Blokiranje internet strani
Simon123 ::
Zanima me ce kdo ve kako se blokira dostop za dolocene internet strani. Ali obstaja kaj na firewallu, ali kaksen program...
Hvala
kozmos ::
najdi datoteko hosts z iskanjem, oz nahaja se v C:\WINDOWS\system32\drivers\etc
Odpri jo z beležnico in vsebina je sledeča:
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
...tukaj naprej lahko napišeš (blokiraš) poljubne spletne strani oz naslove (kot je za primer podano malo višje).
LPT
Damjan Jagar ::
Podan je samo primer za uporabo imen namesto IPjev. S čim naj bi on tukaj kaj blokiral?
http://jagar.si
kozmos ::
Tukaj piše malo več o tem, jaz sem učinkovito blokiral poljubne xxx strani...
LPT
Simon123 ::
thanks, bom probou kej zmotat.
Zakaj mi ne odpre samo ene določene strani?
Oddelek: Omrežja in internet
288437 (4477) BorutK-73
Blokiranje naslovov strani
205360 (3403) clancy
Shranjevanje v Hosts file
82503 (2441) Mendex
ne dovoli mi namestiti antivirusnega programa
134763 (4491) k4vz0024
Obstaja program ki onemogoči določeno spletno stran?
Oddelek: Programska oprema
152083 (1960) #000000
