Forum » Strojna oprema » LG GSA-4120B dela probleme pri pečenju DL DVD+Rjev
DVD pekač je LG GSA-4120B (FW A116), Nero 6.6.0.12 in Traxdata DVD+R DL. In mi ga je uničo (2.000 je DVD prišo) tak da rabim ugotovit kaj je narobe da nebom $$$$ metal stran. Peko je z hitrostjo 2.4x. To je prvič da sem probal peč DL DVD.
Mi lahko kdo kaj več reč iz tistega kaj piše v log filu?
Log:
13.5.2005
Burn DVD Image
18:23:11 #1 Text 0 File Reader.cpp, Line 127
Reader running
18:23:11 #2 Text 0 File Writer.cpp, Line 122
Writer HL-DT-ST DVDRAM GSA-4120B running
18:23:11 #3 Text 0 File Burncd.cpp, Line 3153
Turn on Disc-At-Once, using DVD media
18:23:11 #4 Text 0 File DlgWaitCD.cpp, Line 260
Last possible write address on media: 4173823 (927:30.73, 8151MB)
Last address to be written: 2917891 (648:25.16, 5699MB)
18:23:11 #5 Text 0 File DlgWaitCD.cpp, Line 272
Write in overburning mode: NO (enabled: CD)
18:23:11 #6 Text 0 File DlgWaitCD.cpp, Line 2339
Recorder: HL-DT-ST DVDRAM GSA-4120B, Media type: DVD+R9 Double Layer
Disc Manufacturer ID: RITEK, Media Type ID: D01, Product revision number: 1
Disc Application Code: 0, Extended Information Indicators: 0
18:23:11 #7 Text 0 File DlgWaitCD.cpp, Line 438
Protocol of DlgWaitCD activities:
18:23:11 #8 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, ISO 9660)
2 indices, index0 (150) not provided
original disc pos #0 + 2917892 (2917892) = #2917892/648:25.17
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2917892 blocks [HL-DT-ST DVDRAM GSA-4120B]
18:23:11 #9 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [HL-DT-ST DVDRAM GSA-4120B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 5975842816, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2917892 | lead-out | 1 | 0x41 | 0x00
18:23:11 #10 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
18:23:11 #11 Text 0 File Burncd.cpp, Line 4037
Cache writing successful.
18:23:11 #12 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
18:23:11 #13 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 2.4x (3.324 KB/s)
18:23:11 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
18:23:11 #15 Text 0 File DVDPlusDualLayer.cpp, Line 430
Disc finalized, LBA total Image size: 2917892 (5699MB), Last LBA L0: 1458959 (2849MB)
18:23:34 #16 Text 0 File DVDPlusDualLayer.cpp, Line 519
L0 Data Zone Capacity set to 1458960 (164310h, 2849MB) -> OK, confirmed setting
18:23:34 #17 CDR -1205 File DVDPlusDualLayer.cpp, Line 544
Burning Layer 1
18:23:34 #18 Text 0 File DVDPlusDualLayer.cpp, Line 552
Start writing layer 1 at address 0 (0h)
18:23:34 #19 Text 0 File Cdrdrv.cpp, Line 8438
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R DL (14), Part Version: 1
Disc Size 120 mm, Maximum Rate: not specified (F h)
Number of Layers: 2, Track Path: Opposite Track Path (OTP), Layer Type: recordable
Linear Density: 0,293 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: FCFFFF h
End Sector Number in Layer 0: 19430F h (LBN: 16430F h, 2849 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 0 h
Disc Manufacturer ID: RITEK...
Media type ID: D01
Number of Physical format information bytes in use in ADIP up to byte 63: 64
Media Specific [16..63]:
00 00 00 52 49 54 45 4B - 00 00 00 44 30 31 01 40 ...RITEK...D01.@
25 25 37 00 00 28 64 00 - 28 64 19 1B 0B 0B 0E 0F %%7..(d.(d......
01 00 00 00 00 19 1B 0B - 0B 0E 0F 01 00 00 00 00 ................
