RAM
RAM
mikkenni ::
je to dobra stvarca ka nakup?
http://www.bolha.com/oglas1232057
to so pa karakteristike plate moje, (če bi pasal ta RAM zraven)
Processor
1. Universal socket 370 for Intel® FC-PGA/FC-PGA2 Pentium®III (CopperMine / Tualatin) or other compatible processors
2. Supports Auto/66/100/133 MHz FSB (Front Side Bus)
Chipset
1. Intel® 815EP AGPset
2. iTE I8712F super I/O and health chip
3. Realtek ALC201A audio chip
Memory
1. Supports up to 512 MB SDRAM memory
2. 3 DIMMs 168-pin sockets
3. Supports 32/64/128/256/512 MB SDRAM modules
Expansion Slots
1. 1 x AGP slot supports 2X/4X mode & AGP 2.0 compliant
2. 5 x PCI slots support 33MHz & PCI 2.2 compliant
3. 1 x CNR (Communications and Network Riser) slot
I/O
1. 2 x UDMA ATA 66/100 IDE ports on board
2. 1 x FDD, 2 x COM, 1 x LPT, PS/2 Keyboard, PS/2 Mouse on board
3. 2 x USB ports on board, 2 x USB ports by cable (cable optional)
4. IrDA TX / RX header
Power
1. ATX power connector
2. Power-on by LAN, RTC, Modem & Switch
3. Power-off by Windows® 95/98/ME/2000/NT/XP shut down & Switch
Form Factor
1. ATX form factor, 4 layer PCB (30.5 x 19.1 cm)
H/W Monitoring
1. Auto speed down and alarm when CPU overheat or fan failure (OS independent & driverless)
2. 3 fan power & speed detection connectors
3. System health status detect & report by BIOS
4. H/W detect & report power-in voltage, CPU voltage and CMOS battery status
BIOS
1. 2Mbit flash ROM BIOS, enhanced ACPI feature for PC98/Win98/Win2000/WinME compliance, Green, PnP, DMI, INT13 (>8.4GB) & Anti-Virus functions
2. IDE#1~#4, SCSI, LS120, ZIP & CD-ROM bootable
3. Auto-detect & report system health status
4. Supports @BIOS™ Live Update
  • spremenilo: mikkenni ()
ja me prov zanima kako bos spravu ram z 184 pini v slot z 168 pini.
no sej ce bi se fajn potrudu bi ti mogoce ratal.:\
mikkenni ::
kje pa to vids kok pinov je?
no kater RAM bi mi potle pasal v plato? (cenovno najbolj ugoden)
Dva računalnika na izbiro
121763 (1606) opeter
Qdi kinetiz 7b + Athlon 1800+
62319 (2126) Blinder
Je ta konfig OK? Hitra pomoč potrebna
82324 (2129) Area_51
QDI plata
61677 (1602) Koci
Soyo????
52313 (2249) piko
