Na novo naloženi SuSE 9.1 ne prepozna modema
eX ::
Pozdrav!
Na novo naloženi SuSE 9.1 ne reagira (ne prepozna?) modema - U.S. Robotics 56K Fax Host Int (2f10x)
Ko zaženem komando "lspci -v" dobim:
0000:00:10.0 Communication controller: Conexant: Unknown device 2f10 (rev 01)
Subsystem: U.S. Robotics: Unknown device 2013
Flags: bus master, medium devsel, latency 64, IRQ 10
Memory at febf0000 (32-bit, non-prefetchable)
I/O ports at eff0 [size=8]
Capabilities: [40] Power Management version 2
Sumim da je to še eden tistih "winmodemov", ki v osnovi nimajo podpore za linux, pa me zanima, kako konkretno bi sistem pripravil do tega, da zazna modem.
Hvala!
Skrat ::
Malo pobrskaj po linmodems.org
Free software is a matter of liberty, not price.
Tisti, ki se spoznate na predpotopne racunalnike, kolk je to vredno?
51401 (1203) ]Fusion[
Same težave z linuxom. Pomoč dobrodošla
Oddelek: Operacijski sistemi
191525 (1260) Sahel
Linux rookie
242477 (2055) dr.J
ISDN modem
5983 (873) Joze_K
modem connection speed
181841 (1633) Koci
