Kateri prenosnik izmed nastetih je najboljsi?'
SoNgOkO ::
Pozdravljeni!
Odlocam se za nakup prenosnika, katerega izmed nastetih mi najbolj priporocate glede nato, da imajo podobno konfiguracijo, le Tronote ima DDR2 in drugacno grafiko. Notebook bo namenjen vsakdanjim opravilom (word, gledanje filmov, igranje iger ter delo s Photoshopom)
ACER TRAVELMATE 4001
- Procesor Intel Pentium M (CENTRINO) 1.5 GHz (2M L2 Cache - DOTHAN)
- 15"XGA TFT LCD (1024x768)
- ATI MOBILITY RADEON 9700
- 60 GB TRDI DISK
- CD-RW / DVD-RW DUAL podpora
- 512MB DDR spomina
- Intel® Pro/Wireless 802.11b/g
- Fast IR port
- 4xUSB 2.0
- Modem v.90
- 10/100/1000Mb Ethernet
- Tip II PCMCIA
GERICOM EGO CENTRINO
- ZASLON 15" TFT matrika
- LOČLJIVOST 1024x768
- PROCESOR Intel Pentium M Centrino 1.5GHz
- DELOVNI SPOMIN 512MB DDR
- TRDI DISK 60 GB
- DVD ZAPISOVALEC Da
- GRAFIČNA KARTICA ATI Radeon mobility 9700 128MB
- ZVOČNA KARTICA 16 bit Full Duplex
- MODEM 56 kb/ps
- MREŽNA KARTICA 10/100, Wirelles 2100 3B Mini
- VMESNIKI PCMCIA Type II, TV-out, 3xUSB, FireWire IEE 1394, Paralelni port, čitalec spominskih kartic 4v1
- BATERIJA Smart Li-Ion
- DIMENZIJE 32x330x280 mm
- TEŽA 2.6 kg
Prenosnik PCplus Vario SGP15
- Mobile Intel® Centrino™ tehnologija:
- Mobile Intel® Pentium® M Procesor
- Intel Wireless LAN 802.11b/g
- Intel Pentium M 1.5GHz procesor
- 15.1'' TFT LCD zaslon
- Pomnilnik 512MB
- Trdi disk 60GB 4200 2,5"
- Optični pogon DVD–R/–RW
- ATI RADEON Mobililty 9700 128MB
- Integrirana AC'97 (Realtek ALC655) zvočna kartica
- LAN 10/100, Intel PRO/Wireless 2100/2100A LAN, modem V56k
- 3xUSB 2.0, parallel, VGA–Out, S–Video (TV–Out), Firewire, Mic–in, - - - SPDIF, Line–out, 1x PCMCIA (tip II–CardBus)
- Čitalec kartic 4–v–1 (MS, MMC, SMC in SD)
- 8–cell Li–ion (4400 mAh) baterija
- 4 EASY Launch tipke (Internet, E–Mail, WLAN, osebne nastavitve)
- 2,6 kg
Tronote M85 CXD
- Intel® 915PM + ICH6
- Intel® Pentium® M Processor 1,73 GHz / 533 / 2MB
- 512MB DDR2
- 3D stereo enhanced sound system
- Virtual 7.1-channel audio output
- Sound-Blaster PROTM Compatible
- S/PDIF Digital output (7.1 CH)
- 2x Built-in Speakers
- SRS (Sound Retrieval System® ) / WOW 3D sound technology
- 15.0" XGA+ TFT (1024x768)
- ATi M26 (X700) 128Mb DDR
- Embedded 3-in-1 Card Reader (MS/SD/MMC)
- 1 x Tip II PCMCIA
- 60GB / 5400rpm
- Infrared Transfer : 115.2Kbps SIR/4Mbps FIR, IrDA 1.1 compliant
- 10/100/1000BASE-T Fast Ethernet
- V.90/56K Azalia Modem (V.92 compliant)
- Wireless LAN 802.11b/g
- 4x USB 2.0 ports
- 1x Mini IEEE1394a port
- 1x Infrared File Transfer port
- 1x Parallel port (LPT1), supporting ECP/EPP
- 1x External CRT monitor port
- 1x TV-out port
- 3,1 Kg
Zako ::
Mene isto zanima ta laptop-> Tronote M85 CXD, saj za svojo ceno (260k) ponuja res odlicn opremo. Sem že videl tronote v akciji tako, da je res dober laptop. Ni šminka kot HP, je pa čist ql.
ti javim ko bom ga testiral.
Zako je zakon!!!
mzidy ::
HP šminka?!
TroNote je potem jajca:\
Zako ::
ta "šminka" jwe misšljena kot to, da pač HP je bolj fino oblikovnan šproti tem tronotom.
V bistvu pa za domačo rabo in za fax je to čist ok.
Zako je zakon!!!
Zheegec ::
Haha, 15" monitor pa 3.1Kg - pač Tronote.
Anyway, Tronote se izogibaj, pa po možnosti Gericoma tudi. PCplus je menda Asus, tko de je to OK glede ohišja.
Aja, pa glej za prenosnike z x700 če boš veliko igre igral, ker so že kar poceni, tukaj pa itaq nisi cen navedel, tako da res ne bi vedel kaj vzeti.
Janez Janša, 29.04.2014
SoNgOkO ::
Katere pa so slabe strani notesnikov kot so Tronote in Gericom?
Koliko je v praksi boljsi DDR2 od DDR in koliko je X700 boljsi od Radeona 9700??
Zheegec ::
Razlika med x700 in R9700 (x600) je kar precejšnja, seveda samo za igre pa 3D programe, za ostalo je itaq vseeno :D
Razlika v praksi med DDR2 in DDR1 je, da je SODIMM DDR2 malo dražji, pa DDR2 se manj greje.
Kar se pa prvega vprašanja tiče - idi v Comtron (recimo v BTC nasproty Baby centra) pa poglej prenosnik (ohišje, tipkovnica, teža), potem pa še kakšnega HPja... pa boš videl 0:)
SoNgOkO ::
Alien na zalost nisem iz okolice LJ tako, da ogled odpade. Razlika v ceni med notesniki je zanemarljiva oz Tronote je od ostalih drazji za 4.000SIT.
Grafika v prenosniku???
214795 (4215) M@73Y
Nakup prenosnika...?
51678 (1597) Zheegec
Težava z nakupom prenosnika!
182843 (2297) samo112
Kupujem prenosnik...
142344 (1953) JIM22
Kateri PRENOSNIK kupiti ?
223326 (2859) Arthur