18:23:34 #20 Text 0 File DVDR.cpp, Line 4847
Drive: HL-DT-ST DVDRAM GSA-4120B
Book Type request [LG]: DVD-ROM
Changing the Book Type was finished successfully, return code 0
18:23:34 #21 CDR -1207 File DVDR.cpp, Line 4777
Book Type automatically set to: DVD-ROM
18:23:34 #22 Text 0 File DVDPlusRW.cpp, Line 648
Start write address at LBA 0
DVD high compatibility mode: Yes
18:36:13 #23 SCSI -1061 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 3, TA 0, LUN 0, buffer 0x04700000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x44
Sense Qual: 0x86
CDB Data: 0x2A 0x00 0x00 0x12 0xAB 0x80 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x10
0x35 0x00 0x00 0x0E 0x44 0x86
18:36:13 #24 CDR -1061 File Writer.cpp, Line 311
Internal target failure
18:36:13 #25 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
18:36:13 #26 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
18:36:14 #27 SCSI -1061 File Cdrdrv.cpp, Line 1182
Sense Code: 0x44
Sense Qual: 0x86
CDB Data: 0x35 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x04 0x00 0x00 0x00 0x00 0x10
18:36:14 #28 Phase 127 File dlgbrnst.cpp, Line 1832
Generating DVD high compatibility borders
18:36:16 #29 Phase 129 File dlgbrnst.cpp, Line 1832
Generating DVD borders completed successfully
18:36:16 #30 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 2.4x (3.324 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 20.12.2004 20:37:14 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 3.8.2004 22:59:44 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Log:
13.5.2005
Burn DVD Image
Reader running
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
Burning Layer 1
Media type ID: D01
Sense Code: 0x44
Sense Qual: 0x86
Sense Code: 0x44
Sense Qual: 0x86
Existing drivers:
Registry Keys:
Quikee ::
Tu je problem... kupo si RITEK-ov DL medij. =)
Zakaj pa piše Traxdata gor?
ajajaajajaja....in ti bi rad peku dvdje??
Kaj hočeš reč?
to je to.
to je to.
In kaj je narobe z Traxdato ali RITEKOM?
poglej svoj prvi post
Res nevem kaj mi hočeš reč.
Quikee ::
Hoce ti povedat da TraxData uporablja medije od RITEK-a... in da so njihovi DL mediji zanic. Varirajo po kvaliteti kot hm... njihovi DVD-R in DVD+R mediji (predvsem RITEKG04 in RITEKG05 ).. tak da le ce mas srecne roke bos dobil takega, ki ga bo celo brez napak posnelo.. ce bos mel se vec srece pa ga bo celo brez napak prebralo. =)
Quikee: hvala, sam nebi mogu boljs povedat
Zdaj vidim: Made by RITEK Taiwan.
Hvala RITI da je šlo 2.000 SIT v zrak.
- spremenil: mtosev ()
Katere DL DVDje da kupim?
Paše še je boljše + ali -?
kup verbatim. so mkm.
dost boljsi kot ritek
sicer pa niti nocem vedt zakaj rabs DL.
- spremenil: Dr_M ()
boštjan ::
mtosev,zaenkrat se drži verbatim medijem ko pijenc plota(naj me kdo popravi,če se motim).
Zakaj pa naš vrli
mtosev rabi DL medij.Verjetno zarad firbca,kako njegov pekač peče DL medije.
Zakaj pa naš vrli
NF7-S,2500+@2200MHz,MSi 5900SP,LCD Philip 190X6,Maxtor DM+9 120GB SATA,
2*256 3200/A KHX, PSU 420W DF chieftek
Zakaj pa naš vrli
Mam pa tudi DVD RAM medij.
Nope. Rabim, ker nočem DVD filme kompresirat. 5,56 GB je bil velik tak da sem DL nabavo.
Kaj + ali -?????
Kaj + ali -?????
Quikee ::
mtosev: Ja pa ki si te vido da prodajajo DVD-R DL medij ? Pred kakim tednom so komaj prisli ven iz faze testiranja... pa se to le Verbatim DVD-R DL =) Polek tega dvomim da tvoj pekac DVD-R DL. =) Aja... DVD-R DL kompatibilnost je se slabsa kot DVD+R DL. Vloge so se zamenjale.
- spremenil: Quikee ()
Hmm res nepiše DVD-R DL. Bom pa rabo drugega nabavit pa je.
