Forum » Operacijski sistemi » gentoo stage 1 install
Zzzzzzz ::
Ob stage1 kompajlanju gentoo-ja mi vrne naslednji error (med kompajlanjem gettext 0.12.1-r2)
checking for C compiler default output... configure: error: C compiler cannot create executables
See 'cinfig.log' form more details.
configure: error: /bin/sh './configre' failed for autoconf-lib-link
!!! ERROR: sys-devel/gettext-0.12.1-r2 failed.
!!! function econf, Line 449, Exitcode 1
!!! econf failed
moj /etc/make.conf:
CFLAGS="-O2 -march=pentium-m -fomit-frame-pointer"
CHOST="i686-pc-linux-gnu"
CXFLAGS="${CFLAGS}"
MAKEOPTS="-j2"
Any ideas kaj bi lhko blo narobe?
!!! econf failed
moj /etc/make.conf:
CXFLAGS="${CFLAGS}"
MAKEOPTS="-j2"
BigWhale ::
Kateri step iz manuala si preskocil oziroma, ti ni delal tako kot bi pisalo, da mora ampak si ignoriral obvestilo o napaki? ;)
V kateri tocki pride do napake, malo vec informacij prosim... Saj ves kristalna krogla je na podstresju ;)
Zzzzzzz ::
Torej, moj postopek:
-> boot: smp nodhcp
-> net-setup
-> fdisk (3 particije: boot, / in swap)
-> mkreiserfs (dve particiji)
-> mkswap /dev/hda3
-> swapon /dev/hda3
-> mount /dev/hda4 /mnt/gentoo
-> mkdir /mnt/gentoo/boot
-> mount /dev/hda2 /mnt/gentoo/boot
-> download stage1 tarball v /mnt/gentoo
-> un-tar stage1 tarball
-> poštimal konfiguracijo (glej zgoraj: /etc/make.conf)
-> cp -L /etc/resolv.conf /mnt/gentoo/etc/resolv.conf
-> mount -t proc none /mnt/gentoo/proc
-> chroot /mnt/gentoo /bin/bash
-> env-update
-> source /etc/profile
-> emerge --sync
-> cd /usr/portage
-> scripts/bootstrap.sh
skript se zažene in potem javi tisti error (še prej pa normalno skompajla se mi zdi da 3 pakete)
-> boot: smp nodhcp
-> net-setup
-> mkswap /dev/hda3
-> swapon /dev/hda3
-> env-update
-> emerge --sync
-> cd /usr/portage
Zzzzzzz ::
sm rešu problem.
fora je bla v tem, da je po defaultu na gentoo-ju gcc 3.2 oz. 3.3, ki ne podpira flaga -march=pentium-m. To sem zamenjal z -march=pentium3 in dela OK. Poštimal sem tudi, da v bootstrapu nardi tudi gcc verzije 3.4, ki podpira ta flag. če slučajno koga zanima: tu je link
zee ::
Dve vprašanji bolj za hec kot ne.
Kaj dvoživke ne štejemo?
A ni march=pentium-m načelom enak march=pentium4? Doma imam namreč tako Pentiuma 4 kot M, pa sem Gentoo iz P4 kar prekopiral na M, pa je delalo brez problema potem ko sem še enkrat predel jedro, gonilnike za grafično (P4-Ati, P-M-Nvidia) in nastavil Xe.
zee
| » | Gentoo Xorg.conf LCD - sistem se obesiOddelek: Operacijski sistemi | 2117 (1910) | Mr.B |
| » | Gentoo Nforce mreža ne dela razen z LiveCD-jemOddelek: Operacijski sistemi | 1831 (1723) | nicjasno |
| » | unmergal sem gccOddelek: Operacijski sistemi | 2351 (2097) | borchi |
| » | Gentoo in dual bootOddelek: Operacijski sistemi | 1462 (1323) | moj_nick |
| » | Gentoo - Install from Stage1 (strani: 1 2 )Oddelek: Operacijski sistemi | 4491 (4003) | noraguta |
