PC
PC
_Mortal_ ::
Nism vedu kam da to uštulm pa sem dal sm ne zaklent plis
Every morning is the dawn of a new error...
Cannot find REALITY.SYS. Universe halted.
COFFEE.EXE Missing - Insert Cup and Press Any Key to continue.
Buy a Pentium II so you can reboot faster.
Computers make very fast, very accurate mistakes.
Computers are not intelligent. They only think they are.
My software never has bugs. It just develops random features.
Best file compression around: "DEL *.*" = 100% compression.
The Definition of an Upgrade: Take old bugs out, put new ones in.
BREAKFAST.COM Halted. Cereal Port Not Responding.
The name is Baud, James Baud.
Access denied. Thought you could get in?
Bad command or file name! Go stand in the corner.
Bad command. Bad, bad, command! Sit! Bark! Stay!
Why doesn't DOS ever say "EXCELLENT command or filename?"
As a computer, I find your faith in technology amusing.
File not found. Should I fake it? (y/n)
Ethernet: Something used to catch the EtherBunny.
An error? Impossible! My modem is error correcting.
CONGRESS.SYS Corrupted: Reboot Washington D.C? (y/n)
Does fuzzy logic tickle?
11th commandment: Desire not your neighbor's Pentium II or his 16xCD-R.
The magic of Windows: Turns a Pentium into an XT, instantly.
SENILE.COM found. Out Of Memory.
Who's General Failure and why is he reading my disk?
Ultimate office automation: networked coffee.
Shell to DOS... Come in DOS, this is Shell calling, do you copy?
All computers wait at the same speed.
Defination of a computer: A device designed to speed up and automate errors.
AscII a stupid question, get a stupid ANSI!
E-mail returned to sender. Insufficient voltage.
Hex dump: Where witches leave their used curses.
Do witches run spell checkers?
Smash forehead on keyboard to continue.
Enter any 11-digit prime number to continue.
"640K ought to be enough for anybody" - Bill Gates, 1981
Press any key to continue or any other key to quit.
Backup not found: (A)bort ®etry (P)anic?
I used dip switches and connector wires to speed up my computer. It works just finE*Ĺä^'=ö:.¨~
Error! No keyboard detected. Press F1 to continue.
Error! No mouse detected. Click here to continue.
Error! Virus requires a different operating system.
Ever noticed how fast Windows runs? Neither did I.
Double your HD space, delete your operating system!
Is reading in the bathroom considered as multi-tasking?
My computer said that "Insert disk #3" but I couldn't get more than one disk fit in at a time!
Bug? That's not a bug, that's a random feature!
The computer programmer's national anthem is "AAAAAARRRRGGGGHHH!"
If at first you don't succeed, call it a version 1.0.
Asking if computers can think, is like asking if submarines can swim.
Todays UNIX command: "EXSOP" = Execute System Operator.
Computer programming is an artform that fights back.
Dad, what does "FORMATTING DRIVE C: 90% DONE" mean?
Windows loaded. System in danger.
No errors detected. Yet.
File Linking Error. Your mistake is now in every file.
Erroneous Error. Nothing is wrong.
Multitasking Attempted. System confused.
System Price Error. Inadequate money spent on hardware.
Broken Window. Watch out for glass fragments.
Horrible Bug Encountered. No idea what has happened.
Running low on diskspace. Free at least 2GB.
Windows Closed. You can't look outside now.
Unexplained Error. Please tell the programmer how is this possible.
Keyboard Locked. Try anything you can think of.
Illegal Error. You are not allowed to get this error, next time you will be punished.
Timing Error. Please wait, and wait, and wait, and wait...
Process running. If not ready in 10 minutes, wait longer.
This will end your Windows session, do you wish to play another game?
Timeout Error. Operator fell asleep waiting for the system to boot.
Error! Computer hungry. Insert hamburger in drive A: and press Y to continue.
Error! Programmer running out of cash. Insert Wallet in drive A: and remove when empty.
element ::
Ej, komi sm se prebil čez. Drugač pa tole 100% ne spada pod igre. Pod ložo bl. :D
_Mortal_ ::
Če ti se pojavljajo črte nevm zakaj se je to zgodil
element ::
Se pojavljajo ja. ;((
_Mortal_ ::
Vem samo nevem zakaj???;(;((
element ::
Jest tud ne vem zakaj! >:D Mogoče je preveč bullshita, pa se je server uprl. >:D
[t502] ::
lol
Skoda za crte
[t502]
OmegaBlue ::
Otroc. Premaknil in popravil - nevem kje vidiš smisel tega..
Gapi ::
OmegaBlue: Iskal sem sicer neki druzga pa najdu tole pa da nism naredu samo kak bump da se tema obnovi ker niso slabi izreki sem imel preveč časa da sem to naredu, Da pa si ti to brisal ker sem zasedu samo nekaj bitov več kot bi lahko mi pa ni glih všeč. Drugič lahko pričakujem da me boš iz foruma dol vrgu ker ti moje pisanje ni všeč. Aja pa str sm 31 let . Mogoč nemunen kot 7 letnik ker bi 7 let rad mel ponovno.
OmegaBlue ::
Brisano je zato ker je dobesedno identično tistemu zgoraj in nevem kje imaš veselje ožviljat 4 leta staro temo.
Gapi ::
Veselja sicer nimam a imel sem čas.Tako kot ga mam sedaj da ponovno dam ta thread malo višje in da ga še kdo opazi.
Sicer je stvar taka da je bil text ki je bil v original postu prečrtan in je bil težje berljiv. Trik z notepadom je pa naredu svoje.
vista problem
153706 (3365) markk1
seatools
202379 (2224) StratOS
Kako rešiti podatke???
Oddelek: Programska oprema
61882 (1799) dr.J
Najbolj neumno vprašanje? (strani: 1 2 )
548999 (7907) Mike
Podpisi...
212210 (1746) DrSergioDJ
