OpenBSD in gigabitna mreza
KoKi ::
Ve kdo, ce se bi dalo kje v sloveniji dobit gigabitno mrezno, ki bi bila podprta v OpenBSD?
Mrezne ki so podprte:
Gigabit Ethernet Adapters
* Alteon Tigon I/II-based adapters (ti), including: (A) (B) (C)
o 3Com 3c985 and 3c985B
o Alteon ACEnic V (fiber and copper)
o Digital EtherWORKS 1000SX
o Farallon PN9000SX
o Netgear GA620 and GA620T
o SGI Tigon
* Intel i82540, i82542, i82543, i82544, i82545, and i82546 based adapters (em), including:
o Intel PRO/1000 Gigabit Server Adapter (SX Fiber) (PWLA8490)
o Intel PRO/1000F Gigabit Server Adapter (SX Fiber) (PWLA8490SX)
o Intel PRO/1000T Server Adapter (PWLA8490T)
o Intel PRO/1000XT Server Adapter (PWLA8490XT)
o Intel PRO/1000XS Server Adapter (SX Fiber) (PWLA8490XF)
o Intel PRO/1000T Desktop Adapter (PWLA8390T)
o Intel PRO/1000XTL Lo Profile PCI Server (PWLA8490XTL)
o Intel PRO/1000MT Desktop Adapter (PWLA8390MT)
o Intel PRO/1000MT Server Adapter (PWLA8490MT)
o Intel PRO/1000MT Dual Port Server Adapter (PWLA8492MT)
o Intel PRO/1000MF Server Adapter (SX Fiber) (PWLA8490MF)
o Intel PRO/1000MF Dual Port Server Adapter (SX Fiber) (PWLA8492MF)
o Intel PRO/1000MF Server Adapter (LX Fiber) (PWLA8490LX)
* National Semiconductor DP83820 and DP83821 based PCI adapters (nge), including: (A) (B) (C)
o Addtron AEG320T
o Ark PC SOHO-GA2500T (32-bit PCI) and SOHO-GA2000T (64-bit PCI)
o Asante FriendlyNet GigaNIX 1000TA and 1000TPC
o D-Link DGE-500T
o LinkSys EG1032 (32-bit PCI) and EG1064 (64-bit PCI)
o Netgear GA621
o Netgear GA622T
o SMC EZ Card 1000 (SMC9462TX)
o Surecom Technology EP-320G-TX
o Trendware TEG-PCITX (32-bit PCI) and TEG-PCITX2 (64-bit PCI)
* Level1 LXT1001 based PCI adapters (lge), including: (*)
This driver is currently untested. Feedback would be appreciated.
o SMC TigerCard 1000 (SMC9462SX)
o D-Link DGE-500SX
* Broadcom BCM570x (a.k.a. Tigon3) based PCI adapters (bge), including: (A) (B) (C)
o 3Com 3c996-T (10/100/1000baseTX)
o 3Com 3c996-SX (1000baseSX)
o 3Com 3c996B-T (10/100/1000baseTX)
o Dell PowerEdge 2550 integrated BCM5700 NIC (10/100/1000baseTX)
o SysKonnect SK-9D21 (10/100/1000baseTX)
o SysKonnect SK-9D41 (1000baseSX)
* Sundance/Tamarack TC9021 based PCI adapters (stge), including: (G)
o D-Link DGE-550T (10/100/1000baseTX)
o Antares Microsystems Gigabit Ethernet board
* SysKonnect and Marvell based GigE(sk), including: (A) (B) (C)
o SysKonnect SK-9821 (1000baseT)
o SysKonnect SK-9822 (dual 1000baseT)
o SysKonnect SK-9841 (1000baseLX)
o SysKonnect SK-9842 (dual 1000baseLX)
o SysKonnect SK-9843 (1000baseSX)
o SysKonnect SK-9844 (dual 1000baseSX)
o SysKonnect SK-9521 v2.0 (1000baseT 32-bit)
o SysKonnect SK-9821 v2.0 (1000baseT)
o SysKonnect SK-9843 v2.0 (1000baseSX)
o 3Com 3c940 (1000baseT)
o Linksys EG1032v2 (1000baseT)
o Linksys EG1064v2 (1000baseT)
o D-Link DGE-530T (1000baseT)
o SMC 9452TX (1000baseT)
SleepLess ::
najdel v 2min (mogoce se malo majn)-> INTEL PRO/1000 T SERVER ADAPTER
55.200, ce bi ti malo poiskal bi se mogoce najso kero cenejso varjanto ker intel je pac intel pa je dragi :)
http://www.autronic.si/html/mre_na_opre...
