Forum » Hlajenje in modifikacije » 3500+ overclocking & neznan restart
KrCbelca ::
Hi.
Čez noč sm z prime95 testiral komp. Zutri k sm pržgav ekran sm ugtovu d se je komp restartiru zarad neznanega razloga.
Preveru sm results.txt v prime95 pa piše:
In tukaj se fajl konča, brez razloga restarta. Ker je Prime95 laufal 9 ur in pol z SmalFFT je CPU vrjetn stabiln ane?
CPU voltaža: 1.650V
RAM voltaža: 2.800V
druge napetosti sm pustu kot so, ...
Zakaj se mi komp restartira, kaj nej probam, kje nej ugotovim več podatkov zakaj se je resetiru, ....
Anyone?
[Fri Sep 30 19:27:13 2005]
Self-test 8K passed!
[Fri Sep 30 22:05:41 2005]
[Fri Sep 30 22:22:01 2005]
Self-test 10K passed!
[Fri Sep 30 22:37:10 2005]
Self-test 12K passed!
[Fri Sep 30 22:53:19 2005]
Self-test 14K passed!
[Fri Sep 30 23:11:15 2005]
Self-test 16K passed!
[Fri Sep 30 23:27:23 2005]
Self-test 20K passed!
[Fri Sep 30 23:45:22 2005]
Self-test 24K passed!
[Sat Oct 01 00:00:44 2005]
Self-test 28K passed!
[Sat Oct 01 00:17:43 2005]
Self-test 32K passed!
[Sat Oct 01 00:35:39 2005]
[Sat Oct 01 00:54:43 2005]
[Sat Oct 01 01:12:49 2005]
[Sat Oct 01 01:30:49 2005]
[Sat Oct 01 01:45:59 2005]
[Sat Oct 01 02:04:22 2005]
[Sat Oct 01 02:22:31 2005]
[Sat Oct 01 02:40:07 2005]
[Sat Oct 01 02:57:50 2005]
[Sat Oct 01 03:15:49 2005]
[Sat Oct 01 03:32:50 2005]
[Sat Oct 01 03:50:38 2005]
[Sat Oct 01 04:08:12 2005]
[Sat Oct 01 04:24:48 2005]
[Sat Oct 01 04:43:20 2005]
[Sat Oct 01 05:01:10 2005]
CPU voltaža: 1.650V
RAM voltaža: 2.800V
Anyone?
C2Q Q6600, P5W DH Deluxe,6GB 800MHz Rama
GF 8600gt, 2xSataII WD 250GB, LC Power 550W Green Power
----watter in my vains----
fahrenGONE ::
Tezko je vedet za kaj se gre. Lahko je RAM error ali pa se mu je od vrocine sfuzlalo.( to je moja stokovna razlaga )
Poizkusi s SpeedFan, ce ima loge...
KrCbelca ::
od temperature dvomm. K je imu po ene 4 urah max 45°C
bolj sumim ram. Kak bi ugotovu če je res ram? K ko sm mu še 2.6 V na ramih mi je preden je pršlo v vindowse restartiralo, brez d bi kr kol navijal. Zdj pa k je 2.8 pa use normaln dela, razn to k se restartira kr enkt ponoč pa tko, ...
Al lohk dam ram na 2.9V, d se nau slučajn skuru, ...
PS: Al lohk moderator prestav temo v navijanje? k sm pomotoma dau sm.
- spremenil: KrCbelca ()
fahrenGONE ::
Daj ga skozi memtest86 za ene par ur. Ce je mozno 8 ali vec. Ta program je res zakon. Morda dobis se kaj podobnega na ultimatebootcd.com.
- spremenil: fahrenGONE ()
igor0203 ::
Ker napajalnik pa maš? Mogoče napajalnik ni več zdržu.
Drgač pa kokr ti je fahrenheit reku, stestiraj rame z memtestom, čeprav naj bi ti ta test ki si ti ga ti pognal mučil proc in ne ram...
- spremenil: igor0203 ()
KrCbelca ::
Ja, laufu sm za cpu, k sm ga navil, pa zgleda d je cpu stabiln, ... Za napajalnik d neb zdržou pa dost dvomm, ... k so linije dost stabilne, pa so mal več kokr pa naj bi bile (3.3 je 3.31) tko d dvomm d je napajalnik) mam pa LC550W Silent Giant k ma 14cm vent.
če zalaufam memtest, ga lohk u matični uklopm k mam možnost tm? Pa pol č najde error, al se restartira pa nam vedu kaki error jav al sam ugasne test pa izpiše napšako, d zutrej pl pogledam kwa je blo?
fahrenGONE ::
Mas isti napajalnik kot jaz.
Memtest ti izpise napake in potem lahko zjutraj pogledas, bp. Starta pa se z boot diskete ali CDja.
