Forum » Programska oprema » zonealarm in vsinit.dll
manijak13 ::
Imam en problem in sicer ko bi rad namestil požarnizid zonealarm mi javi naslednjo napako:
Validation failed for C:\\WINDOWS\TEMP\VSINIT.DLL You problaly are missing a necessary rot ceterficate.
Kaj bi lahko naredil da mi nebi javilo te napake?
L.P Jan
L.P Jan
- premaknilo iz Pomoč in nasveti: bastadu ()
StratOS ::
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
| » | missing .dllOddelek: Pomoč in nasveti | 1459 (1199) | _Denny_ |
| » | Win XP SP2Oddelek: Operacijski sistemi | 1017 (936) | iloveboobz |
| » | [VB 6] Klicanje funkcij dll-ja, napisanega v Cju.Oddelek: Programiranje | 1675 (1565) | NavadniNimda |
| » | Namestitev Apache 2.x in PHP5.xOddelek: Izdelava spletišč | 1698 (1643) | yoshi |
| » | Napaka v modulu MSHTML.dllOddelek: Operacijski sistemi | 1129 (1057) | #000000 |
