Forum » Programiranje » [php] timestamp 0 sekund vrne 01:00:00 zakaj?
cryptozaver ::
Ni mi jasno zakaj dobim tole: (psevdokoda)
date("H:i:s", 0 sekund) = 01:00:00
date("H:i:s", 1800 sekund) = 01:30:00 .......
oz kaj bi naredil da vrne 00:00:00
Hvala za namig?
Hvala za namig?
- spremenilo: cryptozaver ()
McAjvar ::
date ti vrne oblikovan niz, glede na drugi parameter, timestamp. v manualu je tole zraven:
date ("neki", 0) ti torej vrne cas, ko bi timestamp vrnil 0, se pravi nekje v prejsnjem tisocletju. ocitno so zacel stet ob enih zjutrej :) moral se bos problema drugace lotit. ce mas to kot neke vrste stoparico al kej tazga, lahko poskusis s kakim trikom, npr:
$diff = $t2 - $t1;
$diff += 23 * 60 * 60;
$date = date("H:i:s", $diff);
The valid range of a timestamp is typically from Fri, 13 Dec 1901 20:45:54 GMT to Tue, 19 Jan 2038 03:14:07 GMT. (These are the dates that correspond to the minimum and maximum values for a 32-bit signed integer). On Windows this range is limited from 01-01-1970 to 19-01-2038.
$diff = $t2 - $t1;
"[...] the advance of civilization is nothing
but an exercise in the limiting of privacy."
- Isaac Asimov
- Isaac Asimov
| » | Davčne blagajne - PHPOddelek: Programiranje | 6682 (1728) | vsepocenv |
| » | MiniPC, hw NUC in BrixOddelek: Strojna oprema | 2965 (2289) | 2f4u |
| » | datetime polje, kako v selectu določiti samo datumOddelek: Izdelava spletišč | 1151 (1049) | darh |
| » | Čudno PHP vprašanjeOddelek: Izdelava spletišč | 1260 (1136) | Loki |
| » | PHP and GMTOddelek: Programiranje | 1222 (1114) | ilanium |
