RAID na malo drugačen način ?????
Arzen ::
Ali lahko naredim raid iz dveh diskov na kerih so podatki ne da bi izgubil podatke?
Se opravičujem za tako butasto vprašanje a vendar me zanima če je to mogoče na kakšen način.
Hvala!
_Dejan_ ::
Je mogoče edino tako da se narediš back up na DVDje ali CDje:D
ASUS P5E3, INTEL Q6600(3000Mhz 333x9), ATI HD 2600XT,
A-Data 4x2GB PC3-10700H(9-9-9-24-2T),LSI 9260-8i,
4x OCZ Vertex Turbo 30GB(RAID10), 3x1TB (RAID1+Spare)
Dzonson ::
torej ce imas maticno plosco z Intel® 865 ali 875 chipset-om potem ti nekaj upanja ostaja:
Intel® Application Accelerator RAID Edition
"Where Intel is able to offer some additional value over the competition is in their RAID Application Accelerator drivers. Normally when you want to upgrade from a single drive to a dual drive RAID 0 array, you have to backup all of your data and create the RAID 0 array, which ends up destroying all the data you had on the original drive. Intel's solution simply requires you to enable Intel RAID in the BIOS, even when you only have one drive, and upon upgrading to a second drive you simply tell the Application Accelerator driver to create a RAID 0 array and the array is created in the background without any data loss."
Arzen ::
Asus Intel 915P ploščo imam... Je tu kaj pomoči...
Dzonson ::
se bolje :))
za 915 chipset pa imas na voljo Intel Matrix Storage, ki ti omogoca, da si na dveh diskih hkrati naredis RAID 0 in RAID 1 polje.
Klik za navodila kako in kaj.
Nisem pa preverjal ali ta Matrix podpira isto funkcijo za ohranitev podatkov prehoda iz enega diska na dva, tako da si malo preberi (www.intel.com)
dr.J ::
Jest bi na tvojem mestu najprej backup naredil.
Intel raid ne obnovi polja
61002 (867) Shark-357
RAID med dvema particijama na dveh diskih.
51331 (1237) All
ICH9R in RAID
222639 (2135) T(he) Boss
Kako nastaviti RAID1 ???
72274 (2186) t3hn0
vezava diskov za montažo filmov
111825 (1691) Tilen
