Forum » Kaj kupiti » Nakup prenosnika...?
Odhinn ::
Pozdrav!
Sem pred nakupom prenosnika!toraj rabim nasvet komentar..bilo kaj..Rabim ga predvsem za igre (6mesecev tujina-Kosovo),toraj takega da bojo nove igre delovale brezhibno (F.E.A.R ; Battlefield2 ;Brothers in Arms: Road to Hill 30)..Če mi lahko kdo pove, na kaj moram gleat pred nakupom compa, da bo to špilalo?ali je to grafična (kera?) itd.. ALi se splača nakup AMD Turiona?..Kako se pri igrah pozna WIDESCREEN..se da igrat normalno?
imam pa v mislih nekaj takih compov:
-ACER Aspire
5024WLMi AMD Turion ml-34
1,8Ghz (35W),
1024MB DDR,
15,4" Display 100GB Festplatte,
DVD+/-RW,
ATI X700 128MB,
Sound onboard,
WLAN, Modem,
LAN 10/100/1000
..BIRG = 1300EU>
-ACER Aspire
1692WLMi Intel® Centrino™ 1,73GHz
512MB DDR,
16:10 15,4"WXG 80GB Festplatte,
DVD-Dual Double Layer
ATI X700 128MB
4-in 1 Card Reader Sound onboard,
WLAN, LAN, Modem, Fast Infrarot
..BIRG = 1200EU>
-Gericom Exellent 1,7
Zaslon 15.4'' (WXGA 1280X800)
Procesor Intel Pentium M 1.7GHz (Centrino)
Pomnilnik DDR 512MB
Trdi disk 60GB
Optična enota DVD+/–RW (Dual)
Grafična kartica ATI RADEON Mobility 9700 256MB
Zvočna kartica integrirana AC'97 (VIA VT1612A)
Mrežna oprema LAN 10/100, intel PRO/WLAN 2200 b/g
Modem V56k V.90/92
Priključki: 3xUSB 2.0, VGA–Out, S–Video (TV–Out), Firewire, Mic–in, SPDIF, Line–out, 1x PCMCIA (tip II–CardBus), Multimedia–in
Čitalec kartic 4–v–1 (MS, MMC, SMC in SD)
Baterija 6–cel Li–ion (4400mA)
Dodatno: 2 EASY Launch tipki (Internet, E–Mail)
Teža 3 kg
GARANCIJA 2 leti
..TEAL = 290k>
- TroNote M85 CXD PentiumM 1.73GHz 512DDR2
60GB, FSB533 15'',DVD +/- 8x RW zapisovalnik Ethernet 10/100/1000TX, 15 ...
Spletna trgovina: 254.701,61 SIT
Hvala Za pomoč in odgovore!
-ACER Aspire
1,8Ghz (35W),
1024MB DDR,
DVD+/-RW,
ATI X700 128MB,
Sound onboard,
WLAN, Modem,
LAN 10/100/1000
..BIRG = 1300EU>
-ACER Aspire
512MB DDR,
ATI X700 128MB
..BIRG = 1200EU>
Pomnilnik DDR 512MB
Trdi disk 60GB
Modem V56k V.90/92
Teža 3 kg
GARANCIJA 2 leti
..TEAL = 290k>
Oath--Bound To Odhinn
Ledenko@64 ::
Pozdravljen!
-glede iger je vsak od teh našteti primeren, malenkost zaostaja gericom z 9700 radeonom (v resnici ~9600pro).
-ene igre imajo podporo za wide screen monitorje druge ne (pri tistih, ki nimajo se pač slika malenkost raztegne, da se pa vpisati resolucije v neke .ini file kjer je napisana resolucija za igranje) za mojega 17" wide screan imam vsako igro poriktano
-glede turiona je pa tak, v bistvu je to athlon 64 z manjšo porabo energije (35W). Mislim, da je z centrinijem 1.73 nekako primerljiv oz. skoraj enak po hitrosti, vendar centrino še malenkost manj troši (okrog 21W)
-če bi jaz izbiral bi vzel tega z TURIONOM, ker ima že 1g rama in 1000 mbit mrežno kartico in 100giga diska
Lep pozdrav
Lep pozdrav
.::..::.@Mac.::..::.
billy ::
Glede na vse te igre, se mi zdi da te "stare" grafe ne bodo dovolj. Kar pomeni, da ti edino preostne laptop z 6800 grafiko ki pa niti približno ni poceni.
billy ::
Grafična je "kar" solidna, ampak to je stara grafična. V redni prodajo 9700 sploh ni več.
Drugače pa primerjaj kakšno desktop mašino z isto grafično, kakšnega P4 3.2Ghz, pa boš videl približno kakšen performance je.
V glavnem...za najnovejše igre igrat z vsemi "detajli" na full laptopa pod 500k ne boste našli. Kdo misli igrat igre na laptopih in še to celo najnovejše, naj rajši kupi za tak dnar namiznega pa 3 10 let stare avte ;)
Zheegec ::
Jaz bi se odličil za Acerja 5024WLMI. V Slo je 350K (BOF, BB, pa še kje??), ima odber monitor (bolj subjektivno, moraš sam videti), pa še wide je, kar je fino (novejši špili itaq podpirajo te resolucije, vsaj večinoma), dobra mašinica za primerno ceno, zaenkrat še ni bilo nobenih težav.
Janez Janša, 29.04.2014
| » | Compaq Presario V4276EAOddelek: Kaj kupiti | 1925 (1885) | oniy69 |
| » | Ker prenosnik od teh dveh naj izberemOddelek: Kaj kupiti | 3572 (3322) | kmhslo |
| » | Izbira prenosnikaOddelek: Kaj kupiti | 2092 (1786) | cingis |
| » | Kako bi se obnesu ta prenosnik?Oddelek: Kaj kupiti | 3048 (2460) | samo112 |
| » | Kje kupiti prenosnika in katerega:)???!!!??Oddelek: Kaj kupiti | 2558 (2296) | mtosev |
