Gentoo Xorg in ATI - problem slika ni na DVI vmesniku
alexb ::
Zivjo,
uspesno sem namestil ATI driverje, saj mi pri opciji MonitorLayout AUTO,AUTO vse normalno deluje, vendar le na analogne izhodu. DVI gre v power save. 3D pospesevanje deluje (glxgears). Podoben problem sem imel ko sem preizkusal Ubuntu, vendar sem ga resil, ko sem v xorg.conf popravil iz AUTO na TMDS. Ta nastavitev v tem primeru ne deluje.
Spodaj prilagam
xorg.conf in pa Xorg.0.log
Upam da se komu utrne kaka ideja.
# File: XF86Config-4
# File generated by fglrxconfig © ATI Research, a substitute for xf86config.
# DRI Section
Section "dri"
# Access to OpenGL ICD is allowed for all users:
Mode 0666
EndSection
# Module section -- this section is used to specify
# which dynamically loadable modules to load.
Section "Module"
# This loads the DBE extension module.
Load "dbe" # Double buffer extension
# This loads the miscellaneous extensions module, and disables
# initialisation of the XFree86-DGA extension within that module.
SubSection "extmod"
Option "omit xfree86-dga" # don't initialise the DGA extension
EndSubSection
# This loads the Type1 and FreeType font modules
Load "type1"
Load "freetype"
# This loads the GLX module
Load "glx" # libglx.a
Load "dri" # libdri.a
EndSection
# Files section. This allows default font and rgb paths to be set
Section "Files"
RgbPath "/usr/X11R6/lib/X11/rgb"
FontPath "/usr/X11R6/lib/X11/fonts/local/"
FontPath "/usr/X11R6/lib/X11/fonts/misc/"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/Type1/"
# FontPath "/usr/X11R6/lib/X11/fonts/Speedo/"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/"
# The module search path. The default path is shown here.
# ModulePath "/usr/X11R6/lib/modules"
EndSection
# Server flags section.
Section "InputDevice"
Identifier "Keyboard1"
Driver "kbd"
Option "AutoRepeat" "500 30"
Option "XkbRules" "xfree86"
Option "XkbModel" "pc101"
Option "XkbLayout" "us"
EndSection
# Core Pointer's InputDevice section
Identifier "Mouse1"
Driver "mouse"
Option "Protocol" "ExplorerPS/2"
Option "Device" "/dev/mouse"
EndSection
# Monitor section
Section "Monitor"
Identifier "Monitor0"
HorizSync 30 - 83
VertRefresh 60
EndSection
# Graphics device section
# Standard VGA Device:
Section "Device"
Identifier "Standard VGA"
VendorName "Unknown"
BoardName "Unknown"
Driver "vga"
EndSection
# === ATI device section ===
Section "Device"
Identifier "ATI Graphics Adapter"
Driver "fglrx"
# ### generic DRI settings ###
# === disable PnP Monitor ===
# Option "NoDDC"
# === disable/enable XAA/DRI ===
Option "no_accel" "no"
Option "no_dri" "no"
# === misc DRI settings ===
Option "mtrr" "off" # disable DRI mtrr mapper, driver has its own code for mtrr
# ### FireGL DDX driver module specific settings ###
# === Screen Management ===
Option "DesktopSetup" "0x00000000"
Option "ConnectedMonitor" "DFP"
Option "MonitorLayout" "TMDS,AUTO"
Option "IgnoreEDID" "on"
Option "HSync2" "30 - 83"
Option "VRefresh2" "60"
Option "ScreenOverlap" "0"
# === TV-out Management ===
Option "NoTV" "yes"
Option "TVStandard" "NTSC-M"
Option "TVHSizeAdj" "0"
Option "TVVSizeAdj" "0"
Option "TVHPosAdj" "0"
Option "TVVPosAdj" "0"
Option "TVHStartAdj" "0"
Option "TVColorAdj" "0"
Option "GammaCorrectionI" "0x00000000"
Option "GammaCorrectionII" "0x00000000"
# === OpenGL specific profiles/settings ===
Option "Capabilities" "0x00000000"
# === Video Overlay for the Xv extension ===
Option "VideoOverlay" "on"
# === OpenGL Overlay ===
# Note: When OpenGL Overlay is enabled, Video Overlay
# will be disabled automatically
Option "OpenGLOverlay" "off"
# === Center Mode (Laptops only) ===
Option "CenterMode" "off"
# === Pseudo Color Visuals (8-bit visuals) ===
Option "PseudoColorVisuals" "off"
# === QBS Management ===
Option "Stereo" "off"
Option "StereoSyncEnable" "1"
# === FSAA Management ===
Option "FSAAEnable" "no"
Option "FSAAScale" "1"
Option "FSAADisableGamma" "no"
Option "FSAACustomizeMSPos" "no"
Option "FSAAMSPosX0" "0.000000"
Option "FSAAMSPosY0" "0.000000"
Option "FSAAMSPosX1" "0.000000"
Option "FSAAMSPosY1" "0.000000"
Option "FSAAMSPosX2" "0.000000"
Option "FSAAMSPosY2" "0.000000"
Option "FSAAMSPosX3" "0.000000"
Option "FSAAMSPosY3" "0.000000"
Option "FSAAMSPosX4" "0.000000"
Option "FSAAMSPosY4" "0.000000"
Option "FSAAMSPosX5" "0.000000"
Option "FSAAMSPosY5" "0.000000"
# === Misc Options ===
Option "UseFastTLS" "0"
Option "BlockSignalsOnLock" "on"
Option "UseInternalAGPGART" "yes"
Option "ForceGenericCPU" "no"
BusID "PCI:1:0:0" # vendor=1002, device=514d
Screen 0
EndSection
# Screen sections
Section "Screen"
Identifier "Screen0"
Device "ATI Graphics Adapter"
Monitor "Monitor0"
DefaultDepth 24
#Option "backingstore"
Subsection "Display"
Depth 24
Modes "1280x1024"
