[php] timestamp 0 sekund vrne 01:00:00 zakaj?
cryptozaver ::
Ni mi jasno zakaj dobim tole: (psevdokoda)
date("H:i:s", 0 sekund) = 01:00:00
date("H:i:s", 1800 sekund) = 01:30:00 .......
oz kaj bi naredil da vrne 00:00:00
Hvala za namig?
Vesoljc ::
McAjvar ::
date ti vrne oblikovan niz, glede na drugi parameter, timestamp. v manualu je tole zraven:
The valid range of a timestamp is typically from Fri, 13 Dec 1901 20:45:54 GMT to Tue, 19 Jan 2038 03:14:07 GMT. (These are the dates that correspond to the minimum and maximum values for a 32-bit signed integer). On Windows this range is limited from 01-01-1970 to 19-01-2038.
date ("neki", 0) ti torej vrne cas, ko bi timestamp vrnil 0, se pravi nekje v prejsnjem tisocletju. ocitno so zacel stet ob enih zjutrej :) moral se bos problema drugace lotit. ce mas to kot neke vrste stoparico al kej tazga, lahko poskusis s kakim trikom, npr:
$diff = $t2 - $t1;
$diff += 23 * 60 * 60;
$date = date("H:i:s", $diff);
"[...] the advance of civilization is nothing
but an exercise in the limiting of privacy."
- Isaac Asimov
Davčne blagajne - PHP
Oddelek: Programiranje
116697 (1743) vsepocenv
MiniPC, hw NUC in Brix
142980 (2304) 2f4u
datetime polje, kako v selectu določiti samo datum
Oddelek: Izdelava spletišč
51167 (1065) darh
Čudno PHP vprašanje
51272 (1148) Loki
PHP and GMT
131233 (1125) ilanium
