knoppix
knoppix
simbad ::
Oj, a se da kako CD verzijo pripravit, da bi samostjno delala brez CDja oz, da bi ta Cd posnel na disk? Imam verzijo 2.4 :\
ql000 ::
evo lenobca: :D iz: http://www.knoppix.org/ FAQ -a
Q: Can one also install the distribution from the CD onto a hard drive?
A: In principal, yes (after all, the "master" system also runs on a hard
drive before it is burned to CD). However there is currently no
installation GUI for this, so installation to a hard drive should probably
only be attempted by more knowledgeable Linux users. Assuming the KNOPPIX
system has already booted, installation approximately follows this
procedure:
1.) initialize a free partition with the ext2 file system and mount it on
/mnt/knoppix, for example.
2.) cp -a /KNOPPIX/* /mnt/knoppix/
3.) set up /mnt/knoppix/etc/fstab and /mnt/knoppix/etc/lilo.conf for the
new system (Caution: symlinks in /boot initially point to the Ram
disk!), run lilo.
4.) mkdir /mnt/knoppix/home/knoppix && \
chown knoppix.knoppix /mnt/knoppix/home/knoppix
5.) Reboot, try the system out, fix any broken settings.
(No guarantees.)
Ni glih biser za install, ampak nobody's perfect!
hruske ::
poor man's install
Disk je crknil...
71131 (909) mat xxl
Iščem živo distribucijo linux-a
Oddelek: Programska oprema
112367 (1908) bluefish
Slo-techov linux
Oddelek: Operacijski sistemi
161816 (1488) pobcc
Linux / net
222045 (1718) roscha
kako "odformatirat" trdi disk
121557 (1276) NevarHere
