Invalid SQL
Invalid SQL
Hammer ::
tole mi napiše:
Invalid SQL:
SELECT calendarpermission.usergroupid, calendarpermission.calendarpermissions,calendar.calendarid,calendar.title, displayorder
FROM calendar AS calendar
LEFT JOIN calendarpermission AS calendarpermission ON (calendarpermission.calendarid=calendar.calendarid AND usergroupid IN(, , , , , , , , 6))
ORDER BY displayorder ASC
mysql error: You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near ' , , , , , , , 6))
ORDER BY displayorder ASC' at line 3
mysql error number: 1064
Kako to popravit ?
LP, hammer
arch5 ::
sej ti piše
tole: (, , , , , , , , 6) ga moti nadomesti z (6) tako da bo usergroupid IN(6) ali pa usergroupid =6
Hammer ::
Kako pa to spremenim, oziroma katero datoteko naj spremenim?
arch5 ::
tisto v kateri se ti tole izvaja
problem pri sprembi root gesla v MySQL v Ubuntu
231708 (1288) killa bee
MySQL BETWEEN dates?
Oddelek: Programiranje
111774 (1688) Housy
SQL problem
91940 (1777) Bossek
mysql vprasanje (update)
51293 (1203) MUC
easy way za odštevat datume
Oddelek: Izdelava spletišč
51266 (1156) Uporabnik