ViewPort 0 0 # initial origin if mode is smaller than desktop
# Virtual 1280 1024
EndSubsection
EndSection
# ServerLayout sections.
Section "ServerLayout"
Identifier "Server Layout"
Screen "Screen0"
InputDevice "Mouse1" "CorePointer"
InputDevice "Keyboard1" "CoreKeyboard"
EndSection
### EOF ###
log datoteka.
X Window System Version 6.8.0
Release Date: 8 September 2004
X Protocol Version 11, Revision 0, Release 6.8
Build Operating System: Linux 2.6.10-gentoo-r6 i686 [ELF]
Current Operating System: Linux krneki 2.6.10-gentoo-r6 #2 SMP Mon Feb 21 22:33:59 EET 2005 i686
Build Date: 17 February 2005
Before reporting problems, check http://wiki.X.Org
to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Sun Feb 27 23:45:18 2005
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Server Layout"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "Monitor0"
(**) | |-->Device "ATI Graphics Adapter"
(**) |-->Input Device "Mouse1"
(**) |-->Input Device "Keyboard1"
(**) FontPath set to "/usr/X11R6/lib/X11/fonts/local/,/usr/X11R6/lib/X11/fonts/misc/,/usr/X11R6/lib/X11/fonts/75dpi/:unscaled,/usr/X11R6/lib/X11/fonts/100dpi/:unscaled,/usr/X11R6/lib/X11/fonts/Type1/,/usr/X11R6/lib/X11/fonts/75dpi/,/usr/X11R6/lib/X11/fonts/100dpi/"
(**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/lib/modules"
(WW) Open APM failed (/dev/apm_bios) (No such file or directory)
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.2
X.Org Video Driver: 0.7
X.Org XInput driver : 0.4
X.Org Server Extension : 0.2
X.Org Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 6.8.0, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/modules/libpcidata.a
(II) Module pcidata: vendor="X.Org Foundation"
ABI class: X.Org Video Driver, version 0.7
Using vt 7
(--) using VT number 7
(II) PCI: Probing config type using method 1
(II) PCI: Config type is 1
(II) PCI: stages = 0x03, oldVal1 = 0x00000000, mode1Res1 = 0x80000000
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,2570 card 147b,1028 rev 02 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,2571 card 0000,0000 rev 02 class 06,04,00 hdr 01
(II) PCI: 00:1d:0: chip 8086,24d2 card 147b,1028 rev 02 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,24d4 card 147b,1028 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,24d7 card 147b,1028 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:3: chip 8086,24de card 147b,1028 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,24dd card 147b,1028 rev 02 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev c2 class 06,04,00 hdr 01
(II) PCI: 00:1f:0: chip 8086,24d0 card 0000,0000 rev 02 class 06,01,00 hdr 80
(II) PCI: 00:1f:2: chip 8086,24d1 card 147b,1028 rev 02 class 01,01,8a hdr 00
(II) PCI: 00:1f:3: chip 8086,24d3 card 147b,1028 rev 02 class 0c,05,00 hdr 00
(II) PCI: 00:1f:5: chip 8086,24d5 card 147b,1028 rev 02 class 04,01,00 hdr 00
(II) PCI: 01:00:0: chip 1002,514d card 174b,7149 rev 00 class 03,00,00 hdr 00
(II) PCI: 02:01:0: chip 104c,8024 card 147b,1028 rev 00 class 0c,00,10 hdr 00
(II) PCI: 02:02:0: chip 10ec,8139 card 147b,1028 rev 10 class 02,00,00 hdr 00
(II) PCI: 02:06:0: chip 1814,0101 card 1043,0126 rev 00 class 02,80,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000c (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]
[1] -1 0 0x00009400 - 0x000094ff (0x100) IX[B]
[2] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
[3] -1 0 0x00009c00 - 0x00009cff (0x100) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xf8000000 - 0xf9ffffff (0x2000000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xf0000000 - 0xf7ffffff (0x8000000) MX[B]
(II) Bus 2: bridge is at (0:30:0), (0,2,2), BCTRL: 0x0006 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[1] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]
[2] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]
[3] -1 0 0x0000ac00 - 0x0000acff (0x100) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xfa000000 - 0xfa0fffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) ATI Technologies Inc Radeon R200 QM [Radeon 9100] rev 0, Mem @ 0xf0000000/27, 0xf9000000/16, I/O @ 0x9000/8