KoKi ::
Saj v tem je ravno fora, ker sem sam nasel od planeta (za 6k) in od level one (za 7k), samo nobena ni podprta v openbsd. 55k al pa 7k pa je "rahla" razlika.
Brane2 ::
Broadcom BCM570x (a.k.a. Tigon3) based PCI adapters (bge), including: (A) (B) ©
Tocno ta cip je v mojih dual Opteron Tyankah, prv tako v karticah, ki sem jih vzel pri JAEtu.
OpenBSDja ne uporabljam, delam z Linuxom in tam naceloma ni nekih vidnih tezav, je pa res da je bilo nekaj stosev z Jumbo Framei, ki so bili reseni sele v zadnjem 2.6.6 kernelu, vendar sam tudi prej nisem obcutil problemov. To je bolj za heavy userje...
Sem pogledal na fakturo:
Pri JAEtu je
ETHGC-LC03 (interna sklad. koda) "Etherne Gigabyte 10/100/1000 SERVER NIC", cena pa je bila takrat cca 16 kSIT z vstetim DDV. To berem s skoraj tocno 7 mesecev starega racuna (2x.11.2003)...
V kernelu uporabljam za to zadevo Tigon3 driver, ceprav je na voljo tudi alternativni Broadcomov driver...
Do sedaj sem s temi karticami povsem zadovoljen, Nisem imel se nobenih problemov. Oziroma raje receno, niti problemcka. :)
  • spremenil: Brane2 ()
Brane2 ::
Aja, se to. Mnoge teh karrtic dobiss tako za 32-bitni kot 64-bitni PCI. Cisto teoreticno PCI32 sicer zaadosca, a v praxi mislim da nima prevec smisla.
Ce ti plata to omogoca, vsekakor ubodi 64-bitno kartico.
Ne spomnim se vec, ali 64-bitna kartica dela tudi v 32-bitnem slotu. Ce dela, bi vzel 64-bitno ne glede na plato. Cisto toliko da bo vse nared, ko preides na 64-biten stroj,,,
matevzm2 ::
Preden te resno prime da bi kupil poceni kartico si poglej http://www.ixbt.com/comm/gig-eth-64bit-...
Zal je v grabljicah, a na prvi strani imas spisek in slike kartic, na drugi pa z angleskimi naslovi opremljene grafe. Na Broadcomu narejena 3Com je precej boljsa od na Relateku narejene CNet.
KoKi ::
Ce mi najdes 3com gigabit za 10k (ali manj..) dobis za pir ;) Drugace pa sem se ze 99% odloco za SMC 9452TX (10k). Hvala Brane.
  • spremenil: KoKi ()
matevzm2 ::
Tezko za tako ceno. Lahko pogledas se ce najdes kaj o Intelu, Mlacom ima za 13k Intelovo kartico.
Nekaj 3Coma imajo tudi v Comtronu v BTCju v LJ, tam imas switch in bojda zraven dobis kartico, cena je okoli 40K - tam nekje, samo bi moral bolj podrobno pogledati.
Bakunin ::
(desktop) Gigabit Intel dobis za ~12.000 SIT.
  • spremenil: Bakunin ()
KoKi ::
matevzm2: Sem tud tukaj pogledo, samo Mlacom nima dostave, pa se mi ne da iskat pol Ljubljani.
j: A se lahko poves kje? Ker v aje sem videl da stane SMC 10k nekje drugje pa je bila za 18...
Bakunin ::
www.mlacom.si
INTEL 10/100/1000 PRO PCI (z DDV) 15.120 (na gotovino imas popust)
lopov ::
Sem gledal test ... Se mi zdi da se tudi D-link dobro odreze, cena je 35$ kar se je bi znalo tudi pri nas biti ugodno.
Gigabitni switch
Oddelek: Omrežja in internet
303344 (2798) ender
Kategorije ožičenja Ethernet
91410 (1246) iges
giga mrezna v linuxu
51041 (945) Tomay
10baseT - xover
51362 (1297) VidKo
Intel Pro/1000 MT Server Adapter Dual Port
183391 (3142) Spc
