Forum » Omrežja in internet » T-2: Informacije
T-2: Informacije
Ja, to jim pošlji, pa se naj zjasnijo.
(ali pa sam pogledaš, če sprememba spada pod omenjeno izjemo, ali pa kdo tu pogleda...)
http://bitcoinity.org/ ne gre:
|------------------------------------------------------------------------------------------| | WinMTR statistics | | Host - % | Sent | Recv | Best | Avrg | Wrst | Last | |------------------------------------------------|------|------|------|------|------|------| | OpenWrt.lan - 0 | 8 | 8 | 0 | 0 | 0 | 0 | | 93-103-0-1.gw.t-2.net - 0 | 8 | 8 | 11 | 11 | 12 | 11 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | | No response from host - 100 | 1 | 0 | 0 | 0 | 0 | 0 | |________________________________________________|______|______|______|______|______|______| WinMTR v0.92 GPL V2 by Appnor MSP - Fully Managed Hosting & Cloud Provider
- spremenil: MrStein ()
dellon ::
POzdravljeni.
rabil bi eno informacijo.
Doma imam t2 modem model: Smart COM SVL100D-LR.
Zanima me kakšen je sistem naprave modem - switch ali je že to tudi router?
broken/link ::
https://tv2go.t-2.net/
nažalost za delovanje potreben flash + ima še nekaj porodnih krčev, dela pa časovni zamik :)
- spremenil: broken/link ()
DejaVu ::
A še kdo opaža da ima T-2 težave pri TCP prometu in sicer vzpostavljanju povezav - le te imajo ogromno latenco ali pa se sploh ne vzpostavijo. In to sem opazil da se je že večkrat zgodilo za nekaj ur v zadnjem mesecu. Sem na optiki.
DejaVu ::
Kaj je s T-2? To je nenormalno no. Ne spomnim se, da bi kdaj Siol optika imela take težave. Kako si lahko to dovolijo v letu 2014? Takšne težave so se dogajale 10 let nazaj, ne pa danes.
Dami ::
Povej kaj ti ne dela pa tracert do kam, da primerjamo.
buneech ::
Rias Gremory ::
Še komu T-2 hebe?
Pri meni rata net neodziven (razen fb chata) za cca 1 minuto potem pa se stanje vrne na prvotno. To se je v zadnjem tednu zgodilo že vsaj dvakrat.
Sem iz (okolice) Ljubljane.
Han ::
Bo T-2 v kratkem (ta mesec) kaj ažuriral svoje pakete?
T3 Mega (VDSL 10/1 Mbps, TV shema S ) namreč za ceno 32,99 eur/mesec niti približno ni več konkurenčen Telemachovemu paketu SILVER za ceno 32,50 eur/mesec (16/1 Mbps, bistveno boljša TV shema).
- spremenil: Han ()
cordoba ::
Imam optiko na t2 in bi rad zamenjal operaterja, zaradi raznih dejanj. Npr podrazitve, v tem času so potiho skenslali 2 HD programa, ni slovenskih HD in športnih programov. Zanima me ali je optika vezana na t2, ali jaz lahko prikljucim amis, ali telemach itd?
OmegaBlue ::
Če imaš telekom optiko potem imaš lahko drugega ponudnika, če je pa T-2 fiber potem pa ne.
leiito ::
Lahko pa gotovo vzamem optiko pri kom drugem in T2 vrnem njihovo kramo. Sam sicer nimam težav z netom (oziroma prihaja do občasnih preknitev na tableti, ne pa na kompu, oba na wifiju, sklepam da problem ni v T2), ampak s ponudbo športa. Nedavno sem jih vprašal kaj se dogaja s ŠK3-6 in so odpisali, da se pogajajo, enako kot so mi razlagali že lani. Na prošnjo za bolj precizno informacijo so pojasnili, da že pol leta čakajo odgovor ŠK, ki so ga prosili naj jim pošljejo ponudbo. Če ŠK pol leta niti ne odgovori, očitno nima interesa dati niti ponudbe, kaj šele pogajati se, T2 pa se to zdi normalno in so pripravljeni čakati (in njihove stranke z njimi), da se morda nekoč pri ŠK kaj spremeni.
Siol & co. medtem ponujajo izbiro katerekoli tekme lige prvakov ali top evropskih lig, z opcijo različnih komentatorjev v več jezikih, vse v HD, medtem ko je prek T2 slika prenosov ŠK kakovosti kot nekoč kopije VHS, svetlobna leta od Discoveryja ipd., kjer je že SD tako dober, da komaj ločiš od HD.
leiito,
in koliko te pride osnovni paket, ki to kar omenjaš že vsebuje ?
leiito ::
leiito,
Ne vem koliko je osnovni paket, zihr je na njihovi strani, jaz za 50/10 (če se ne motim, prej sem imel 100, ampak v praksi itak ne gre čez 28/s na speed testu, 7/s pri DL + 2 tivija, paket L, če se ne motim, timeshift in dodatnih 10GB v oblaku plačujem cca €50.
leiito,
torej hočeš reči da boš cca plačeval 2x več/mesečno zaradi FUDBALA.