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xe8000000 from 0xefffffff to 0xe7ffffff
(II) Active PCI resource ranges:
[0] -1 0 0xfa004000 - 0xfa005fff (0x2000) MX[B]
[1] -1 0 0xfa006000 - 0xfa0060ff (0x100) MX[B]
[2] -1 0 0xfa000000 - 0xfa003fff (0x4000) MX[B]
[3] -1 0 0xfa007000 - 0xfa0077ff (0x800) MX[B]
[4] -1 0 0xfa102000 - 0xfa1020ff (0x100) MX[B]
[5] -1 0 0xfa101000 - 0xfa1011ff (0x200) MX[B]
[6] -1 0 0xfa100000 - 0xfa1003ff (0x400) MX[B]
[7] -1 0 0xe8000000 - 0xe7ffffff (0x0) MX[B]O
[8] -1 0 0xf9000000 - 0xf900ffff (0x10000) MX[B](B)
[9] -1 0 0xf0000000 - 0xf7ffffff (0x8000000) MX[B](B)
[10] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[11] -1 0 0x0000dc00 - 0x0000dc3f (0x40) IX[B]
[12] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[13] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
[14] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[15] -1 0 0x0000b800 - 0x0000b81f (0x20) IX[B]
[16] -1 0 0x0000b400 - 0x0000b41f (0x20) IX[B]
[17] -1 0 0x0000b000 - 0x0000b01f (0x20) IX[B]
[18] -1 0 0x0000bc00 - 0x0000bc1f (0x20) IX[B]
[19] -1 0 0x00009000 - 0x000090ff (0x100) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0 0xfa004000 - 0xfa005fff (0x2000) MX[B]
[6] -1 0 0xfa006000 - 0xfa0060ff (0x100) MX[B]
[7] -1 0 0xfa000000 - 0xfa003fff (0x4000) MX[B]
[8] -1 0 0xfa007000 - 0xfa0077ff (0x800) MX[B]
[9] -1 0 0xfa102000 - 0xfa1020ff (0x100) MX[B]
[10] -1 0 0xfa101000 - 0xfa1011ff (0x200) MX[B]
[11] -1 0 0xfa100000 - 0xfa1003ff (0x400) MX[B]
[12] -1 0 0xe8000000 - 0xe7ffffff (0x0) MX[B]O
[13] -1 0 0xf9000000 - 0xf900ffff (0x10000) MX[B](B)
[14] -1 0 0xf0000000 - 0xf7ffffff (0x8000000) MX[B](B)
[15] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[16] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[17] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[18] -1 0 0x0000dc00 - 0x0000dc3f (0x40) IX[B]
[19] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[20] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
[21] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[22] -1 0 0x0000b800 - 0x0000b81f (0x20) IX[B]
[23] -1 0 0x0000b400 - 0x0000b41f (0x20) IX[B]
[24] -1 0 0x0000b000 - 0x0000b01f (0x20) IX[B]
[25] -1 0 0x0000bc00 - 0x0000bc1f (0x20) IX[B]
[26] -1 0 0x00009000 - 0x000090ff (0x100) IX[B](B)
(II) LoadModule: "dbe"
(II) Loading /usr/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="X.Org Foundation"
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.2
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "extmod"
(II) Loading /usr/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "type1"
(II) Loading /usr/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="X.Org Foundation"
compiled for 6.8.0, module version = 1.0.2
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "freetype"
(II) Loading /usr/lib/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 6.8.0, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/lib/modules/extensions/libglx.a
(II) Module glx: vendor="X.Org Foundation"
(II) Loading sub module "GLcore"
(II) LoadModule: "GLcore"
(II) Loading /usr/lib/modules/extensions/libGLcore.a
(II) Module GLcore: vendor="X.Org Foundation"
(II) Loading extension GLX
(II) LoadModule: "dri"
(II) Loading /usr/lib/modules/extensions/libdri.a
(II) Module dri: vendor="X.Org Foundation"
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/lib/modules/linux/libdrm.a
(II) Module drm: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "fglrx"
(II) Loading /usr/lib/modules/drivers/fglrx_drv.o
(II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
compiled for 4.3.99.902, module version = 8.8.25
Module class: X.Org Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="X.Org Foundation"
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.4
(II) LoadModule: "kbd"
(II) Loading /usr/lib/modules/input/kbd_drv.o
(II) Module kbd: vendor="X.Org Foundation"
(II) ATI Radeon/FireGL: The following chipsets are supported:
FireGL - (RV250 4964), FireGL - (RV250 4965),
