Forum » Pomoč in nasveti » Slabi rezultati v 3DMark03
_LuKeC_ ::
Včeraj sem si prvič testiral računalnik v 3dmarku, ker sem mel občutek da nekaj ne deluje tak kot treba. Še pred tem pa sem formatiral cel disk in vse na novo naložo. Po testiranju so rezultati bili obupni
Rezultati grafične kartice so kolko tolko ampak v primerjavi z ostalimi, ki imajo enak računalnik kot jaz mnogo slabši, da o procesorju sploh ne govorim. Test CPU-ja je pa res porazno nizek
. Mogoče kdo ve kaj bi lahko bilo krivo za take slabe rezultate???
General Information
Operating System Microsoft Windows XP
DirectX Version 9.0c
Mobo Manufacturer dN
Mobo Model
AGP Rates (Current/Available) N/A / 4x, 8x
CPU Intel Pentium 4 2666 MHz
FSB 133 MHz
Memory 512 MB
Display Information
Graphics Chipset ATI RADEON 9600 Series
Driver Name RADEON 9600 SERIES
Driver Version 6.14.10.6387
Driver Status WHQL - Not FM Approved
Video Memory 256 MB
Core Clock 398 MHz
Memory Clock 203 MHz
Sound Information
Sound Adapter Driver Name C-Media Wave Device
Sound Adapter Driver Version 5.12.1.639
Benchmark Settings
Program Version 3DMark03 Revision 6 Build 0
Resolution 1024x768@32 bit
Texture Filtering Optimal
Pixel Processing / Antialiasing None
Post Processing false
Vertex Shaders Optimal
Main Test Results
3DMark Score 2535 3DMarks
CPU Score 216 CPUMarks
Detailed Test Results
Game Tests
GT1 - Wings of Fury 91.2 fps
GT2 - Battle of Proxycon 15.5 fps
GT3 - Troll's Lair 14.0 fps
GT4 - Mother Nature 16.4 fps
CPU Tests
CPU Test 1 28.0 fps
CPU Test 2 3.2 fps
Feature Tests
Fill Rate (Single-Texturing) 605.3 MTexels/s
Fill Rate (Multi-Texturing) 1273.3 MTexels/s
Vertex Shader 9.8 fps
Pixel Shader 2.0 17.1 fps
Ragtroll 9.8 fps
Sound Tests
No sounds Not Supported
24 sounds Not Supported
60 sounds Not Supported
General Information
Mobo Model
FSB 133 MHz
Memory 512 MB
Display Information
Video Memory 256 MB
Core Clock 398 MHz
Sound Information
Benchmark Settings
Main Test Results
Game Tests
CPU Tests
CPU Test 1 28.0 fps
CPU Test 2 3.2 fps
Feature Tests
Ragtroll 9.8 fps
Sound Tests
Moonman ::
Cpu test je slab zaradi 133Fsb. P4 so komaj zaživeli s C revizijo (200Mhz fsb)
Ostalo pa je čisto OK za 9600. Ti imaš lite verzijo radeona.
_LuKeC_ ::
Sej jaz nebi nič vedo če bi vido samo rezultate, če so dobri al pa slabi. Jaz sem moje primerjal z ostalimi pa mam dosti slabše kot drugi. Zato se mi zdi malo čudno...
| » | Rezultati 3DMark05Oddelek: Strojna oprema | 1608 (1340) | Tilen |
| » | Izdan 3DMark05Oddelek: Novice / Grafične kartice | 3970 (3970) | lukanium |
| » | Lastniki Gericom Blockbusterja pomoč (strani: 1 2 )Oddelek: Pomoč in nasveti | 5838 (4931) | snow |
| » | GF FX 5700 Ultra in 3DMark 2001SE build 330Oddelek: Pomoč in nasveti | 1275 (1203) | ERGY |
| » | Uporabnikov test DetonatorjevOddelek: Novice / Grafične kartice | 3097 (3097) | tejo |
