Mejli v Outlook Express izginili...?!
Azz_Kikr ::
Prejle sem zagnal Outlook Expres in videl, da mi je izbrisal čez 500 e-mailov. Kaj to pomeni? V mapi z datitekami s pošto pa je nastal tale dokument:
Outlook Express 6.00.2800.1123
CLEANUP Log started at 11/06/2004 03:23:45
CLEANUP: 03:23:45 [db] C:\Documents and Settings\Robert Roskar\Local Settings\Application Data\Identities\{50018877-5DC3-47FB-A65A-27175719D975}\Microsoft\Outlook Express
CLEANUP: 03:23:51 [db] Starting Background Cleanup Cycle...
CLEANUP: 03:23:57 [db] Deleted Items.dbx, CompactAt: 20%, Wasted: 06%, File: 137896048, Records: 00000019, Allocated: 137780136, Freed: 137644752, Streams: 00156816, RemovedRead: 0, RemovedExpired: 0, JunkDeleted: 0
CLEANUP: 03:23:57 [db] Drafts.dbx, CompactAt: 20%, Wasted: 00%, File: 000060116, Records: 00000000, Allocated: 000000080, Freed: 00000000, Streams: 00000000, RemovedRead: 0, RemovedExpired: 0, JunkDeleted: 0
CLEANUP: 03:23:57 [db] Inbox.dbx, CompactAt: 20%, Wasted: 00%, File: 1958526576, Records: 00000441, Allocated: 1958260020, Freed: 57675920, Streams: 04518096, RemovedRead: 0, RemovedExpired: 0, JunkDeleted: 0
CLEANUP: 03:23:57 [db] Outbox.dbx, CompactAt: 20%, Wasted: 00%, File: 000060116, Records: 00000000, Allocated: 000000080, Freed: 00000000, Streams: 00000000, RemovedRead: 0, RemovedExpired: 0, JunkDeleted: 0
CLEANUP: 03:23:57 [db] Sent Items.dbx, CompactAt: 20%, Wasted: 00%, File: 814227568, Records: 00001269, Allocated: 814083140, Freed: 00112552, Streams: 813068256, RemovedRead: 0, RemovedExpired: 0, JunkDeleted: 0
CLEANUP: 03:23:57 [db] Folders.dbx, CompactAt: 20%, Wasted: 23%, File: 000074720, Records: 00000007, Allocated: 000003136, Freed: 00000732, Streams: 00000000, RemovedRead: 0, RemovedExpired: 0, JunkDeleted: 0
CLEANUP: 03:23:58 [db] Pop3uidl.dbx, CompactAt: 20%, Wasted: 00%, File: 000009404, Records: 00000000, Allocated: 000000000, Freed: 00000000, Streams: 00000000, RemovedRead: 0, RemovedExpired: 0, JunkDeleted: 0
CLEANUP: 03:23:58 [db] Offline.dbx, CompactAt: 20%, Wasted: 00%, File: 000009656, Records: 00000000, Allocated: 000000000, Freed: 00000000, Streams: 00000000, RemovedRead: 0, RemovedExpired: 0, JunkDeleted: 0
CLEANUP Log started at 11/06/2004 03:27:40
CLEANUP: 03:27:41 [db] C:\Documents and Settings\Robert Roskar\Local Settings\Application Data\Identities\{50018877-5DC3-47FB-A65A-27175719D975}\Microsoft\Outlook Express
CLEANUP: 03:27:45 [db] Starting Background Cleanup Cycle...
CLEANUP Log started at 11/06/2004 03:31:20
CLEANUP: 03:31:20 [db] C:\Documents and Settings\Robert Roskar\Local Settings\Application Data\Identities\{50018877-5DC3-47FB-A65A-27175719D975}\Microsoft\Outlook Express
CLEANUP: 03:31:21 [db] Starting Background Cleanup Cycle...
CLEANUP: 03:31:21 [db] Deleted Items.dbx, CompactAt: 20%, Wasted: 06%, File: 137896048, Records: 00000000, Allocated: 137781928, Freed: 137815768, Streams: 00000000, RemovedRead: 0, RemovedExpired: 0, JunkDeleted: 0
CLEANUP: 03:31:21 [db] Drafts.dbx, CompactAt: 20%, Wasted: 00%, File: 000060116, Records: 00000000, Allocated: 000000080, Freed: 00000000, Streams: 00000000, RemovedRead: 0, RemovedExpired: 0, JunkDeleted: 0
CLEANUP: 03:31:22 [db] Inbox.dbx, CompactAt: 20%, Wasted: 00%, File: 1958526576, Records: 00000438, Allocated: 1958291468, Freed: 57727464, Streams: 04500672, RemovedRead: 0, RemovedExpired: 0, JunkDeleted: 0
CLEANUP: 03:31:22 [db] Outbox.dbx, CompactAt: 20%, Wasted: 00%, File: 000060116, Records: 00000000, Allocated: 000000080, Freed: 00000000, Streams: 00000000, RemovedRead: 0, RemovedExpired: 0, JunkDeleted: 0
CLEANUP: 03:31:22 [db] Sent Items.dbx, CompactAt: 20%, Wasted: 00%, File: 814227568, Records: 00001269, Allocated: 814083140, Freed: 00112552, Streams: 813068256, RemovedRead: 0, RemovedExpired: 0, JunkDeleted: 0
CLEANUP: 03:31:22 [db] Folders.dbx, CompactAt: 20%, Wasted: 32%, File: 000074720, Records: 00000007, Allocated: 000003556, Freed: 00001160, Streams: 00000000, RemovedRead: 0, RemovedExpired: 0, JunkDeleted: 0
CLEANUP: 03:31:22 [db] Pop3uidl.dbx, CompactAt: 20%, Wasted: 00%, File: 000009404, Records: 00000000, Allocated: 000000000, Freed: 00000000, Streams: 00000000, RemovedRead: 0, RemovedExpired: 0, JunkDeleted: 0
CLEANUP: 03:31:22 [db] Offline.dbx, CompactAt: 20%, Wasted: 00%, File: 000009656, Records: 00000000, Allocated: 000000000, Freed: 00000000, Streams: 00000000, RemovedRead: 0, RemovedExpired: 0, JunkDeleted: 0
A kdo ve, kaj se je sploh zgodilo?
If sometimes you feel yourself little, useless, offended and depressed, always remember that you were once the fastest and most victorious sperm in your group!
Azz_Kikr ::
V bistvu izgleda, da imam nek corrupted .dbx fajl in ga noče odpreti. Videl sem namreč, da je velik 1,9 GB, kar pomeni, da se v njem skrivajo vsi moji mejli, samo OE jih noče ali ne more odpreti. Se da kakor koli popraviti ta fajl, da bodo moji mejli spet vidni? Hecno se mi zdi, da prav so v nekem fajlu, pa ne morem do njih :(
ToniT ::
Eden od teh programov bo sigurno pomagal.
OE ima eno omejitev: velikost fajlov je omejena na 2GB in zato ti je verjetno vse skupaj šlo v franže (glede na velikost inbox: 1,9GB....).
Požrešni Win7 na disku.
101615 (1225) Invictus
[Java]Problem z vektorjem
Oddelek: Programiranje
92043 (1912) KernelPanic
outlook express problem s količino
Oddelek: Programska oprema
62307 (2234) Duhec
Outlook resen problem.. od vedno za vedno
91938 (1733) Jackal
Outlook Express>prejeto-KAKO IZBRISATI???
93000 (2908) TinkaPinka