RADEON 9000/9000 PRO (RV250 4966), RADEON 9000 LE (RV250 4967),
MOBILITY FireGL 9000 (M9 4C64), MOBILITY FireGL - (M9 4C65),
MOBILITY RADEON 9000 (M9 4C66), RADEON 9000 PRO (D9 4C67),
RADEON 9250 (RV280 5960), RADEON 9200 (RV280 5961),
RADEON 9200 SE (RV280 5964), MOBILITY RADEON 9200 (M9+ 5C61),
MOBILITY RADEON 9200 (M9+ 5C63), FireGL 8800 (R200 5148),
RADEON 8500 (R200 514C), RADEON 9100 (R200 514D),
RADEON - (R200 5154), RADEON - (R200 5155),
RADEON 8500 AIW (R200 4242), RADEON 9600 (RV350 4150),
RADEON 9600 SE (RV350 4151), RADEON 9600 PRO (RV360 4152),
MOBILITY RADEON 9600/9700 (M10/M11 4E50), RADEON 9500 (R300 4144),
RADEON - (R300 4145), RADEON 9600 TX (R300 4146),
FireGL Z1 (R300 4147), RADEON 9700 PRO (R300 4E44),
RADEON 9500 PRO/9700 (R300 4E45), RADEON 9600 TX (R300 4E46),
FireGL X1 (R300 4E47), RADEON 9800 SE (R350 4148),
FireGL - (R350 414B), RADEON 9550 (RV350 4153),
FireGL T2 (RV350 4154), FireGL - (RV350 4155), FireGL - (RV350 4156),
FireGL - (RV350 4157), RADEON 9800 PRO (R350 4E48),
RADEON 9800 (R350 4E49), RADEON 9800 XT (R360 4E4A),
FireGL X2-256/X2-256t (R350 4E4B),
MOBILITY FireGL T2/T2e (M10/M11 4E54), RADEON X300 (RV370 5B60),
RADEON - (RV370 5B61), RADEON X600 (RV380 5B62),
RADEON - (RV370 5B63), FireGL V3100 (RV370 5B64),
FireGL - (RV370 5B66), FireGL - (RV370 5B67),
MOBILITY RADEON X300 (M22 5460), MOBILITY RADEON - (M22 5461),
MOBILITY RADEON - (M22 5462), MOBILITY RADEON - (M22 5463),
MOBILITY FireGL V3100 (M22 5464), MOBILITY FireGL - (M22 5465),
MOBILITY FireGL - (M22 5466), MOBILITY FireGL - (M22 5467),
RADEON X600 (RV380 3E50), RADEON - (RV380 3E51),
RADEON - (RV380 3E52), RADEON - (RV380 3E53),
FireGL V3200 (RV380 3E54), FireGL - (RV380 3E55),
FireGL - (RV380 3E56), FireGL - (RV380 3E57),
MOBILITY RADEON X600 (M24 3150), MOBILITY RADEON - (M24 3151),
MOBILITY RADEON X300 (M22 3152), MOBILITY RADEON - (M24 3153),
MOBILITY FireGL V3200* (M24 3154), MOBILITY FireGL -* (M24 3155),
MOBILITY FireGL -* (M24 3156), MOBILITY FireGL -* (M24 3157),
RADEON X800 (R420 4A48), RADEON X800 PRO (R420 4A49),
RADEON X800 SE (R420 4A4A), RADEON X800 XT (R420 4A4B),
RADEON X800 (R420 4A4C), FireGL X3-256 (R420 4A4D),
MOBILITY RADEON 9800 (M18 4A4E),
RADEON X800 XT Platinum Edition (R420 4A50), RADEON X800 (R423 5548),
RADEON X800 PRO (R423 5549),
RADEON X800 XT Platinum Edition (R423 554A),
RADEON X800 SE (R423 554B), RADEON X800 XT (R423 5D57),
FireGL V7100 (R423 5550), FireGL V5100 (R423 5551),
FireGL -* (R423 5552), MOBILITY RADEON X800 XT (M28 5D48),
MOBILITY FireGL V5100* (M28 5D49), RADEON X700 XT (RV410 5E4A),
RADEON X700 PRO (RV410 5E4B), RADEON X700 SE (RV410 5E4C),
RADEON X700 (RV410 5E4D), RADEON X700 (RV410 5E4F),
RADEON - (RV410 5E52), RADEON - (RV410 5E53), RADEON - (RV410 5E55),
RADEON 9100 IGP (RS300 5834),
RADEON 9000 PRO/9100 PRO IGP (RS350 7834),
MOBILITY RADEON 9000/9100 IGP (RS300M 5835)
(II) Primary Device is: PCI 01:00:0
(--) Chipset RADEON 9100 (R200 514D) found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) fglrx(0): pEnt->device->identifier=0x820a9f0
(II) resource ranges after probing:
[15] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[16] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[17] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[18] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[19] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[20] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[21] -1 0 0x0000dc00 - 0x0000dc3f (0x40) IX[B]
[22] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[23] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
[24] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[25] -1 0 0x0000b800 - 0x0000b81f (0x20) IX[B]
[26] -1 0 0x0000b400 - 0x0000b41f (0x20) IX[B]
[27] -1 0 0x0000b000 - 0x0000b01f (0x20) IX[B]
[28] -1 0 0x0000bc00 - 0x0000bc1f (0x20) IX[B]
[29] -1 0 0x00009000 - 0x000090ff (0x100) IX[B](B)
[30] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[31] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) fglrx(0): === [R200PreInit] === begin, [s]
