sprememba 'date created' za datoteko
CaqKa ::
imam mp3 player diva gem... ki mi po nevem kakem naključju predvaja datoteke po date created atributu namesto po filenameu..
torej ne date modified ampak date created.
date modified se da v total commanderu spremenit, kaj pa date created?
R33D3M33R ::
Zdi se mi da zna Evidence Eliminator spremeniti te atribute.
zile ::
Q: Why can't I change the date of a directory?
A: This is a limitation of DOS. To change the date of a file, DOS must open the file. Since you cannot open directories for reading or writing, you cannot change their dates. Since version 4.03, it's possible to change the date/time of a directory through a DOS function for long filenames. Starting with Total Commander 4.53, you can also change the timestamp of directories on Windows NT and Windows 2000, but only if you login as an administrator, because you need backup privileges to open folders for modification.
  • spremenil: zile ()
CaqKa ::
MS-DOS/cmd xcopy
Oddelek: Operacijski sistemi
111956 (1818) DeeJay
Vsftp
51735 (1642) trnvpeti
Kako v Win2k premakniti mapo Documents and Settings?
62470 (2436) Mercier
CATALYST 3.6
Oddelek: Programska oprema
168888 (8373) freejack
vkljucevanje txt datoteke v ...
Oddelek: Programiranje
131970 (1746) webblod