Dami ::
wtf??
Bakunin ::
leiito ::
Jp, prek wifi. In da, za fuzbal sem pripravljen plačevati več. Bom pač nehal jemati mamile.
leiito ::
imam wi-fi 802.11 ac (Airport Extreme), ampak ga MBP in iPad ne podpirata. Ampak tudi prej, ko sem imel še PC in prek žice, hitrost downloadanja ni nikoli presegla 7/s.
Za wifi-n je to tak kul..
tisti 150MBiten :)
tisti 150MBiten :)
- spremenil: iloveboobz ()
wanderer ::
Živjo
Lahko kdo potrdi, je t-2 pred kratkim onemogočil gledanje (neplačanih) programov preko VLC-ja? Sem na optiki, poskusil tudi z novo listo (2.8.2014).
Vse je delovalo v redu še 10 dni nazaj recimo.
broken/link ::
to je onemogočeno že cca leto ali dve. Če ti je do danes delovalo ti je bolj po sreči kot kaj drugega :)
Kaj ti pomaga tv2go ? le ta ti predvaja cca 10 % vsega kar si naročen ?
YaN-cH ::
cordoba ::
http://www.belkin.com/in/IWCatProductPa...
Od t2 sem dobil ta router. Ročno sem ga resetiral, pa zdaj ko dostopam do routarja nevem username in password. Kdo ve kakšen je factory za ta model?
Borut6 ::
Probaj brez gesla, če si ga resetiral.
Bi pa mogla bit spodaj nalepka z username in passwordom.
6151 ::
Pri T2 so očitno odgovorili na telekomovo ponudbo in povečali hitrosti interneta na vseh paketih
na primer pri T2 TERA paketu so hitrost iz 100/20 dvignili na 300/50, na žalost so na VDSL dvignili le upload (Je res tako težko ponudit 40/10 v paketu glede na to da se da naročiti tudi 60/25)
7900X3D | 32GB | 6800 | 4 TB
Glede na to da je država ta teden dala zahtevo za stečaj T-2(-ja) se ne kaj preveč sekirat...
SeMiNeSanja ::
Stečaj != likvidacija
Predlog za stečaj != stečaj
Počakat in videt kaj se bo skuhalo.....
sam so še vedno dražji od amisa. vsaj na bakru.
Kuha se to, ali po skladno z konkurenco/monopolom, smel Telekom kupiti T-2 (infrastrukturo, ljudi, in stranke), ko bo le ta v stečaju. Verjetno jih pa skrbi to, da tega nebi smel narediti. Potem je T-2, bistveno bolj zanimiva naložba vstopa tujih podjetij v svet telekomunikacije v Sloveniji. In če se izpelje ta scenarij, sem prepričan, da bi se za Telekom Slovenije, dobilo tako na prst polovico načrtovanega.........
Upam da se ne bo izcimilo nič.
6151 ::
Ja, se strinjam. Bomo verjetno naslednji mesec pri nas šli iz T2 na Amis, saj optike verjetno ne bomo videli. 30/5+TV+Stacionarni za 50€ na mesec je krepko manj od tega kar plačujemo sedaj.
roCkY ::
Od nas je centrala vidna na cca. 800 metrih. Kabla pa je prek 2000m.
Na podeželju smo res precej bogi. In tudi zato vztrajam na Telekomu. Mini HD in nenazadnje ponudba HD kanalov me drži pri njih dokler ne bo T-2 optike. Letos se je malo premaknilo...
A glede na tele "igre" s stečajem V2.0 se bojim da bodo kabli sedaj 6 let v kanalih kot so bili 6 let prazni kanali v tleh.
Na nekaj prek 2 km imam 18 MB sinhronizacije. Je pa veliko lokacij bljiže kot 1000m. Pri teh razdaljah pa VDSL2 in predvsem VDSL2b da kar konkretne pretoke.
Upam da T-2 ne bo pristal v rokah Telekoma ker potem bomo dobili monopol neglede na novega lastnika T1.
6151 ::
iloveboobz je izjavil:
pa gre sploh 30Mbit po bakru ?
Pri meni zagotovo gre, saj sem od centrale oddaljen 300m
Ne vem če bo Telekom kupil T2. Kot bodoči kupec telekoma, bi se pritožil v EU, češ da je Telekom monopolist, in to zgolj zaradi tega da bi zrušil ceno s katerim bi moral kupiti Telekom.