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/modules/libvgahw.a
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 6.8.0, module version = 0.1.0
(II) fglrx(0): PCI bus 1 card 0 func 0
(**) fglrx(0): Depth 24, (--) framebuffer bpp 32
(II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) fglrx(0): Default visual is TrueColor
(**) fglrx(0): Option "NoAccel" "no"
(**) fglrx(0): Option "NoDRI" "no"
(**) fglrx(0): Option "Capabilities" "0x00000000"
(**) fglrx(0): Option "GammaCorrectionI" "0x00000000"
(**) fglrx(0): Option "GammaCorrectionII" "0x00000000"
(**) fglrx(0): Option "OpenGLOverlay" "off"
(**) fglrx(0): Option "VideoOverlay" "on"
(**) fglrx(0): Option "DesktopSetup" "0x00000000"
(**) fglrx(0): Option "MonitorLayout" "TMDS,AUTO"
(**) fglrx(0): Option "HSync2" "30 - 83"
(**) fglrx(0): Option "VRefresh2" "60"
(**) fglrx(0): Option "ScreenOverlap" "0"
(**) fglrx(0): Option "IgnoreEDID" "on"
(**) fglrx(0): Option "UseInternalAGPGART" "yes"
(**) fglrx(0): Option "Stereo" "off"
(**) fglrx(0): Option "StereoSyncEnable" "1"
(**) fglrx(0): Option "UseFastTLS" "0"
(**) fglrx(0): Option "BlockSignalsOnLock" "on"
(**) fglrx(0): Option "ForceGenericCPU" "no"
(**) fglrx(0): Option "CenterMode" "off"
(**) fglrx(0): Option "FSAAScale" "1"
(**) fglrx(0): Option "FSAAEnable" "no"
(**) fglrx(0): Option "FSAADisableGamma" "no"
(**) fglrx(0): Option "FSAACustomizeMSPos" "no"
(**) fglrx(0): Option "FSAAMSPosX0" "0.000000"
(**) fglrx(0): Option "FSAAMSPosY0" "0.000000"
(**) fglrx(0): Option "FSAAMSPosX1" "0.000000"
(**) fglrx(0): Option "FSAAMSPosY1" "0.000000"
(**) fglrx(0): Option "FSAAMSPosX2" "0.000000"
(**) fglrx(0): Option "FSAAMSPosY2" "0.000000"
(**) fglrx(0): Option "FSAAMSPosX3" "0.000000"
(**) fglrx(0): Option "FSAAMSPosY3" "0.000000"
(**) fglrx(0): Option "FSAAMSPosX4" "0.000000"
(**) fglrx(0): Option "FSAAMSPosY4" "0.000000"
(**) fglrx(0): Option "FSAAMSPosX5" "0.000000"
(**) fglrx(0): Option "FSAAMSPosY5" "0.000000"
(**) fglrx(0): Option "NoTV" "yes"
(**) fglrx(0): Option "TVStandard" "NTSC-M"
(**) fglrx(0): Option "TVHSizeAdj" "0"
(**) fglrx(0): Option "TVVSizeAdj" "0"
(**) fglrx(0): Option "TVHPosAdj" "0"
(**) fglrx(0): Option "TVVPosAdj" "0"
(**) fglrx(0): Option "TVHStartAdj" "0"
(**) fglrx(0): Option "TVColorAdj" "0"
(**) fglrx(0): Option "PseudoColorVisuals" "off"
(**) fglrx(0): Qbs disabled
(==) fglrx(0): RGB weight 888
(II) fglrx(0): Using 8 bits per RGB (8 bit DAC)
(**) fglrx(0): Gamma Correction for I is 0x00000000
(**) fglrx(0): Gamma Correction for II is 0x00000000
(==) fglrx(0): Buffer Tiling is ON
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/lib/modules/linux/libint10.a
(II) Module int10: vendor="X.Org Foundation"
(II) fglrx(0): initializing int10
(II) fglrx(0): Primary V_BIOS segment is: 0xc000
(**) fglrx(0): Option "mtrr" "off"
(--) fglrx(0): Chipset: "RADEON 9100 (R200 514D)" (Chipset = 0x514d)
(--) fglrx(0): (PciSubVendor = 0x174b, PciSubDevice = 0x7149)
(--) fglrx(0): board vendor info: third party grafics adapter - NOT original ATI
(--) fglrx(0): Linear framebuffer (phys) at 0xf0000000
(--) fglrx(0): MMIO registers at 0xf9000000
(--) fglrx(0): ChipExtRevID = 0x00
(--) fglrx(0): ChipIntRevID = 0x02
(--) fglrx(0): VideoRAM: 65536 kByte (64-bit DDR SDRAM)
(WW) fglrx(0): board is an unknown third party board, chipset is supported
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Loading /usr/lib/modules/libddc.a
(II) Module ddc: vendor="X.Org Foundation"
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"
(II) Loading /usr/lib/modules/libi2c.a
(II) Module i2c: vendor="X.Org Foundation"
compiled for 6.8.0, module version = 1.2.0
(II) fglrx(0): I2C bus "DDC" initialized.
(II) fglrx(0): Connector Layout from BIOS --------
(II) fglrx(0): Connector1: DDCType-3, DACType-0, TMDSType--1, ConnectorType-2
(**) fglrx(0): IgnoreEDID is specified, EDID data will be ignored
(**) fglrx(0): MonitorLayout Option:
Monitor1--Type TMDS, Monitor2--Type AUTO
(II) fglrx(0): I2C device "DDC:ddc2" registered at address 0xA0.
(II) fglrx(0): I2C device "DDC:ddc2" removed.