(res mislim)
boštjan ::
ups,komaj zdaj sem vido,da misliš pekača menjat zarad tega.po moje nesmiselno
- spremenil: boštjan ()
Quikee ::
Kaj nabavil bos drug pekac zaradi DVD-R DL ? Kaj ti te dela... DVD-R DL ma vec kot leto dni zamude pred DVD+R DL... kompatibilnost je slaba, proizvaja pa jih sam MKM (Verbatim) in cena bo(je) vecja. Ce bos pa nabavo drugi pekac zaradi vrjetno drugih lastnosti potem te pa razumem. =)
Iščem novi pekač kateri bo mel podporo za tudi DVD RAM. Je še kaki drugi razen LG kateri bi poleg vsega drugega podpiral RAM?
Zakaj pa rabim DVD RAM?
Moj prvi DVD pekač je mel RAM podporo in sem se na to navado.
boštjan ::
koliko mi je znano zaenkrat samo LG.
Quikee ::
Noben nima DVD RAM podpore razen LG-ja (razn ce pocakas na Nec 4550 in 16x DVD-RAM)... sicer pa sej lahko obdrzis tega LG-ja, kje pise da mors met le en pekac v masini ? (jaz mam 3 zaenkrat)
Če vas zanima moj prvi je bil Matshita (Panasonic) LF-D321E.
Ej kdaj pa pride Nec ven?
Quikee ::
Tam v 3/4 leta.. samo pomoje ga ne bo do novega leta. =) Se prej pride pa se en model iz serije 35xx.
Se opravičujem.
Evo še Philipsa je uničo.
Log file:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'H:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26.10.2004 18:35:34
Nero Version: 6.6.0.12
Internal Version: 6, 6, 0, 12c
Recorder: HL-DT-ST DVDRAM GSA-4120B Version: A116 - HA 3 TA 0 - 6.6.0.12
Adapter driver: atapi HA 3
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: HL-DT-ST DVDRAM GSA-4120B Version: A116 - HA 3 TA 0 - 6.6.0.12
=== Scsi-Device-Map ===
DiskPeripheral : HDS722516VLSA80 atapi Port 2 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVDRAM GSA-4120B atapi Port 3 ID 0 DMA: On
CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 4 ID 0 DMA: Off
CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 4 ID 1 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-4120B K: CDRom0
Generic DVD-ROM L: CDRom1
Generic DVD-ROM M: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1022MB (1047280kB)
Free physical memory: 522MB (535376kB)
Memory in use : 48 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
14.5.2005
Burn DVD Image
12:59:30 #1 Text 0 File Reader.cpp, Line 127
Reader running
12:59:30 #2 Text 0 File Writer.cpp, Line 122
12:59:30 #3 Text 0 File Burncd.cpp, Line 3153
12:59:31 #4 Text 0 File DlgWaitCD.cpp, Line 260
12:59:31 #5 Text 0 File DlgWaitCD.cpp, Line 272
12:59:31 #6 Text 0 File DlgWaitCD.cpp, Line 2339
Disc Manufacturer ID: PHILIPS, Media Type ID: CD2, Product revision number: 0
12:59:31 #7 Text 0 File DlgWaitCD.cpp, Line 438
12:59:31 #8 Text 0 File ThreadedTransferInterface.cpp, Line 830
12:59:31 #9 Text 0 File ThreadedTransferInterface.cpp, Line 1043
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
12:59:31 #10 Phase 24 File dlgbrnst.cpp, Line 1832
12:59:31 #11 Text 0 File Burncd.cpp, Line 4037
12:59:31 #12 Phase 25 File dlgbrnst.cpp, Line 1832
12:59:31 #13 Phase 36 File dlgbrnst.cpp, Line 1832
12:59:31 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2609
12:59:31 #15 Text 0 File DVDPlusDualLayer.cpp, Line 430
12:59:55 #16 Text 0 File DVDPlusDualLayer.cpp, Line 519
12:59:55 #17 CDR -1205 File DVDPlusDualLayer.cpp, Line 544
Burning Layer 1
12:59:55 #18 Text 0 File DVDPlusDualLayer.cpp, Line 552
12:59:55 #19 Text 0 File Cdrdrv.cpp, Line 8438
Disc Size: 120 mm, Maximum Rate: not specified (F h)
Disc Manufacturer ID: PHILIPS.
