vir: http://hometheater.about.com/od/dvdrecorderfaqs/f/dvdrecgfaq4.htm
Hmm, kar se mene tiče si lahko filmsko/glasbena mafijska industrija nekam vtakne svojo digitalno TV ter bodoča HD-DVD in Blu-ray medija, katera sta nabasana z takimi ali drugačnimi "zaščitami". Ali kdo ve če je tudi slovenski HBO "zaščiten" z tem?
"The world is a dangerous place. Not because of the people who are evil,
but because of the people who don't do anything about it."
- Albert Einstein
- Albert Einstein
Dejancek ::
Kar se mene tiče je težko verjetno da bo to izvedljivo, vsaj dokler bo piratstvo in krekanje.
NImi pa jasno kako bojo na kabelskih lahko zaklenili signal, da nebi mogu snemat.
Nimi tudi jasno kako bi lahko prek TV-Tunerja lahko zaklenili signal da nebi upal snemati, ker ravno pri PC-jih je največ tega in karkol bi, "če" bi zaklenili, bi bil na netu že neki program, ki bi to zaščito podrl.
In HBO ni zaščiten s tem.
BigWhale ::
Ali je ze kdo odstranil digitalni watermark iz slike? Priblizno tako tezko bo odstranit copy protection iz taksnega videa.
Dejancek ::
BigWhale :
Vprašanje Light Bearer-a je to : Ali kdo ve če je tudi slovenski HBO "zaščiten" z tem?
In odgovor je dobil.
Seveda se pa resno poraja vprašanje kaj bo s tem in če bo. Če bo, bo to v rangu 5 let, za kar smo lahk veseli da bo tako. Vprašanja za prihodnost je najbolje pustit za prihodnost, saj takrat bo druga tehnologija, drugi krekerji, itd.
Dejancek ::
In za zanimivost :
For example, taking a typical 1-hour video and assuming 1 hour to store the video to the HDD, an hour to read out the video, and another hour for the embedding, it might take as long as 5-6 hours including manual processing for the entire procedure.
Nekdo bo pa res mogel imet veselje do tega dela
| » | Prodaja Blu-rayev zrasla, DVD-ji daleč spredajOddelek: Novice / Optične enote / mediji | 6786 (4271) | Mr.B |
| » | Zaklepanje dvd-jev pred nepooblaščenim kopiranjemOddelek: Pomoč in nasveti | 1409 (1193) | lonz |
| » | HD-DVD pridobiva?Oddelek: Novice / Optične enote / mediji | 7124 (5356) | Stepni Volk |
| » | Pretvorba iz DivX, XviD v DVDOddelek: Zvok in slika | 2544 (2452) | raptor1 |
| » | Windows Media player noče DVDja predvajat zaradi copyright zaščite :(Oddelek: Operacijski sistemi | 1610 (1447) | mtosev |