(II) fglrx(0): DDC detected on DDCType 3 with Monitor Type 1
(II) fglrx(0): Primary head:
Monitor -- TMDS
Connector -- None
DAC Type -- Unknown
TMDS Type -- NONE
DDC Type -- NONE
(II) fglrx(0): Secondary head:
Monitor -- CRT
Connector -- VGA
DAC Type -- Primary
TMDS Type -- NONE
DDC Type -- VGA_DDC
(II) fglrx(0):
(II) fglrx(0): DesktopSetup 0x0000
(**) fglrx(0): PseudoColor visuals disabled
(**) fglrx(0): Overlay disabled
(II) fglrx(0): PLL parameters: rf=2700 rd=12 min=20000 max=35000
(==) fglrx(0): Using gamma correction (1.0, 1.0, 1.0)
(**) fglrx(0): Center Mode is disabled
(==) fglrx(0): TMDS coherent mode is enabled
(II) fglrx(0): Validating mode for clone (secondary) head ------------
(II) fglrx(0): Monitor0: Using hsync range of 30.00-83.00 kHz
(II) fglrx(0): Monitor0: Using vrefresh value of 60.00 Hz
(II) fglrx(0): Clock range: 20.00 to 350.00 MHz
(II) fglrx(0): Not using default mode "640x350" (vrefresh out of range)
(II) fglrx(0): Not using default mode "320x175" (bad mode clock/interlace/doublescan)
(II) fglrx(0): Not using default mode "640x400" (vrefresh out of range)
(II) fglrx(0): Not using default mode "320x200" (bad mode clock/interlace/doublescan)
(II) fglrx(0): Not using default mode "720x400" (vrefresh out of range)
(II) fglrx(0): Not using default mode "360x200" (bad mode clock/interlace/doublescan)
(II) fglrx(0): Not using default mode "320x240" (bad mode clock/interlace/doublescan)
(II) fglrx(0): Not using default mode "640x480" (vrefresh out of range)
(II) fglrx(0): Not using default mode "800x600" (vrefresh out of range)
(II) fglrx(0): Not using default mode "400x300" (bad mode clock/interlace/doublescan)
(II) fglrx(0): Not using default mode "1024x768" (bad mode clock/interlace/doublescan)
(II) fglrx(0): Not using default mode "512x384" (bad mode clock/interlace/doublescan)
(II) fglrx(0): Not using default mode "1024x768" (vrefresh out of range)
(II) fglrx(0): Not using default mode "1152x864" (vrefresh out of range)
(II) fglrx(0): Not using default mode "576x432" (bad mode clock/interlace/doublescan)
(II) fglrx(0): Not using default mode "640x480" (bad mode clock/interlace/doublescan)
(II) fglrx(0): Not using default mode "1280x960" (hsync out of range)
(II) fglrx(0): Not using default mode "640x512" (bad mode clock/interlace/doublescan)
(II) fglrx(0): Not using default mode "1280x1024" (vrefresh out of range)
(II) fglrx(0): Not using default mode "1280x1024" (hsync out of range)
(II) fglrx(0): Not using default mode "800x600" (bad mode clock/interlace/doublescan)
(II) fglrx(0): Not using default mode "1600x1200" (vrefresh out of range)
(II) fglrx(0): Not using default mode "1600x1200" (hsync out of range)
(II) fglrx(0): Not using default mode "896x672" (bad mode clock/interlace/doublescan)
(II) fglrx(0): Not using default mode "1792x1344" (hsync out of range)
(II) fglrx(0): Not using default mode "1856x1392" (hsync out of range)
(II) fglrx(0): Not using default mode "928x696" (bad mode clock/interlace/doublescan)
(II) fglrx(0): Not using default mode "1920x1440" (hsync out of range)
(II) fglrx(0): Not using default mode "960x720" (bad mode clock/interlace/doublescan)
(II) fglrx(0): Not using default mode "832x624" (vrefresh out of range)
(II) fglrx(0): Not using default mode "416x312" (bad mode clock/interlace/doublescan)
(II) fglrx(0): Not using default mode "1152x768" (vrefresh out of range)
(II) fglrx(0): Not using default mode "576x384" (bad mode clock/interlace/doublescan)
(II) fglrx(0): Not using default mode "700x525" (bad mode clock/interlace/doublescan)
(II) fglrx(0): Not using default mode "1400x1050" (vrefresh out of range)
(II) fglrx(0): Not using default mode "800x512" (bad mode clock/interlace/doublescan)
(II) fglrx(0): Not using default mode "2048x1536" (hsync out of range)
(II) fglrx(0): Not using default mode "2048x1536" (bad mode clock/interlace/doublescan)
(II) fglrx(0): Not using default mode "1792x1344" (width too large for virtual size)
(II) fglrx(0): Not using default mode "1600x1200" (width too large for virtual size)
(II) fglrx(0): Not using default mode "1400x1050" (width too large for virtual size)
(--) fglrx(0): Virtual size is 1280x1024 (pitch 1280)
(**) fglrx(0): *Default mode "1280x1024": 108.0 MHz, 64.0 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1280x1024" 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
(**) fglrx(0): Default mode "1792x1344": 204.8 MHz, 83.7 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1792x1344" 204.80 1792 1920 2120 2448 1344 1345 1348 1394 -hsync +vsync
(**) fglrx(0): Default mode "1600x1200": 162.0 MHz, 75.0 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1600x1200" 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync
(**) fglrx(0): Default mode "1400x1050": 122.0 MHz, 64.9 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1400x1050" 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync
(**) fglrx(0): Default mode "1280x960": 108.0 MHz, 60.0 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1280x960" 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync
(**) fglrx(0): Default mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1024x768" 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync
(**) fglrx(0): Default mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
(II) fglrx(0): Modeline "800x600" 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync
(**) fglrx(0): Default mode "640x480": 25.2 MHz, 31.5 kHz, 60.0 Hz
(II) fglrx(0): Modeline "640x480" 25.20 640 656 752 800 480 490 492 525 -hsync -vsync
(II) fglrx(0): Valid Clone Mode: 1280x1024
(II) fglrx(0): Valid Clone Mode: 1280x960
(II) fglrx(0): Valid Clone Mode: 1024x768
(II) fglrx(0): Valid Clone Mode: 800x600
(II) fglrx(0): Valid Clone Mode: 640x480
(II) fglrx(0): Total of 5 clone modes found ------------
(II) fglrx(0): Validating modes on Primary head ---------
(==) fglrx(0): DPI set to (75, 75)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/modules/libfb.a
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.2
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/lib/modules/libramdac.a
(II) Module ramdac: vendor="X.Org Foundation"
(**) fglrx(0): NoAccel = NO
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/lib/modules/libxaa.a
(II) Module xaa: vendor="X.Org Foundation"
(==) fglrx(0): HPV inactive
(==) fglrx(0): FSAA enabled: NO
(**) fglrx(0): FSAA Gamma enabled
(**) fglrx(0): FSAA Multisample Position is fix
(**) fglrx(0): NoDRI = NO
(II) Loading sub module "fglrxdrm"
(II) LoadModule: "fglrxdrm"
(II) Loading /usr/lib/modules/linux/libfglrxdrm.a
(II) Module fglrxdrm: vendor="FireGL - ATI Technologies Inc."
