Forum » Kaj kupiti » Kateri prenosnik?
Kateri prenosnik?
Buggy ::
Hoce slo tipkovnico...hoce loceno grafiko, hoce 32GB rama in hoce i7 ultra...
danes dobil ponudbo za nekaj podobnega (case: studentka arhitekture) 1870€ dost decent...glede na to da je v tujini tam-tam
ThinkPad P16s Gen3 U7-155H 32GB 1TB 16in WUXGA RTX 500 Ada W11P
SLO Key
1 KOS 1.538,00 22 1.538,00
Processor: Intel Core Ultra 7 155H, 16C (6P + 8E + 2LPE)/22T, P-core
1.4/4.8GHz, E- core 900MHz/3.8GHz, LPE-core
700MHz/2.5GHz 24MB
Graphics: NVIDIA RTX 500 Ada 4GB GDDR6
Chipset: Intel SoC Platform
Operating System: Windows 11 Pro
Memory: 32GB (1x 32GB) SO-DIMM DDR5-5600 Non-ECC
Memory Slots: Two DDR5 SO-DIMM slots, dual-channel capable
Max Memory: Up to 96GB DDR5-5600
Storage: 1TB SSD M.2 2280 PCIe
Display: 16" WUXGA (1920 x 1200), IPS, Anti-Glare, Touch, 45%NTSC, 300 nits
Ports: 1x USB-A (USB 5Gbps / USB 3.2 Gen 1), 1x USB-A (USB 5Gbps / USB 3.2
Gen 1) Always On, 2x USB-C (Thunderbolt 4 /
USB4 40Gbps), with USB PD 3.0 and DisplayPort 2.1, 1x HDMI 2.1, up to
4K/60Hz, 1x Headphone / microphone combo jack (3.
5mm), 1x Ethernet (RJ-45), 1x Security keyhole
Ethernet:100/1000M (RJ-45)
WLAN + Bluetooth: Intel Wi-Fi 6E AX211, 11ax 2x2 + BT5.3
WWAN: Quectel EM160R-GL, 4G LTE CAT16, M.2 card, with embedded eSIM
functionality
Audio Chip: High Definition (HD) Audio, Realtek ALC3287 codec
Speakers: Stereo speakers, 2W x2, Dolby Audio
Microphone: 2x Array
Camera: 5MP +IR with Privacy Shutter
Battery: Integrated 75Wh
Power Adapter: 135W USB-C Slim (3-pin)
Fingerprint Reader: Touch Style, Match-on-Chip, Integrated in Power Button
Security Chip: Discrete TPM 2.0 Enabled
Keyboard: Backlit, Slovenian
Case Color: Black
Case Material: Aluminium (Top), Aluminium (Bottom)
Dimensions (WxDxH): 361.5 x 248.6 x 21.13 mm
Weight: 1.82kg
Warranty: 3 year
link_up ::
no update, narocil v sredo pri BB, do danes se niso dobavili nicesar. Pa je bil kao na zalogi...
Raj za povprecneze je ta nasa dezela...vse kar je malo out of the ordinary, je pa za cakat in cakat...ker njim se ne splaca.
Od zdaj naprej perem mozgane vsakemu v familiji, ki si bo zazelel slo tipkovnice. Zadnji nakup preko nasih trgovin, naj propadejo ali pa prodajajo robo za 300e, me ne gane.
tko, rant over...se opravicujem. :)
In and Out
on18 ::
Pozdravljeni,
kupujem prenosnik za študij in predvsem za 3D-modeliranje, zato bi želel da bi delal brez večjih težav. Namen imam dali okoli 1300€.
Imate kakšna priporočila glede znamk sam se najbolj nagibam da vzamem Asus, gledal sem ta model:
https://www.mimovrste.com/asus-prenosni... , če ga ima kdo se zadovoljni?
Bi bil ta prenosnik vredu glede na ceno in nato kaj ima vgrajeno sam se najbolj ne spoznam v te zadeve zato sprašujem tukaj:)
Ter zanima me če je 16GB ram dovolj za normalno delo pri 3D-modeliranju ali bi rabil 32GB?
Rias Gremory ::
@on18
Bi vzel tudi iz tujine?
klempo ::
tole imaš v akciji v Big Bangu ... za podobno ceno 4060 grafika
https://www.bigbang.si/lenovo-loq-15arp...
on18 ::
Rias Gremory je izjavil:
@on18
Mogoče, kako pa je z garancijo?
Preko katere strani pa naj gledam?
Glej Amazon.de, computeruniverse.net. Tile pošiljajo v Slovenijo.
chucki ::
Aitek.de poglej
https://www.aitek.de/produkt/asus-tuf-g...
Tega imam jaz ze 18 mesecev. Top za taksen denar. Se ne pregreva in trotla. 3070ti je isto hitra kot 4070.
Pozdravljeni,
- spremenil: chucki ()
Rias Gremory ::
@on18
Za ponudbe poglej na geizhals.eu, za posamezne trgovine pa glej odgovor @mtoseva.
Garancijo, kolikor vem, uveljavljaš pri prodajalcu. Možno je pa tudi pri proizvajalcu. Naj kdo drug pove.
scipascapa ::
Rias Gremory ::
@scipascapa
Delaš pri uvozniku?
Delaš pri uvozniku?
scipascapa ::
scipascapa je izjavil:
https://www.shoppster.si/p/4768417
690€ če kdo rabi, ZS.
pa smo naredili posel, še kdo? ;)
A naj počakam do black Friday, da kupim prenosnik? Gledam Lunar lake in Strix point modele. Thx
Gledam tale prenosnik https://geizhals.eu/asus-expertbook-p5-...