Media type ID: CD2
00 00 00 50 48 49 4C 49 - 50 53 00 43 44 32 00 40 ...PHILIPS.CD2.@
25 25 37 0B 02 3C 6A 02 - 3C 6A 1B 1C 0D 0C 0C 0C %%7..j.j......
02 01 01 10 00 1B 1C 0D - 0C 0C 0C 02 01 01 10 00 ................
12:59:55 #20 Text 0 File DVDR.cpp, Line 4847
12:59:55 #21 CDR -1207 File DVDR.cpp, Line 4777
12:59:56 #22 Text 0 File DVDPlusRW.cpp, Line 648
13:01:12 #23 SCSI -1039 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 3, TA 0, LUN 0, buffer 0x04820000
Sense Code: 0x09
Sense Qual: 0x01
CDB Data: 0x2A 0x00 0x00 0x01 0xB6 0xC0 0x00 0x00 0x20 0x00 0x00 0x00
0x35 0x01 0x00 0x0E 0x09 0x01
13:01:12 #24 CDR -1039 File Writer.cpp, Line 311
Focus or tracking error
13:01:12 #25 Text 0 File ThreadedTransfer.cpp, Line 228
13:01:12 #26 Text 0 File ThreadedTransfer.cpp, Line 222
13:01:16 #27 Phase 127 File dlgbrnst.cpp, Line 1832
13:01:46 #28 Phase 129 File dlgbrnst.cpp, Line 1832
13:01:46 #29 Phase 38 File dlgbrnst.cpp, Line 1832
Existing drivers:
Registry Keys:
Log file:
Windows XP 5.1
IA32
WinAspi: -
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Use Inquiry : 1
14.5.2005
Burn DVD Image
Reader running
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
Burning Layer 1
Media type ID: CD2
Sense Code: 0x09
Sense Qual: 0x01
Existing drivers:
Registry Keys:
Bil sem v BOFu in Big Bangu in sem našo samo Philips.
Quikee ::
Aha.. in si kupi kljub temu da kricimo mi Verbatim =) Jao.
DVD+R Datalife Plus Dual Layer 8,5GB (5 kos) 9.060,00
Pa pazmisli.
Pokaži kje se lahko dobi en medij?
Pa pazmisli.
Eno trgovino v MBju pokaži.
Kje?
Naj najnovejši FW je (niti na strani od LG ga nimajo).
Quikee ::
Pol pa ne vem... mogoce ne podpira PHILIPS CD2 tvoj pekac.. mogoce tudi RITEK D01 ne podpira. Mogoce pa je zanic pri pisanju na DL medije. Samo sem videl review pa jim je slo posnet (Verbatimov MKM 001). =)
Je kak test da vidim če je pekač OK?
Pa kje v MBju bi imeli te medije?
Kere ?
Verbatim
Kaj je šo moj pekač po gobe?
Verbatim
Quikee ::
Oh... JAE, Comtron, Fast Forward, pa se kje drugje bi se tudi nasli.
Aja pa preden bos se kaj pekel na DL medije.. ce mas image.. peci v DVD Decrypteru. IDE drivere iz varnostnih razlogov nastavi na MS IDE. Preveri DMA da je Ultra DMA 2. Zapeci kak normalen DVD medij da vidis da stvar deluje.. po moznosti v Nero CD/DVD Speed.. Create Data Disc.
Pri DVD Decrypterju pod I/O in to: SPTI Microsoft?
Je ja.
Je ja.
Quikee ::
" Pri DVD Decrypterju pod I/O in to: SPTI Microsoft? "
Ne... IDE driverje v windowsih... ne I/O interface.
Jaz nikje nevidim MS IDE. Kje?
Aja en je na Ultra DMA Mode 5 drugi pa Ultra DMA Mode 2 (nevem katero je disk katero pogon).
| » | Nero 7 PremiumOddelek: Programska oprema | 1943 (1697) | kriko1 |
| » | NEC ND-3540A problem...Oddelek: Pomoč in nasveti | 2786 (2077) | dean444 |
| » | tezave z virusomOddelek: Pomoč in nasveti | 1868 (1717) | royal |
| » | Težave s pekačemOddelek: Pomoč in nasveti | 2375 (2315) | boštjan |
| » | PLEXTOR BurfProof unicuje cdje - prosim pomagajte!Oddelek: Pomoč in nasveti | 2164 (1918) | krho |