(II) fglrx(0): Depth moves disabled by default
(**) fglrx(0): Capabilities: 0x00000000
(**) fglrx(0): cpuFlags: 0x8000001d
(**) fglrx(0): cpuSpeedMHz: 0x00000bbf
(==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
(**) fglrx(0): using built in AGPGART module: yes
(**) fglrx(0): UseFastTLS=0
(**) fglrx(0): BlockSignalsOnLock=1
(==) fglrx(0): EnablePrivateBackZ = NO
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 0 0 0xf9000000 - 0xf900ffff (0x10000) MX[B]
[1] 0 0 0xf0000000 - 0xf7ffffff (0x8000000) MX[B]
[2] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
[3] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[4] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[5] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[6] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[7] -1 0 0xfa004000 - 0xfa005fff (0x2000) MX[B]
[8] -1 0 0xfa006000 - 0xfa0060ff (0x100) MX[B]
[9] -1 0 0xfa000000 - 0xfa003fff (0x4000) MX[B]
[10] -1 0 0xfa007000 - 0xfa0077ff (0x800) MX[B]
[11] -1 0 0xfa102000 - 0xfa1020ff (0x100) MX[B]
[12] -1 0 0xfa101000 - 0xfa1011ff (0x200) MX[B]
[13] -1 0 0xfa100000 - 0xfa1003ff (0x400) MX[B]
[14] -1 0 0xe8000000 - 0xe7ffffff (0x0) MX[B]O
[15] -1 0 0xf9000000 - 0xf900ffff (0x10000) MX[B](B)
[16] -1 0 0xf0000000 - 0xf7ffffff (0x8000000) MX[B](B)
[17] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[18] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[19] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[20] 0 0 0x00009000 - 0x000090ff (0x100) IX[B]
[21] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[22] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[23] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[24] -1 0 0x0000dc00 - 0x0000dc3f (0x40) IX[B]
[25] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[26] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
[27] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[28] -1 0 0x0000b800 - 0x0000b81f (0x20) IX[B]
[29] -1 0 0x0000b400 - 0x0000b41f (0x20) IX[B]
[30] -1 0 0x0000b000 - 0x0000b01f (0x20) IX[B]
[31] -1 0 0x0000bc00 - 0x0000bc1f (0x20) IX[B]
[32] -1 0 0x00009000 - 0x000090ff (0x100) IX[B](B)
[33] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[34] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) fglrx(0): UMM area: 0xf0701000 (size=0x038ff000)
(II) fglrx(0): driver needs XFree86 version: 4.3.x
(WW) fglrx(0): could not detect XFree86 version (query_status=-3)
(II) Loading extension ATIFGLRXDRI
(II) fglrx(0): doing DRIScreenInit
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is 4, (OK)
drmOpenByBusid: Searching for BusID PCI:1:0:0
drmOpenByBusid: drmOpenMinor returns 4
drmOpenByBusid: drmGetBusid reports
drmOpenDevice: node name is /dev/dri/card1
drmOpenDevice: open result is -1, (No such device)
drmOpenDevice: Open failed
drmOpenByBusid: drmOpenMinor returns -1023
drmOpenDevice: node name is /dev/dri/card2
drmOpenDevice: node name is /dev/dri/card3
drmOpenDevice: node name is /dev/dri/card4
drmOpenDevice: node name is /dev/dri/card5
drmOpenDevice: node name is /dev/dri/card6
drmOpenDevice: node name is /dev/dri/card7
drmOpenDevice: node name is /dev/dri/card8
drmOpenDevice: node name is /dev/dri/card9
drmOpenDevice: node name is /dev/dri/card10
drmOpenDevice: node name is /dev/dri/card11
drmOpenDevice: node name is /dev/dri/card12
drmOpenDevice: node name is /dev/dri/card13
drmOpenDevice: node name is /dev/dri/card14
drmGetBusid returned ''
(II) fglrx(0): [drm] DRM interface version 1.0
(II) fglrx(0): [drm] created "fglrx" driver at busid "PCI:1:0:0"
(II) fglrx(0): [drm] added 8192 byte SAREA at 0xe098a000
(II) fglrx(0): [drm] mapped SAREA 0xe098a000 to 0xb7d76000
(II) fglrx(0): [drm] framebuffer handle = 0xf0000000
(II) fglrx(0): [drm] added 1 reserved context for kernel
(II) fglrx(0): DRIScreenInit done
(II) fglrx(0): Kernel Module Version Information:
(II) fglrx(0): Name: fglrx
(II) fglrx(0): Version: 8.8.25
(II) fglrx(0): Date: Jan 14 2005
(II) fglrx(0): Desc: ATI FireGL DRM kernel module
(II) fglrx(0): Kernel Module version matches driver.
