Slabi rezultati v 3DMark03
_LuKeC_ ::
Včeraj sem si prvič testiral računalnik v 3dmarku, ker sem mel občutek da nekaj ne deluje tak kot treba. Še pred tem pa sem formatiral cel disk in vse na novo naložo. Po testiranju so rezultati bili obupni:'( Rezultati grafične kartice so kolko tolko ampak v primerjavi z ostalimi, ki imajo enak računalnik kot jaz mnogo slabši, da o procesorju sploh ne govorim. Test CPU-ja je pa res porazno nizek;(( . Mogoče kdo ve kaj bi lahko bilo krivo za take slabe rezultate???
General Information
Operating System Microsoft Windows XP
DirectX Version 9.0c
Mobo Manufacturer dN
Mobo Model
AGP Rates (Current/Available) N/A / 4x, 8x
CPU Intel Pentium 4 2666 MHz
FSB 133 MHz
Memory 512 MB
Display Information
Graphics Chipset ATI RADEON 9600 Series
Driver Name RADEON 9600 SERIES
Driver Version 6.14.10.6387
Driver Status WHQL - Not FM Approved
Video Memory 256 MB
Core Clock 398 MHz
Memory Clock 203 MHz
Sound Information
Sound Adapter Driver Name C-Media Wave Device
Sound Adapter Driver Version 5.12.1.639
Benchmark Settings
Program Version 3DMark03 Revision 6 Build 0
Resolution 1024x768@32 bit
Texture Filtering Optimal
Pixel Processing / Antialiasing None
Post Processing false
Vertex Shaders Optimal
Main Test Results
3DMark Score 2535 3DMarks
CPU Score 216 CPUMarks
Detailed Test Results
Game Tests
GT1 - Wings of Fury 91.2 fps
GT2 - Battle of Proxycon 15.5 fps
GT3 - Troll's Lair 14.0 fps
GT4 - Mother Nature 16.4 fps
CPU Tests
CPU Test 1 28.0 fps
CPU Test 2 3.2 fps
Feature Tests
Fill Rate (Single-Texturing) 605.3 MTexels/s
Fill Rate (Multi-Texturing) 1273.3 MTexels/s
Vertex Shader 9.8 fps
Pixel Shader 2.0 17.1 fps
Ragtroll 9.8 fps
Sound Tests
No sounds Not Supported
24 sounds Not Supported
60 sounds Not Supported
Dr Evil ::
In kaj si pričakoval s tako grafično?:\
Moonman ::
Cpu test je slab zaradi 133Fsb. P4 so komaj zaživeli s C revizijo (200Mhz fsb)
Ostalo pa je čisto OK za 9600. Ti imaš lite verzijo radeona.
_LuKeC_ ::
Sej jaz nebi nič vedo če bi vido samo rezultate, če so dobri al pa slabi. Jaz sem moje primerjal z ostalimi pa mam dosti slabše kot drugi. Zato se mi zdi malo čudno...
Moonman ::
Če hočeš višji rezultat lahko probaš naviti grafično. ;)
Rezultati 3DMark05
251598 (1330) Tilen
Izdan 3DMark05
313941 (3941) lukanium
Lastniki Gericom Blockbusterja pomoč (strani: 1 2 )
615824 (4917) snow
GF FX 5700 Ultra in 3DMark 2001SE build 330
101263 (1191) ERGY
Uporabnikov test Detonatorjev
63062 (3062) tejo