KrCbelca ::
mam lanparty nF4 tko da lohka v biosu nastavm d zažene memtest
če dam rame na 2.9, se boj obrez hlajenja kej pregreval? kolk je kej nevarna temperatura za twinmos rame?
fahrenGONE ::
Ne vem kako je s temperaturo ampak v ekstremnih primerih se vse skupaj prej sesuje kot da ti ram odpove. Ti v BIOS nastavi vse potrebno in potem samo bootas na floppy ali cd/dvd in memtest86 bo zacel delat sam od sebe.
KrCbelca ::
Ok, še en Q:
Stock je bil proc 11 x 200, ram divider je biu 1:1, tko d je imu ram frekvenco 200MHz
Zdj jest dam 10 x 265, ram divider pa ČE dam tko d je frekvenca rama 200MHz, al pol ram isto dela kokr pr stock nastavitvah al slabš?
igor0203 ::
isto ti dela. a si ti furu rame 1:1? Pa na kok si naviu proc? Ker če si mel 10 x 265 pol ni čudn da se ti je komp restartu. Ker če maš gor bh-5 čipe in 2-2-2-5 latence rabš 3.6-3.7V da bi jih na tok gonu.
Če bi mel gor kšn heatspreader ti ne bi nč škodl, vent čez se pa da tam pri. 3.1+V
fahrenGONE ::
Jep, 1:1 je sicer ok nastavitev ampak ne zdrzijo rami. Tukaj je ena uporabna stran za izracun: http://math.gogar.com/athlon64.cgi
JIM22 ::
Če si res ram furo 1:1 pol še dober da si v win pršo. Te twinmos SP so novi BH5 čipi ki rabjo velikV da delajo dober. Ti jim kar daj 3,4V pa en vent preko in testiraj z memtestom86. Na tej plati ko jo imaš ti vklopi v biosu memtest in ti bo sam začel delat, ko boš restarto. Potem ga moraš spet izklopit če hočeš v win. Tam ti bo vrgl errorje ven če bodo. Če bo prehudo se bo restarto in lahko veš da si še daleč od stabilnosti.
Digitalni marketing, nastop na spletu v naročnikovem imenu.
Vsi na FB pridružite se itVision :)
- spremenil: JIM22 ()
KrCbelca ::
Hehe, nism na 1:1 furu ramov
sam tko me zanima, d vem an :D
mam pa twinmose SP pc3500+ k sm jih pr mlacomu kupu, tko da pomoje niso bh-5 čipi - na kolk napetosti priporočate da te dam?
igor0203 ::
poglej na rame če ti piše bh-5 al maš hynixove čipe.
če so bh-5 ti taki rami zaživijo šele pri 3.2+V(250MHZ 2-2-2-5), če pa hynix pa tam od 2.7-2.9
KrCbelca ::
igor0203 ::
Pol maš hynix čipe gor... Baje da so te tud kr v redu, da grejo 250MHz 2,5-3-3-x. Te rami ne marajo visokih voltaž, zato jim dej od 2.6-.2.9V. Kok pa rabjo za določeno frekvenco pa sam ugotov
KrCbelca ::
Ok, sm zdej divider zvečov, tko d je frekvenca rama 193, proca pa 2700, pa bom še 1x laufou čez noč prime, pa bomo vidl č bo se sesul komp, če se bom probal z memtestom, čeprav mam občutek d ram matrajo velike frekvence
Javim ju3
Javim ju3
KrCbelca ::
Hehe, nebi bil jest če nebi že spet neki uprašou:
Mam 3500+ pa me zanima do kere voltaže nej grem z vodnmu hlajenjem d bo ok za 24/7. Do kolk nej bo idle/load temperatura?
igor0203 ::
hja odvisn kok rab za stabilno delovanje. Sicer kšni za 24/7 gonjo proc na 1.7V, sam osebno ne bi šel čez 1.65V
KrCbelca ::
2700 not stable, 2650 zgleda stable po 4 urah, bom vidu kak bo vnaprej, k sm frekvenco spustu, pa d vidmo č bo še zezal
KrCbelca ::
Trenutno na 2600MHz, stable.
Temperatura proca je 39°C pod 100% obremenitvijo, voltaža pa je 1.53V
Bom zdj lepo počas zvišou mal voltažo, k je točn 2600 omejitev za tako voltažo pol pa po 10MHz navijou (mn ne morm k mam divider 10)
| » | BSOD na win 7Oddelek: Pomoč in nasveti | 1936 (1830) | iloveboobz |
| » | Težave - s cpujem ?Oddelek: Pomoč in nasveti | 1601 (1549) | painfulwhite |
| » | Posodobitev računalnikaOddelek: Kaj kupiti | 2257 (1688) | igiwarcraft |
| » | AMD 2500+ & Abit NF7Oddelek: Navijanje | 2819 (2065) | Wad@ |
| » | Prime 95 in errorOddelek: Navijanje | 1625 (1435) | krucymucy |