(II) fglrx(0): Kernel Module Build Time Information:
(II) fglrx(0): Build-Kernel UTS_RELEASE: 2.6.10-gentoo-r6
(II) fglrx(0): Build-Kernel MODVERSIONS: no
(II) fglrx(0): Build-Kernel __SMP__: no
(II) fglrx(0): Build-Kernel PAGE_SIZE: 0x1000
(II) fglrx(0): [drm] register handle = 0xf9000000
(II) fglrx(0): [agp] Mode=0x1f004217 bridge: 0x8086/0x2570
(II) fglrx(0): [agp] AGP v1/2 disable mask 0x00000000
(II) fglrx(0): [agp] AGP v3 disable mask 0x00000000
(II) fglrx(0): [agp] enabling AGP with mode=0x1f004314
(II) fglrx(0): [agp] AGP protocoll is enabled for grafics board. (cmd=0x1f000314)
(II) fglrx(0): [agp] grafics chipset has AGP v2.0
(II) fglrx(0): [drm] ringbuffer size = 0x00100000 bytes
(II) fglrx(0): [drm] DRM buffer queue setup: nbufs = 100 bufsize = 28672
(II) fglrx(0): [drm] texture shared area handle = 0xe4c01000
(II) fglrx(0): shared FSAAScale=1
(II) fglrx(0): DRI initialization successfull!
(II) fglrx(0): FBADPhys: 0xf0000000 FBMappedSize: 0x00701000
(II) fglrx(0): FBMM initialized for area (0,0)-(1280,1434)
(II) fglrx(0): FBMM auto alloc for area (0,0)-(1280,1024) (front color buffer - assumption)
(==) fglrx(0): Backing store disabled
(==) fglrx(0): Silken mouse enabled
(II) fglrx(0): Using hardware cursor (scanline 1024)
(II) fglrx(0): Largest offscreen area available: 1280 x 402
(WW) fglrx(0): Option "ConnectedMonitor" is not used
(II) fglrx(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
8x8 mono pattern filled rectangles
Solid Lines
Dashed Lines
Offscreen Pixmaps
Setting up tile and stipple cache:
30 128x128 slots
(II) fglrx(0): Acceleration enabled
(II) fglrx(0): X context handle = 0x00000001
(II) fglrx(0): [DRI] installation complete
(II) fglrx(0): Direct rendering enabled
(II) Loading extension FGLRXEXTENSION
(II) Loading extension ATITVOUT
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(**) Option "Protocol" "ExplorerPS/2"
(**) Mouse1: Device: "/dev/mouse"
(**) Mouse1: Protocol: "ExplorerPS/2"
(**) Option "CorePointer"
(**) Mouse1: Core Pointer
(**) Option "Device" "/dev/mouse"
(==) Mouse1: Emulate3Buttons, Emulate3Timeout: 50
(==) Mouse1: Buttons: 3
(**) Mouse1: SmartScroll: 1
(**) Option "CoreKeyboard"
(**) Keyboard1: Core Keyboard
(**) Option "Protocol" "standard"
(**) Keyboard1: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xfree86"
(**) Keyboard1: XkbRules: "xfree86"
(**) Option "XkbModel" "pc101"
(**) Keyboard1: XkbModel: "pc101"
(**) Option "XkbLayout" "us"
(**) Keyboard1: XkbLayout: "us"
(**) Option "CustomKeycodes" "off"
(**) Keyboard1: CustomKeycodes disabled
(II) XINPUT: Adding extended input device "Keyboard1" (type: KEYBOARD)
(II) XINPUT: Adding extended input device "Mouse1" (type: MOUSE)
(II) Mouse1: ps2EnableDataReporting: succeeded
Could not init font path element /usr/X11R6/lib/X11/fonts/local/, removing from list!
(II) fglrx(0): [drm] removed 1 reserved context for kernel
(II) fglrx(0): [drm] unmapping 8192 bytes of SAREA 0xe098a000 at 0xb7d76000
Ubuntu 7.04 + Pinnacle PCTV = slika super, zvoka ni - Linux n00b here (strani: 1 2 )
Oddelek: Operacijski sistemi
707843 (5284) poweroff
X server in Nvidia na FC#
272433 (2260) HellRaiseR
kde in resolucija
101959 (1827) moj_nick
xserver-xree86
61859 (1771) Skrat
Linux / ATI Radeon / problem z driverji
132189 (2006) ahac
