problem z paint.net
problem z paint.net
tyxXx ::
torej ....
situacija je taka hocem instalirat PaintDotNet_2_0 in ko hocem instalirat mam tm za izbrt repair ali remove paint.net ..... ce dam repair ali remove mi napise naslednje -> There is a problem with Windows installer package . A program run as part of the setup did not finish as expected . Contact your support ......
Torej kaj naj
(paint net pa rabim za msn 7.0 ce hocem met za risat ) :D
še screeni ->
klik
klik
klik
  • spremenil: tyxXx ()
Samodejno Undreclockanje proca AMD (CPU Z) !!!???
212488 (1962) njok
Microsoft Windows AntiSpyware Beta1
Oddelek: Operacijski sistemi
375305 (3254) Myth
Moja kištica ohladi se z vodo in en kup vodnih blokov lastne izdelave (strani: 1 2 )
7713632 (10694) Privatnik
program za spyware
Oddelek: Programska oprema
111743 (1610) gofra
Smack The Pingu tekmovanje (strani: 1 2 )
716603 (4541) DMouse