A se dobi kaj boljšega za to ceno? Hočem, da prenosnik ima 32gb rama.
Rias Gremory ::
Si obupal nad Strix point?
- spremenilo: Rias Gremory ()
Ne še. Strix point je še dražji od Lunar lake. Še vedno razmišljam, če vzamem lunar lake ali Strix point.
Od tehnike bolj malo. Tujina je cenejša.
Je.
scipascapa ::
A je tole dober deal?
https://www.shoppster.si/p/4837548
vzameš tega preko mene, ZS
https://www.mimovrste.com/lenovo-prenos...
560EUR
- spremenil: scipascapa ()
Rias Gremory ::
Pokvarjen link.
Redorange ::
Pozdravljeni.
Imam HP 470 G9 prenosnik in bi rad večji ssd. Na strani piše da ima NVMe.
Zanima me če lahko vgradim disk SATA?
Enega od teh? A lahko tudi več kot 1TB?
Hvala.
Hvala.
- spremenil: Redorange ()
Han ::
Za ta prenosnik bo ok, lahko pa dodaš 13 eur za boljši PLUS model.
https://www.markoshop.si/racunalnistvo-...
- spremenil: Han ()
00mare00 ::
Kateri prenosnik priporočate za nekje 500€ za delo z avtocad (2D) in SketchUp? Gledal sem spodnjega
https://www.mimovrste.com/prenosniki/as...
GupeM ::
Nobenega novega. Za takšen denar bo podhranjen, ali pa bo imel ekran tako v kurcu, da je škoda denarja. Zgornji ima TN matriko, kar je no-go za risanje.
Priporočam kaj rabljenega.
Cr00k ::
Jaz sem se v Dell XPS 13 snapdragon x elite zapicil. Ima kdo kaksno informacijo, kako najugodneje do enega? So slovenski zastopniki ok, ali je bolje tujina? Na amazon.de sem sicer gledal, a ponujajo samo qwertz nemsko tipkovnico. Nisem nikjer opazil, da bi lahko narocil z ANSI US razporedom...
00mare00 ::
Avtocad in Sketchup imata zelo nizke zahteve za poganjat. Ekran je pa druga zadeva. Kakšen ekran pa bi moral gledata?
- spremenilo: 00mare00 ()
00mare00 ::
ips panel, če rabiš pa še čim večji razpon barvn pa vsaj rgb 100%
potem bi bil ta boljši. Ima vsaj IPS panel
https://www.mimovrste.com/prenosniki/de...
https://www.mimovrste.com/prenosniki/le...
https://www.mimovrste.com/prenosniki/hp...
scipascapa ::
Dobra cena.
Tole imam do 22.11 na voljo. Potem zapade.
690€
1200€
560€
Tole imam super cene za LENOVO prenosnike.
Cene so že z DDV.
690€
1200€
560€
Cene so že z DDV.
scipascapa ::
Dream machine laptopi tudi pri nam
https://dreammachines.pl/en
nekaj modelov je že na voljo.
RG3050-15EU50 i5 15.6" 144Hz/RTX3050/500 GB M.2 SSD/16 GB 3 704,35 €
RG4050-15EU46 i7 15.6" 165Hz sRGB 100%/RTX4050/1TB M.2 SSD/16 GB 3 874,55 €
RG4060-15EU52 i7 15.6" 165Hz sRGB 100%/RTX4060/1TB M.2 SSD/32 GB 3 1.070,50 €
V540TU-14EU25 Ultra 7-155H/14.0"/QHD+/120Hz/N7/1TB M.2 SSD/16 GB 3 875,10 €
GX4MRXL-14EU20 Ultra 5-125H/14.0"/QHD+/120Hz/sRGB 100%/1TB M.2 SSD/16 GB 3 797,71 €
RG4060-15EU44 i7-14650HX/RTX4060/15.3"/WQXGA/240Hz/RGB100%/1TB M.2 SSD/32 GB 3 1.327,89 €
RG4070-15EU31 i9-14900HX/RTX4070/15.6"/FHD/144Hz/N7/1TB M.2 SSD/32 GB 3 1.720,41 €
RX4090-17EU31 i9-14900HX/17.0"/RTX4090/WQXGA/240Hz/sRGB 100%/Liquid Cooling/1TB M.2 SSD/32 GB 2 3.089,03 €
RG4050-15EU44 i5 15.6" 144Hz/RTX4050/1TB M.2 SSD/32 GB 3 843,97 €
cene so brez ddv.
v kolikor kaj zanimanja, ZS.
cene so brez ddv.
Gledam tale prenosnik https://geizhals.eu/asus-vivobook-s15-o...
Ima kdo kakšno mnenje, če je ok za to ceno?
Fenkal ::
Živijo! Je tole vredu vredu izbor za everyday use, za Autocad in občasno 3D modeliranje. https://geizhals.eu/asus-zenbook-14-ole...
Oziroma kaj bi predlagali v cenovnem okviru 800-900EUR.
- spremenilo: Fenkal ()
Argonavt ::
Išče se prenosnik za SŠ ASUS Vivobook. Si ga kdo mogoče lasti, zanimajo me izkušnje. Intel I5, I7, 12 ali 13 Gen.OLED je smiseln napram IPS.
PihecMihec ::
Zdravo za starše isčcem prenosnik budget okoli 400eur. Facebook/google/youtube/neka random strateška igra prek neta.
Sem gledal ogromno pa vsakic vidim veliko napak pri laptopih.
Ce ima kdo kako idejo bi bil vesel
