Forum » Navijanje » KQYHA stepping
KQYHA stepping
prehlajeni ::
Ojla!
Kupil sem nov proc in te dni še nisem mel časa se z njim igrat. Ker se mi zdi da gre za malo čuden stepping oz. ga še nisem nikjer na tabli videll (začne se z K), bi vas prosil da malo ga malo pokomentirate, da se ne bom brezveze zaj***val če sem kak len proc kupil. Iskal sem tud po googlu pa ni kaj preveč najdu o tem amd-ju.
prepis z proca:
____________________________
AMD Athlon
AXDA2600DKV4D T887776G41163
KQYHA 0427GPBW 1999AMD
hvala in lp
prepis z proca:
AMD Athlon
hvala in lp
Moonman ::
Hmm, probaj pa boš vedel. Še posebej, ker imaš stepping, ki ga nima še noben tukaj.
Poročaj o napredku, da bomo videli če je ta stepping kaj prida.
prehlajeni ::
hmmm... tole je z enga tujga foruma:
...upam da bom mel dons kej cajta mojga sprobat
New CPU on it's way:
AXDA2600KV4D KQYHA 0418SPCW
Suppose to be a good one.....
Well, it's here and it is a AXDA2600KV4D KQYHA 0418SPCW just like it's suppose to be...
Testing on the Jetway N2PAP-Ultra with Water Cooling shows these CPU's to be good overclockers....
Specs:
Vcore=1.85V
Vdd=1.9V
Vdimm=2.8V on PMI Turbo PC4500 8/4/4/3
CPU Temp= 31°C
The Jetway would POST at 11.5X240(2.76Gig!) but a BIOS fluke in that area caused some problems...
11.5X235(2.7Gig) booted into Windows2000, but crashed the Operating System....
11.5X230(2.645Gig) booted right up just fine and I'm posting with the system right now... [Big Grin]
11.5X230 is almost the same speed as 11X240 and what this tells me that this is a great CPU for people that can't get their boards to 240 to 250, but stll want 2.64Gig with "boot up stability"...
I'm quite happy with the 1st KQYHA I have ever seen.... [ThumbsUp]
EDIT: Note that about 6 weeks ago I tested a AQYHA 2600 0408 and 11.5X205 was it's limit....
I like it so much, I ordered a 2nd one.. Tonight I'll try this one in a Shuttle setup....
Hmmm.... bad news, the Shuttle repeats the results, but at 5Mhz lower FSB's....
A 2nd AXDA2600KV4D KQYHA 0418SPCW arrived today... If it's as good as the 1st, I'll be a happy camper.... [Big Grin]
Moonman ::
Zgleda dobro.
Upajmo, da tvoj skriva enak potencial.
Kje si ga kupil?
Kje si ga kupil?
- spremenilo: Moonman ()
prehlajeni ::
...vceri sem mal na hitr probal pa zadeva dela na 200 x 11,5 stabilno (30 min - se mi je mudil) brez dvigivanje voltaže ...več nisem šel ...morm dobit drug kulr
| » | Baza AMD-jevih steppingov (strani: 1 2 3 4 5 )Oddelek: Navijanje | 46880 (19664) | peter_ki |
| » | AMD procesorjiOddelek: Navijanje | 2770 (1855) | Tic |
| » | ABIT NF7-S in AMD Athlon XP 2600+Oddelek: Navijanje | 2204 (1795) | Tilen |
| » | Problem novi barton 2600 vs.2×512 vs.epox 8rda+!! (strani: 1 2 )Oddelek: Navijanje | 4761 (4118) | kajzer |
| » | kolk navit 2600+Oddelek: Navijanje | 2158 (1353) | Tugo |
